Question about Frigidaire Refrigerators
Everything is freezing in our refrigerator even
Most everything is freezing in our refrigerator even after cleaning the coil and turning way down on tempeture control
  • 50 Answers
Your thermostat has failed and requires replacement. If the fridge is very old you could use a mains interupter device that has a temperature sensor that is placed in the fridge. There are several hobby kits for such devices usually used for converting old fridges for wine storage.
Posted on Sep 29, 2009
Ice maker not working AND food in fridge is freezing
Seems that you have a problem with your controls. Check the timer sequencer and thermostat.
Mar 16, 2014 | Refrigerators
Kenmore elite coldspot model 106.74219400 freezes in the fridge never gets above 5 or 10 degrees and it never shuts off.
there is a flap in the refrigerator side usually near or behind the light bulb the freezer side is thermostatically controlled with the compressor being controlled. On the refrigerator side the cold air comes from the freezer side. when this flap is open the refrigerator will cool continuously, Check the flap or the duct assembly
here is an illustration of the part
http://www.repairclinic.com/Kenmore-Refrigerator-Model-10674219400-ID-927868-Duct-Venting-Parts
Apr 14, 2013 | Kenmore Refrigerators
Roper refrigerator is freezing everything even when the dial is turned off. Help, a root beer just exploded!!
First check for ice build up in the freezer, which would indicate a defrost circuit failure. Look for ice build up on the evaporator coil.
You might be best served by manually defrosting your refrigerator and seeing if the indications change.
Feb 01, 2012 | Refrigerators
It's freezing everything.
Hi, refrigerators have either a mechanical defrost timer, or an ADC (Adaptive Defrost Control). If your refrigerator has a mechanical timer, set the cold control to the coldest setting and then advance the defrost timer. You can manually advance the timer with a screwdriver. Insert the screwdriver into the advancement pinion and turn clockwise a 1/4 to 3/8's of a turn. If the compressor starts, replace the defrost timer. For further help, you'll want to call a professional appliance repair technician.
You can use a condenser coil brush to clean the coils periodically. Because the coils exchange heat, any dust, lint, or dirt on them cuts down its ability to exchange heat.
May 19, 2011 | Dometic Refrigerators
Frigidaire Side by Side Fridge. FRS26H5DSB4, both controls are turned to 0 and still everything in fridge freezes. Have cleaned the coils and samething. Thanks,
The compressor run time isn't being controlled any more and either the sensor or the control itself will need replacement. You might have noticed that the compressor is running either continuously or at least too long.
Oct 25, 2009 | Frigidaire FRS26H5AS Side by Side...
My arctica side by side is running very cold...everything in frig is freezing, even when I turn up the temperature. The freezer, also, is running colder than zero. I've cleaned the back, coils, etc. and...
sounds like the controil board is locked in run
try unplugging it for about 10 minuts
if that does not work you will need service to properly dioagnos the control
the artica has had issues
hope this helps
Oct 13, 2009 | GE Profile Arctica 25.4 Cubic Feet...
Frigidaire is freezing everything!
Possible defrost timer or thermostat failure.
Jul 11, 2017 | Frigidaire FRS26H5AS Side by Side...
GE Frigerator has intermittant Freezing
It sounds like the defrost heater is burned out. Remove the inside back cover in the freezer to see if the coils are frozen up. If so, more than likely your defrost heater has bit the dust. It is located at the bottom of the inside coil of the freezer.
Also, you could be have a clogged condensor coil. It is located on the out side back of the Fridge. You need to remove the panel from the lower part of the fridge and do a thorugh cleaning.
Nov 01, 2007 | Refrigerators
Refrigerators Logo
116 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
