Question about Dyson DC07 Bagless Upright Cyclonic Vacuum
Took out the hose from the handle and now it's not
The vacuum was working fine. Then I removed the handle to try to get access to the hose. I put the attachment on and now the vacuum won't turn on at all.
    Sergeant:
  • 197 Answers
The dyson should work with or with out the hose wand (handle), so I think its more like the mains lead or the switch is faulty, do you know how to do a continuity test, with a tester? if not you may have to seek an approved engineer to test it.
Does it switch on when its not been used for along time? if it does - could be a blockage
Posted on Sep 29, 2009
My Kenmore vacuum model #116.27515 will not turn on.
When you took the hose apart were there wires that you had to take apart as well. If those wires were inside the hose then you need a new hose. I think they are about one hundred dollars or go to second hand store and get a used one.if you can.
Jan 28, 2016 | Kenmore Vacuums
Cant put handle back on
Sometimes the hose that slides on the inside of the handle is coming undone. You will need a new hose.
Sep 05, 2014 | Dyson DC25 Animal Bagless Upright Vacuum
Meile vacuum s3121
push a broom handle through it or a peace of hose pipe
Nov 23, 2013 | Vacuums
Hose is plugged close to the handle. How is the handle removed from the hose and reassembled after the plug is removed?
I don't recommend this for the homeowner. Take the hose in to your nearest AERUS store. It is just too easy to damage the pins and rings putting the handle back on. If you insist on trying, remove the little torx screws under the little buttons on the top side of the handle. Good LUCK and be careful. Don't force anything.
Jun 10, 2010 | Electrolux Centralux Vacuum
I have an Aerus Guardian canister vacuum with a clogged hose. The tiny stuffed animal toy is lodged right below where the swivel handle meets the hose. Switching the air flow does not dislodge it. I would...
Consider this. If your vacuum is still under warranty, removing the hose will void the warranty on the hose. I strongly recommend calling an authorized dealer/consultant.
Although it may seem to be fairly simple to remove the handle, there are wires that need to be disconnected in order to separate the handle from the hose, gaining access to the toy. And reconnected. If not properly done, attempting this may lead to needing to purchase a new hose.
Apr 19, 2010 | Electrolux Guardian Bagged Canister Vacuum
Remove hose from handle on old electrolux canister
BE careful here. Do not fish a coat hanger in the handle.
The original hose has a set of detachable handle componnets.There are two metal screws in the underside of the hand grip.Do Not pry. Once removed go to the suction dial area underside of the grip. Observe the plastic fingers near the dial. These must be reset in their " track " when reassembling the handle.
Gently insert a small flat screwdriver between the rubber wiring contacts and the plastic tongue wraps around the socket. this tongue which extends from the hose handle adjacent to the metal tube. Work you way back to the hose area carefully separating the "hand grip cover" from the hose handle itself.
Once apart remove the obstruction. Carefully clean the two brass rings looking for any pitting. If pitted, gently polish by rotating fine wet/dry sandpaper around the rings, then lube with vaseline.
The matching contact fingers on the handgrip cover should be cleaned as well and gently tensioned to put a bit more presusre on the contact rings.
Slide the handle ONLY onto the hose. Once in place the contact rings will be visible. Now you can work the handgrip cover back into place starting with the two tabs at the hose end below the contact rings. To seat the small fingers at the control valve gently click into place before reinstalling upper handle screws.
Jun 15, 2009 | Electrolux Central Vacuum
Panasonic Vacuum MC-E450UK
Panasonic MC-E 450UK upright vacuum cleaner.
Just had this problem myself...........easy to get at it when you know how.
Panasonic UK wouldn't help me so I spent some time working it out..........here it is.
Remove the hose from its mounting storage at the rear (called hose clip) where the main body of the vacuum cleaner meets the base of the handle assembly. Remove the screw at the rear of the handle assembly which is behind where the hose 'was' situated and is located inside the deep recess.
Using the soft part of your clenched hand as a hammer, knock the base of the handle assembly at the front and it will slide backwards off the main body of the vacuum cleaner. Don't be scared, give it a thump and keep moving it backwards with a few more knocks.
Next remove the two screws at the front which hold the mains cable and on/off switch cover in place.
Finally looking from the rear once more, lift the plastic 'lug' at the top of the cover and which is part of the cover. This will now allow you to release the cover and pull it forward.
There you go! Told you it was easy!
Watch out for the funny little spring at the front behind the cover in the tiny plastic tube where it connects to the small rubber tubing as it could possibly try to escape.
You now have complete access in order to cut the intermittent part of the cable out and remove it from the 'choc' block.
Happy fixing!!
Jack.
Apr 07, 2008 | Vacuums
Kenmore Progressive Direct Drive Upright - noise and bad suction
Had the same problem tonight. Took the entire thing apart only to find there was a much simpler solution. Check the small hose that runs from the brush rollers where the longer hose (on the back) attaches to the side of the vacuum. Easiest way to do this is to lay the handle down and stick something (coat hanger worked good) through it until it comes out of the head. I found a pretty good sized fuzz plug in mine. As soon as I removed it, everything worked great again - and no noise!
Mar 15, 2008 | Kenmore 31912 Progressive Direct Drive...
Vacuum doesn't work when main attachment is on....
S3765-040, power head would not run when the handle was elevated. Problem was with wiring from connecter plug on power head swivel into the power head itself, because of the design the wire tends to develop a short. Test it by turning on the vacuum, elevate the handle, then when it stops running move the visible part of the wiring with you foot/hand. If it starts/stops then you have a short. Replacement part was about $10.
Oct 17, 2007 | Hoover S3765-040 WindTunnel Bagless...
My Hoover is picking dust , very poorly
The Telios has a bad design on the handle and it sounds like something has definately got stuck. Unfortunately the nature of the cheap European design means the handle can only be removed by someone who owns a vice in their garage without breaking the removal points. Alternatively find a long bamboo stick or pole to put inside the hose mount which connects normally from the main bin of the Telios (not the other way around up the handle) which has no sharp edges and push up and down vigourously to dislodge any clogged dirt which may have inadverntely got stuck either by the handle or in the hose itself.
Another thing to do is to check the suction from the Telios itself by removing the hose. If there is suction coming from the main dirt bag/bin door with the hose removed then there is no problem other than a clogged hose and handle. Hoover updated the handle and hose in 1999 and spares can be found by looking on Ebay.co.uk for cheaper prices.
Aug 12, 2007 | Hoover S3330 / S3332 Straight Suction...
Dyson DC07 Bagless Upright Cyclonic Vacuum Logo
93 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
