Question about Kenmore Dryers
My dryer stops and a e1 code shows
E-1 code
  • 50 Answers
This is a faulty sensor. Check with your dealer for a spare part.
Posted on Sep 29, 2009
Shortly after starting a load in the dryer, the dryer stops, beeps and the lighted code says E1. The grid on back wall of dryer is very hot. I am unable to find my instruction booklet. This keeps...
The E1 error code means that the electronic thermostat is the problem. With what your describing as far as it being very hot and the E1 code,i would suspect one of 2 things;
1) the thermister is bad and needs to be replaced
2) thier is a blocked/restricted vent and or excessive lint built up in the blower housing causing the heat to be retained in the dryer instead of being vented out and across the thermister where its getting a false reading and throwing up the E1 error code
GENE
Sep 12, 2011 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Dear I have samsung dryer model jv665jw , it starts for 3 seconds and stop , on disply it show error E1 ! What is the problem please ?
It's a error code and you can call your local appliance store and give them the code they should be able to tell you what it is that's setting that code. I think E1 is the control board and usually runs in the $200 range to replace. Hope it's a simple fix though.
Apr 29, 2011 | Samsung Dryers
What is E!
Hi
Thanks for using FixYa. Error E1 means thermistor failure, it flashes when the thermistor circuit is open. The dryer will not operate if the exhaust temperature drops below 18° F. or exceeds 250° F. To resolve this the thermistor should be replaced. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 06, 2010 | Whirlpool ET8CHEXSQ Dryer
Code E1
E1 or E2 Thermistor Failure
The dryer will not operate if the exhaust temperature drops below 18 degrees F. or exceeds 250 degrees F.
When the thermistor circuit is open (>50K ohms), the error code E1 flashes in the display.
When the thermistor circuit is shorted (<500 ohms), the error code E2 flashes in the display.
Normal thermistor resistance values:
60 degrees F. - 15.3K ohms.
70 degrees F. - 11.9K ohms.
80 degrees F. - 9.2K ohms.
Take the top off the dryer and inside you'll find the "tech sheet." It has instructions for removing the front panel and locating the thermistor.
Apr 21, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
HE3 dryer stops drying with code E1
Hi, how are ya?
The E1 is a thermistor problem. It's a little black fuse that's next to the thermal fuse on the duct housing.
It's pretty easy to fix. You need to take the bottom pannel off and then the black blower housing.
Good luck :)
Aug 06, 2009 | Kenmore Elite HE3 Steam 8674 Dryer
I'm getting an E1 signal from dryer...What is the
This usually works to unlock the E1 code
To unlock the Control Locked feature:
Press and hold the End Of Cycle Signal buttonfor 3 seconds to turn this feature off.
NOTE: When the dryer is running and Control
Locked light is on, the dryer can be stopped by
pressing the Pause/Cancel button, but cannot
be restarted until the control is unlocked.
If this worked for you don't forget to give me a ranking. Thank you!
May 06, 2009 | Kenmore Elite HE4 Electric Dryer
My dryer stops in mid cycle and gives me an error code of E1
It is a bad thermistor on the blower housing
http://forum.appliancepartspros.com/dryer-repair/1379-kenmore-elite-e1-sensor.html
Apr 18, 2009 | Kenmore Elite Oasis 6808 Electric Dryer
ERROR CODE E1 MODLE #GGW9200LW O
E1 error code is for the thermistor, try cleaning off the bottom of the thermistor, (sometimes tacky lint will coat them), if that doesn't help, just replace the thermistor.
Sep 17, 2008 | Whirlpool GGW9250PL Gas Dryer
Dryer turns off and shoes e1 code
E1- Thermistor open.
It monitors the exhaust temperature, and cycles the heater relay on and off to maintain the desired temperature.
It could be the sensor, or electronics.
May 08, 2008 | Whirlpool GGW9200L Gas Dryer
E-1 light
check owners manual should have a code listing. Have you checked the vent and venting
Oct 17, 2007 | Kenmore Elite HE4 Electric Dryer
Dryers Logo
61 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
