Question about LG 32LG30 32 in. LCD HDTV
How can you add channels that are available but did not come up when using the auto scan? I have selected the new channels, but they have failed being stored. In short, which button do I push?
  • susan_byrd Sep 29, 2009
    I did scan again immediately. The manual that came with the LG is vague on how to store the new channels and your solution was not helpful.
  • 33 Answers
Scan a new search
Posted on Sep 29, 2009
How to reset channel auto scan.After I finish channel scan,message pops up stating PLEASE RUN CHANNEL AUTO SCAN,
If when You scan, and you don't get at least one channel, it will keep showing You this message! look at screen it will show new channels! if no new channels check to make sure your coax is hooked up good, also make sure you are using right setting if outside antenna, select antenna, if cable select cable for your source!
Nov 03, 2016 | Televison & Video
MY TV will not let me change the channel it is reading Channel not available. How do I fix this problem?
all of these newer TV's need to auto scan for channel's.which only takes a few minutes usually.look under the MENU selection
Jan 05, 2015 | Televison & Video
How do i get a signal using co-axial connections
An antenna on one end of the coaxial cable will get signals. The other end can connect to your TV. Then in the menu on the TV you have to select 'antenna' instead of cable. Many seem to have some kind of 'auto scan' mode that will look for channels available. (Unless you are talking about getting signals from the cable company. Then select 'cable' and still auto scan to find available channels.)
Oct 20, 2014 | Televison & Video
What is the steps for channel search
Go into main menu and select AUTO PROGRAM AND ENGAGE.
Set will scan thru and store all available channels---you can also add manually or delete channels you do not want.
Jan 09, 2012 | Panasonic PT-53WX53 53" Rear Projection...
How do I retune my Panasonic Viera TV?
Hello
To tune your Panasonic Plasma to on air TV channels do the following:
Connect the antenna connection to its antenna in at the back panel.
Automatically searches and adds available channels to the memory.
Select "ANT in"
Select Cable or Antenna Select "Auto"
Select a scanning mode
Auto channel setup
Select "Auto program"
Select "ANT in"
Select "Auto"
Select scanning mode (ALL channels/Analog only/Digital only
Start scanning the channels
Available channels (analog/digital) are automatically set.
All channels: Scans digital and analog channels
Analog only: Scans Analog channels only
Digital only: Scans Digital channels only
Confirm registered channels
If OK is not pressed after selecting "Apply", the channels will not be saved.
The channel will be saved when no operation is performed for 60 seconds and
the "Manual program" menu will also exit automatically.
If you perform scanning more than twice, previously saved channels are erased.
About broadcasting systems
Analog (NTSC): Conventional broadcasting
Digital (ATSC): New programming that allows you to view more channels
featuring high-quality video and sound
[Use "UP ' DOWN ' RIGHT ' LEFT] AND 'OK"] keys to selcet and proceed.
Mar 07, 2011 | Panasonic Viera TH-42PZ80U Plasma TV
How to tune channels first time when you purchase a new Sony Kdl 32EX600 LED tv?
Hello
Do connection to the antena if you wants to set the TV auto tuned.
During this initial setup, you can perform the following:
1 Select the language for the on-screen display text.
2 Select HOME or Retail mode. [Here you have to select "Home" mode if the set displays "Retail"
3 Connect cable or antenna, then select OK to run Auto
Program
• If you have cable and antenna available, please connect cable first.
• IMPORTANT: Auto Program is only effective when cable or
antenna is connected. If you cancel Auto Program before completion some channels may not be
available.
4 Auto Program will scan for available channels from the signal source directly connected to
the TV's CABLE/ANTENNA input and may take sometime to complete the process. Follow
the help text provided on the screen to run Auto Program.
OK.
Feb 23, 2011 | Sony KDL40EX600 TV
I don't understand the manual! How do you get any channels tuned in on the Technika LCD19-910
on all tvs there is a menu pannel find the menu button on the remote or tv could also be called setup button look for channel option or antena cable option (no on most of the new tvs it is an auto scan) and select that option it will scan throught the channels and auto add the ones that get reception say if ur using an antena
if u are trying to hook up a cable box or sat box through the antena coail wire at the same time u can not have them on so to scan for antena channels turn off the sat recver and cable box scan for channels because the sat box and cable box destors the singnal when on the same time with the antena u will proble have to go back into the main menu where yu selected the channels and manualy add channel 3 or 4 which is what runs the sat/cable box if ur using the antena hookup on the tv
if u are hooking the sat/cable box or dvd player to red gren blue or yellow white red hook up's they will be under a diffrent source chanel which u can usaly get to by hitting the input or source button on the remote
Jan 15, 2011 | Televison & Video
I have a model number sd-p503p-k i dont know how to add channels after channel 65?
You probibally need to re-scan your available channels. The TV goes through and grabs all of the available channels that it sees so you don't get any all static channels while your surfing the tube. The manual is actually about 35 megs so I cannot post it here, but here's what it says; - Hit Menu
- Select Setup
- Select Channel Setup
- Select Auto Channel Preset
- Select Antenna and change it to A or B, whichever one your using.
This should fix your problems, unless your area doesn't have channels past 65. If that's true then everything I just wrote is irrelevant, but there ya go!
Oct 28, 2009 | Pioneer SD-532HD5 53" Rear Projection...
'satellite' icon not available to retune digital channels
Updating the Channel List Automatically You can update the channel list when the broadcaster adds new Services or if you move the TV to a new location.
1. Press the MENU button to display the menu. Press the ▲ or ▼ button to select "Digital Menu", then press the ENTER button.
2. Press the ▲ or ▼ button to select "Channel", then press the ENTER button.
3. Press the ENTER button again, to select "Country".
4. Select the appropriate country by pressing the ▲ or ▼ button. Press the ENTER button to confirm your choice. Even though you have changed the country setting in this menu, the country setting for Analogue TV is not changed. (Refer to page 11 of the user guide)
5. Press the ▲ or ▼ button again, to select "Auto Store". Press the ENTER button. When it has finished, the number of scanned services will be displayed. The existing favourite channel list will not be deleted when the channel list is updated. To stop the scan before it has finished, press the ENTER button with "STOP" selected.
6. Press the EXIT button to exit. If the signal status is poor, the "No Service found! Check the aerial connection" message is displayed. Check the aerial connection and the try the procedure again
Sep 30, 2009 | Samsung LE40R73BD 40 in. HD-Ready LCD...
Dont know how to do a channel scan on my samsung 2333hd t.v
Using the Color buttons on the Remote with the Channel List.
• Red (Antenna): Switches to Air or Cable.
• Green (Zoom): Enlarges or shrinks a channel number.
• Yellow (Select): Selects multiple channel lists.
• TOOLS (Option): Displays the Add(or Delete), Add to Favorite(or Delete from Favorite),
Timer Viewing, Channel Name Edit, and Auto Program menus..
Auto Program
The TV automatically cycles through all of the available channels and stores them in memory.
In rare cases, "Auto program" may miss a few channels due to weak signals and the channels may
not be added to the channel memory.
Air
Cable
Auto
MENU → arrow up, arrow down→enter → arrow up, arrow down→enter →arrow up, arrow down →enter →arrow up, arrow down, arrow left , arrow right →enter → MENU,EXIT.
Hope this helps. I have the owners manual on file.
Sep 01, 2009 | Samsung SyncMaster 2333HD 23 in. LCD TV
LG 32LG30 32 in. LCD HDTV Logo
134 people viewed this question
Computer Repairing
Computer Repairing
