SOURCE: Lost the instructions need help setting it up for
Here ya go:
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/dt300.ashx
Testimonial: "great instructions, thanks"
SOURCE: Hi I sent this enquiry
I'll take a shot at it, although I can't find a manual.
There are 5 buttons that you can push:
Reset, Set, +, -, Enter.
Inserting a pin in the Reset hole will erase everything.
You probably press Enter to cycle through Program 1, 2, 3, 4, 5, 6, Auto, Manual. Then use +, - to set the function, such as On time or Off time.
Then use Set to program.
In other words, to set the lamp to go on at 6pm and shut off at 11pm:
Press Enter until you see Program 1 flashing or highlighted in some fashion.
Use + or - to set the On time, press Set.
Use + or - to set the Off time, press Set.
Try this and get back to us.
Gary
SOURCE: need a print out of instructions for my digital
GE 15079 timer instruction manual appears on following link:
http://waterheatertimer.org/GE-timers-and-manuals.html#15079
If this is not your timer, then add a comment with description of timer and buttons and function.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on timer.
SOURCE: I need instruction manual for TD126 timer
TD126 timer
I'm going to guess at these instructions since they're not posted anywhere yet.
It's a chance I will be wrong, and others can add a comment and refine the answer.
The other option is: you can buy timer and scan your manual into pdf format and post it on your website for free.
Then add a comment with manual web location so we fixyans can sell your manual and manual information to other folks who are wanting a manual to sell to other folks.
Another option: You can pay a fixyan to buy the timer and do the work for you.
My guess is that free is better:
Plug timer into outlet for 1 hour to charge battery.
Remove timer from outlet to program.
Timer appears to be a 24-hour repeat timer with 12 hour am-pm format
There are 5 buttons on face of timer: Reset SET + - Finger
-Press reset button to clear programming.
-Set current time: Push and hold finger button while pressing + and - until current time and am pm display. Or push and hold SET button while pressing + and -.
Program timer:
-Press finger until PROG 1 ON displays
-Press press + and - to set program1 ON Hour.
-Press SET to confirm hour
-Press press + and - to set program1 ON minute.
-Press SET to confirm ON minute
-Press finger until PROG 1 OFF displays
-Press press + and - to set program1 OFF Hour.
-Press press + and - to set program1 OFF minute.
-Press SET to confirm OFF minute
-Press finger until PROG 2 ON displays
-Repeat steps above.
-When programming is finished, push set button.
And you might have to push finger button, or push and hole finger button, and then set button.
-Timer appears to be in AUTO as default mode.
Timer may also have a switch located on side of timer. Move switch to timer if there is a switch.
Some timers also require you push two buttons at same time to enter different modes, or hold one button while pushing other button.
SOURCE: brinks 44-1030 manual i need a
1) Can you describe the timer in detail?
The buttons and the dial, shape, if it plugs in or is programmable, whatever you can think of to illustrate what timer looks like.
I have extensive files on timers
Most brinks timers are versions of other timers, and manuals exist for those timers.
Add a comment with the information, and I will post a manual if timer matches other brands.
2) You can open following link and see if your timer appears on the page:
Manuals appear for each timer on page with a few exceptions.
http://waterheatertimer.org/Woods-timers-and-manuals.html
3) Another step would be to buy the 44-1030 at Walmart and scan the manual into .jpg format.
Download Cute-writer the free pdf software.
Print your .jpg image but select cute-writer as the printer.
Instead of printing, the software makes a pdf manual.
I use this technique when I need a manual
Title your new manual and post it on the internet for sale.
Return the timer for a refund.
4) Add a comment for more free help.
For a price, fixya expert speaks with you over phone while you describe timer.
i am looking for replacement pegs to turn the lights on and off. the black and red ones. I have lost one and the lights stay on all night and day
