Question about Apex Digital AD-1225 DVD Player
Bad disk? my apex ad-1225 keeps saying every disk i put in is a "bad disk" when these play perfectly on my laptop or other people's dvd players, do i just need a new one?
  • 2 more comments
  • Anonymous Dec 29, 2007
  • Anonymous Jan 19, 2008
    I have the same problem. Keeps saying "bad disc" and won't play any disc. I know these discs are good.
  • Anonymous May 22, 2008
    my player keeps saying bad disc to all my discs
  • sarielfebo Sep 10, 2008
    my apex ad-1225 keeps saying every disk i put in is a "bad disk" when these play perfectly on my laptop or playstation2
SOURCE: Says no disk
its broken
Posted on Dec 23, 2007
VOTIT
  • 2071 Answers
SOURCE: APEX AD-1115 DVD PLAYER
Manually cleaning the lens
To locate the laser lens, look around the door or drawer of the DVD player and you will see a small circular disc, which is often called the turntable or disc platter. Right off the edge of the platter you should see a small clear lens. There are some manufacturers that have had problems with the lens, depending on the age of the unit. In these problem players, moving the unit to a different location, turning the unit upside down, or sometimes even without moving the unit, the lens can become detached from the laser assembly and floats around inside the unit. You can re-glue it back with a little crazy glue, BUT it must be perfectly centered, and without getting any glue on it. So, if you don’t see the plastic lens, but instead see the laser pick-up assembly, look around for the lens inside the unit and glue it back on.
To clean the lens you must use very little pressure. Take a cotton swab and barely moisten it with plain, non-scented, or oily type alcohol. In a swirling motion, very gently rub the lens until you’ve covered it entirely. Then repeat using the dry end.
If the cleaning didn’t help, don’t despair just yet. You can see if there’s a problem elsewhere in the unit by using a few simple tricks and tips.
First thing you want to see if the unit’s laser is in good working order. This method isn’t foolproof, but most of the time works admirably. When you insert a disc, see if you can look up underneath where the disc sits on the turntable. Observe the laser lens going up and down. If the lens is trying to focus, that’s good! After a few seconds of the lens trying to focus, the platter should start to spin. On almost every CD/DVD unit I've encountered, the unit won't spin unless the laser has properly focused on the surface of the disc. If the unit spins up and and then shuts down, you should check and make sure the laser pick-up assembly slider mechanism is working without any obstructions and that the small chrome rail that it slides on is slightly greased. Don’t go overboard with the grease though, as too much can cause all sorts of problems.
The slider mechanism, depending on the age of the unit and the manufacturer, consists of the small chrome rail, a drive motor, a small gear assembly, and (in some units) a small belt that drives the slider unit via the motor. This small belt causes all sorts of problems. If the belt is broken or slipping, it can cause skipping, dropouts, or simply no start up at all. Also, if the belt breaks in the middle of the disc, the drive mechanism gets hair or dirt wrapped up into the gears, or the pick-up assembly doesn’t return to the start position (called home), the unit will (99% of the time) refuse to release the disc, causing it to become stuck inside the unit. There’s a little micro or leaf type switch located at home position that sometimes gets dirty or breaks and, causing this problem also.
If the disc starts to spin slowly and doesn’t come up to speed, the spindle motor that’s attached to the turntable platter is a common problem. There could also be a problem with the spindle motor driver controller IC or the power supply regulator that supplies voltage to the driver IC. If the disc starts to spin and then spins really fast, or stops and starts to spin backwards, your problem is the laser pick-up assembly or the servo control circuit. If you continue to have problems after cleaning and checking the other things listed above, you may have a problem with the player's alignment. Of course, one of the problems you'll face checking alignments on a DVD/CD player is that you’re going to need to use an oscilloscope on most of them. If you have the proper tools and equipment, the first thing to look at is the RF pattern of the unit while its playing. It should be a sharp and clear pattern. If it's dull and smeared, then the laser could be weak.
Also, in these units are very critical alignments called the focus/tracking gains and offsets. When these alignments are off, it can often cause intermittent troubles. As the unit ages and parts change value, so do these alignments, and will need to be checked. In my time as service technician repairing DVD/CD players, 65% of the laser pick-up assembles I have tested were good and only needed a small adjustment. Today's technology makes it unfeasible for a shop to hook up a DVD/CD player, and even some recorders, to their equipment and make these adjustments because of the cost involved.
