Question about Whirlpool Duet GHW9150P Front Load Washer
Our washer seems out of balance is there anything we can do ourselves?
Rebalance the load
Posted on Sep 29, 2009
Out of balance switch will not stop washer when load becomes out of balance.
Your switch is bad. You don't necessarily need the switch. Snip the wires off either side of the switch and fuse them together with a wire connector.
May 06, 2012 | Maytag Atlantis MAV6000 Top Load Washer
Washer drum off balance
there is an alignment track that the drum rides on it uses little wheels that ride on this track to keep the drum in the right place. either the bracket holding thos wheels to the back of the drum are loose or the wheels themselves are worn. these should be checked for servicabilty or replaced the problem is not the drum itself.. please rate.
Oct 07, 2008 | LG WM1812C Front Load Washer
I have a GE front load washer ( # WBVH5300KOWW ) purchashed 03/24/2010 that constantly gets off balance with certain loads. The drum bounces from side to side in the machine and the washer actually walks...
I dont know if it would apply to the GE brand front loader, but for a while excessive vibration was a problem with another brand and they came to find the rubber foot on bottom was made from a too hard composite and made replacment legs with a softer rubber foot and that solved the problem. Perhaps that may be so here,also they should check for a weak shock asorber/ outer tub strut
Aug 16, 2011 | Washing Machines
Seems out of balance when spinning
the washer may not be level, or when you put the clothes in, you're not distributing the load well. doubt the last one, but before you do anything, make sure the washer itself is level
Jul 06, 2011 | Washing Machines
I overloaded my washer and now when it spins it seems to be off balance. It's really loud and inefficient in getting the water out of the clothes. I don't know anything about electronics and don't really...
You may have knocked the whole machine off balance. Is it a bit wobbly when you lean on it? If so adjust the feet to level it.
Try spinning on empty to get the drum happy again.
Dec 09, 2010 | Kenmore Elite 45986 Front Load Washer
Drum seems broen and off balance
if it is washer, most likely need spring kit they look like shocks that the tub sets on
Apr 18, 2010 | Kenmore 98702 Stacked Washer/Dryer
Top loader Maytag washer cannot balance load
The shock absorbers that hold the tank are broken. Then the load will move the washer all over the place.
Look online for an exploded diagram and order the new shocks for it
Nov 12, 2009 | Dryers
We can't seem to balance our washer barrel with or without a load. it spins out of balance. all springs are good.
Is the washer itself balanced? Have you tried adjusting the adjustable "leg" screws on the bottom of the washer?
Aug 16, 2009 | Washing Machines
Our washing machine suddenly started making a loud clicking/banging noise when it spins - it is not related to size or balance of the load - what is causing this and how can it be fixed and is this a...
the drum glides may be worn - or the suspension dampers failed/out of oil.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Aug 08, 2009 | Kenmore Elite 45986 Front Load Washer
Out of balance spinning.
there is a spring that hooks to the back the tub of the washer and conects to the frame of the washer its there as a counter balance. if that spring was not put back in place the washer will shake like crazy. if that spring is conected the basket is warped
Nov 17, 2007 | Bosch Nexxt Premium WFMC6400UC Front Load...
Whirlpool Duet GHW9150P Front Load Washer Logo
90 people viewed this question
Dan Webster
Dan Webster
Sal De
