My XC 865 Xerox Copier has been trouble-free and productive for about 10 years. I thought it could use routine maintenance now, as it crumples paper now and then, and needs ink at the moment. Do you know of anyone who will come to my house in Medford, MA 02155, to service it? My number is 617-429-2422. Sincerely, Carolyn Stevens
  • carolyn2stev Sep 29, 2009
    Hi, thank you for the suggestion.  why is it important to remove my phone number?  And if it is important, would you please assure that it is removed, and tell me.  Thanks, CS
    Scholar:
  • 112 Answers
Here is a link to a company out of Boston that sells and services Xerox equipment.
http://www.doctech.net/
I'm not sure if you can modify your question to remove the personal information you posted but I suggest you try. I'll also flag the post so perhaps a moderator can remove your phone number.
Posted on Sep 29, 2009
  • compugrl Sep 29, 2009
    I can't remove the phone number from your post. It is never a good idea to post your phone number in a public forum on the internet.
Documate error 8
Hello.
I am a Support Engineer with Xerox Scanners.
E8 is a Paper Jam error that could be caused by:
- paper crumpling during scan.
- paper is multi-feeding all at once instead of feeding separate.
- scanner continuously tries to feed after paper has fed through.
if the paper is crumpling during the scan, make sure the inside of the scanner is clear of any obstructions. use the paper guides in the ADF tray to keep the paper straight when feeding in.
if the paper is multifeeding while scanning, fan out the pages before inserting them into the scanner. if problem persists, try cleaning the rollers with rubbing alcohol and a lint free cloth.
if scanner tries to continually feed after the paper feeds through, the ADF tray will need to be reseated. open the scanner and remove the ADF tray at the top. line up the 4 keys at the bottom of the tray with the 4 corresponding key slots inside the scanner. push the tray back until it clicks into place.
We also have an extensive support site and knowledgebase at
http://www.xeroxscanners.com/en/en/support/
If you continue to experience trouble, please feel free to contact us by calling 800-648-0410.
Regards,
Xerox Scanners Support
Jan 28, 2013 | Xerox DocuMate 162 Pass-Through Scanner
Tip
Xerox XC and XD series copier H3 or H4 error code reset procedure
To reset the H3 or H4 condition on just about any Xerox XC or XD series copier press the following key's in sequence and as quickly as possible (with 4 seconds for the first 4 keys)
Press "C" then the far left key (exposure mode) then the "C" key then the far left again.
So in other words C, far left, C, far left
If done correctly the display should go blank.
Now key in 14 as if you were going to make 14 copies.
Now press the print button.
The machine should reset and the code should be gone.
9 times out of 10 this is a false code that pops up due to power surges or noise.
If the code comes back this means you have a heater lamp or thermal fuse (more common) failure in the fusing area and will need service.
This procedure will work on all Xerox XD and XC models.
on Mar 20, 2010 | Office Equipment & Supplies
XEROX COPIER XC865 HAS AN H4 ERROR CODE HOW TO RESET AND WHAT DOES IT MEAN
H4Fuser temperature too low. Must be reset in diagnostics
Dec 18, 2009 | Xerox XC356 Copier
Xc 1040 xerox Red light is flashing and the copier will not
On a XC 1040 machine either there is a jam on the fuser, the fuser switch fell out of place, or the sensor swich arm fell off the registration sensor.
Since we cannot see the machine we might understand what is taking place.
If the machine is turned off and back on and there is no red light, then the machine must be able to attempt to make a copy. If a copy does not come out, then there is problely some worn feed rolls.
If when the machine is turned on and there is a red light then th There can be some bad paper feed cluthes as well.There might be a paper stuck at either fuser assemly or paper feed roller areas.
Provide more description about the visuals on the machine.
Good luck.
Jul 15, 2009 | Xerox WorkCentre 4118 Network Kit...
XEROX Phaser 8560 - Maintenance Kit
They sell a lot of maintenance kits that way.I worked for a major Tampa are copier company for 10 years and they used every part until it just quit.However, you should line up a maintenance kit at the ready.Sometimes a counter will shut down the copier when it gets to the point where they want it to stop.
Apr 07, 2009 | Xerox Phaser 8560MFP Laser Printer
Clicking sound and crumpled paper
Bad heat roll drive gear in the fuser. Very common problem.
Look up on google a business called "The Parts Drop". Ask for Britt, part is $13 or $14.
Aug 31, 2008 | Xerox WorkCentre XD100 All-In-One Laser...
Xerox xc 520
now you're testing my memory. The paper loads from the right side. You need a paper tray. The paper comes out on the left side. Also, the top is a moving platen (remember those?) so you need to have enough space around the copier for the top to slide left and right. Before buying a new drum, make sure you have a paper tray. No sense paying for a supply for something you cannot use. I need to check with a few people to see if I can find the reset sequence. It was in the manual, but like you, I no longer have one for that product.
Aug 25, 2008 | Office Equipment & Supplies
Can you help us with a copier problem
That sounds like your toner is empty. Sometimes that cartridge runs out or low on ink and just doesn't display.
What is happening is the density sensor is looking for a nice black patch and the patch it is looking for is gray or almost blank and it stays in a constant cycle of trying to make that ink patch dark enough to produce a copy,
I would try a new toner.
Jun 09, 2008 | Xerox Office Equipment & Supplies
Paper in copier hangs up
it sounds like the heat roller gear has broken. open machine and look @ the heat section in the back you should see the gear broke.
Nov 04, 2007 | Xerox WorkCentre XD120f Copier
jasbo
jasbo