Hope this may help;
Regards,
VOTIT
DON'T TO FORGET TO RATE
Posted on Aug 25, 2008
  • 16 Answers
SOURCE: Replace DVD remote
Check this eBay auction for the remote:
http://cgi.ebay.com/Apex-Digital-AD-1225-DVD-Player_W0QQitemZ250397256142
Note, it comes with the DVD player free.
It's only $15.
Posted on Mar 30, 2009
  • 103 Answers
SOURCE: apex AD-1100W dvd/cd/mp3 player quit playing movies
hi,
Does it happen for all dvd disc or some particular dvd disc. If it is with some particular disc then clean the dvd and try them. If the problem exist for all the dvd then try to clean the lens by dvd lens cleaner and try to play. dvd lens cleaner will be available in dvd stores.
Thanks,
Posted on May 23, 2009
Vanguardian
  • 106 Answers
SOURCE: need manual
Here is the link to your manual.
http://www.apexdigitalinc.com/manual/AD-1225%20Manual.pdf
It may take a few moments to load, it's 25 pages long.
Posted on Sep 07, 2009
GPX D1816 DVD
This is a common situation, this an indication the laser assembly pickup is failing, it is far cheaper to replace the player than have it repaired.
Mar 10, 2012 | Apex Digital AD-1110W DVD Player
I put a disc in and it says loading then says bad disc....any solutions???
Several things:
If this is a disc you made, it probably is not finalized.
The disc could simply be bad.
The laser is dirty. If so, purchase a disc cleaner, or disasemble the unit, and clean the laser with rubbing alcohol and a cotton swab.
Dec 19, 2011 | Apex Digital AD-1225 DVD Player
I have a apex 1225 DVD player and the buttons on the front ( the open/close button) broke off the little box that hold all 3 buttons together. Is there any place I can get a replacment part to repair this...
No,the DVD players are so cheap now,not worth the money or the time to repair the thing.Parts belong to the cheap prices devices are impossible to find parts or they never produced extra parts for it.Basic DVD players,CD players are disposible machines these day.U can buy new one,around $40 dollars.
Jun 24, 2010 | Apex Digital AD-1225 DVD Player
Need directv remote code for apex digital ad-1225 dvd player
Apex Digital 20672, 20717, 20755, 20794,
20795, 20796, 20797, 20830,
21004, 21020, 21056, 21061,
21100
You can get the manual on link below.
http://www.directv.com/learn/pdf/Remote_Controls/DIRECTVRC64forWeb.pdf
Jan 02, 2010 | Apex Digital AD-1225 DVD Player
Need manual for apex ad-1225 dvd player
Sep 07, 2009 | Apex Digital AD-1225 DVD Player
Apex AD-1100W dvd/cd/mp3 player quit playing movies
hi,
Thanks,
May 23, 2009 | Apex Digital AD-1110W DVD Player
Replace DVD remote
It's only $15.
Mar 30, 2009 | Apex Digital AD-1225 DVD Player
JVC dr-mv77su/78bu does not recognize disc
hi , you have to open your dvd player and clean you laser lens whit a cotton swabs and alcohol do not use peroxide. Do it slowly and be careful
bye and good chance.
Dec 03, 2008 | Apex Digital AD-1225 DVD Player
WHY WON'T MY DVD PLAYER WORK?
you can try this unplug the unit , you'll need alchohol, q-tips, screwdriver open it and look for all the flat cable connectors. be carefull and remove 1 side at the time ,and clean the contacts, put them back on , see if you can see the optic laser inside the mechanism it looks like a crystal eye, if you can reach it be gentle and clean the dust may it have. or buy at radio shack a cd cleaner. if after that your dvd don't work with dvds try a regular cd. if it plays music the laser its bad nothig else you can do. cheaper to buy a new one
Jun 10, 2007 | Apex Digital AD-1110W DVD Player
Apex Digital AD-1225 DVD Player Logo
87 people viewed this question
Top Apex Digital Televison & Video Experts
Jaime Hernandez
robert landry
Are you an Apex Digital Televison and Video Expert? Answer questions, earn points and help others
