Question about Dmm M-D Building Products Box Beam Level, 48"
I am using a metal folding machine to bend a 90 degree angle into 4m long stainless steel plate, it is coming out at 90 degrees but has a big bow along its length. What are the common causes of this? Many Thanks.
  • 50 Answers
Worn machine is possible cause.
Posted on Sep 29, 2009
What foot and setting do I need to sew strips of bias binding together.
If you are sewing bias strips end to end, any foot would work. A 1/4" seam allowance is probably fine. You'll probably just need to cut the ends @ 45 degree angles and match them up before stitching. Sewing them at 90 degree angles creates a big bulk of fabric whereas 45 degree angles spread the bulk out when applied to your cushion fabric.
Learn How to Join the Ends When Quilt Binding Tips from McCall Quilting
Mar 16, 2017 | Sewing Machines
Need torgue specs for bolts on head of my 2000 vauxhall tigra 1.4
Cylinder head bolts (You must use new bolts)
stage 1 ... 25 Nm (18 lb ft)
stage 2 ... angle tighten + 90 degrees
stage 3 ... angle tighten + 90 degrees
stage 4 ... angle tighten + 90 degrees
stage 5 ... angle tighten + 45 degrees
Remember use NEW bolts, these are called torque to yield bolts, they stretch like a linear spring and they only last one use.
Jun 25, 2016 | Vauxhall Cars & Trucks
I want to know the torque opel corsa lite 1.4 cylinder head bolts.
Feb 26, 2015 | Opel Corsa Cars & Trucks
How can you classify a triangle according to it angle? is there a formula for it
Well, there is classification by sides, equilateral with 3 equal sides, Isosceles with two equal sides, and scalene with no equal sides, but you talk about angles, but I wanted to point out equilaterals have 3 equal angles, isoceles have 2 equal angles and scalene have no equal angles.
So, now we talk about angles: a Right trianlge has one angle that is 90 degrees, an Obtuse triangle has one angle greater than 90 degrees, and an Acute has no angles over 90 degrees.
Thus, it is possible to have a (scalene or isoceles) AND (acute, obtuse, or right) triangle, but never an equilateral AND (obtuse or right). The angles can't be equal and 90+ degrees if all three must equal 180 degrees.
Oct 06, 2012 | Mathsoft StudyWorks! Middle School Deluxe...
The handle opener on my my Kitchenaid whisperquiet dishwasher is completely loose and I can't open the dishwasher to remove my clean dishes. What can I do???
The idea is to lift up on the part of the latch that is fixed to the body of the washer. The door part of the latch slides under this peice. If the handle mechanism is broken, it will not depres the door part of the latch to allow it to open. therefore, we have to pickup the latch part fixed to the body.
To get the door open, take a clothes hanger and cut off a 12" peice with a pair of pliers. Bend the last 1.25" at 90 degress angle. Make another bend about 4 " from that to make another 90 degree angle. This will give you leverage. Insert the first bent end between the top of the door and the counter. Rotate it so that the end is facing down. Feel for a metal plate. When you hit the plate with the probe, turn your hanger so that it lifts up the plate and simultaneously pull on the door handle. The door should come open.
Now you have to get the handle repaired, but at least you know how to open the door.
Oct 25, 2010 | KitchenAid 24 in. KUDS25SH Built-in...
KUDS25SH DOOR WILL NOT OPEN THE LATCH FEELS LIKE SOME THING HAS BROKE OR LOOSE
Jul 12, 2010 | KitchenAid 24 in. KUDS25 Built-in...
Directions on how to use a square to cut common rafters we have a stanley squ and no manual, on use
A standard square is used primarily for drawing 90 degree angles. Simply hold the fat side of your square firmly against the length of rafter. The skinny side of the square should be lying accross the rafter, forming a 90 degree angle with the side. Use a pencil to draw a line along the edge of the square and use this line as a guide while sawing the rafters.
Sep 27, 2009 | Carpenter Stanley 45-500 Handyman Steel 's...
Can't open door
Is this the kick plate? On some of these dishwashers, the upper part of the lower plate has a step. The step should be oriented so that it looks backward when compared to an actual set of stairs (the ninety degree angle will come into the dishwasher and the flat side be oriented to the floor). If you're putting the plate on upside down, it will get in the way of your door hinges.
Sep 10, 2009 | Jenn-Air 24 in. JDB1090AWS Stainless Steel...
Torque settings for big ends on a 97 toyota camry 220sei
On the V-6 it's 25 Nm (18 ft lbs) on the first pull and then you rotate the next pull 90 degrees using a torque angle wrench.
Checking the specifications for the four cylinder:
25 Nm (18 ft lbs) on first pull and 90 degrees
on the second pull using a torque angle wrench.
May 01, 2009 | 1990 Toyota Corolla
Put back smeg oven door
Yeah I was stumped with this for a short time as it isnt imediately obvious.
The bottom of the two brackets has a flip up catch, place these in the upright position and with some force hook the upper bracket into these catches (please ensure you keep your face and hands away from the direction of the spring)
Once you have the two brackets held open offer up the door at exactly 45 degrees (notice the notch on the underside of both lower brackets) locate this notch on the door hinge hole studs.
Once this is done and your certain it is in the correct postion lower the door from 45 degrees to 90 degrees, put some pressure on the door slightly past 90 degrees and carefully fold down the flip up catches that are holding the upper brackets.
Jan 28, 2008 | Smeg SE250XUK Stainless Steel Electric...
Dmm M-D Building Products Box Beam Level, 48" Logo
47 people viewed this question
Top Dmm Measuring Tools & Sensors Experts
Vuk B
Carlos Elizondo
Carlos Elizondo
Level 1 Expert
Are you a Dmm Measuring Tool and Sensor Expert? Answer questions, earn points and help others
