Question about Sharp AL-1217 Copier
Paper jam light on
We have a 'paper jam' light. Everything has been cleared and cleaned but light still on and we cannot copy or scan. Model AL-1217D
  • Sharp Expert
  • 257 Answers
After the paper passes the fuser unit, there is a sensor to show it has passed. If its actuator is not returning due to its spring dislocation, adjust that spring and make sure its swinging freely.
Posted on Dec 01, 2009
  • Sharp Master
  • 1,297 Answers
Check the paper tray sensor,one sensor is damaged.
Posted on Oct 03, 2009
  • 329 Answers
The censor that detect presence of paper in the printer has stopped working. check it if you can or get it repaired from local sevice centre......
Posted on Sep 30, 2009
How to reset the alarm indicator drum cartridge replacement in my copier machine sharp AL-1217D and it is necessary to reset the machine if you install a new drum unit? please help.
to reset drum counter u have to go in simulation clear density clear density enter 24 press start button where u normaly press to make copy then enter 7 again press start button off your machine and back it on that,s it
Aug 28, 2013 | SHARP AL-1217D
The "Paper Jam" light on my Sharp AL-1631 copier stays on
The paper detector on the fixing units have a history of going bad. The fixing unit is the hot roller above the drum inside the right door on the top. As the copy comes thru the rollers the paper hits a plastic lever that is spring loaded and located in the middle of the fixing unit. The sensor is all the way to the right side of the fixing assembly. If you move the lever in the middle you'll see a piece of plastic moving on the right, that piece comes out of the sensor and if can't reset the jam, that piece may not be resetting itself back inside the sensor. This is difficult to try to explain.
Good luck
Bob
Apr 23, 2009 | Sharp AL 1631 Copier
Paper Jam light on, but no paper jam
A piece of paper torn from copy paper is caught around registration switch, exit switch or feedshift switch.
so check theme.
Jan 18, 2009 | Sharp AL 1631 Copier
AL-800 cannot make copies jam light remains on with no jams
First, is the paper being fed at all? If the paper is being fed and jams at the same location then a senor, actuator or switch is bad, out of place or broken. If the device will not clear the jam light, completely power down the device, unplug from wall, let set about 30 sec. to 1 min. and then replug in and see if it reset. If the device did not reset then again a senor, actuator, or switch is out of position ( being held up in the paper path). If the paper does not feed at all then the feed section is the problem. Clean the feed tire (s) the rubber restorer or a high alcohol base cleaner. Listen to hear if the feed tire (s) are even turning. If feed is not turning then it could be clutch, motor or board problem.
Jan 04, 2009 | Sharp AL-800L Copier
Prints and scans fine, but copies are all black
Hold down the auto expsoure key the the lights will began to blink light copies then push it again to hold lighter expsoure.
Jul 18, 2008 | Sharp AL-1642CS Copier
Can not copy from tray/drawer, but get copy from multi-bypass tray
Regular copy paper that I got from the Staples. Same paper in the paper tray/drawer as in the multi-bypass tray. Thanks.
Jun 25, 2008 | Sharp AL 1631 Copier
False jam indicator
I had almost the same problem but the problem that I had was that after running 5 or more copies it would show a jam with no paper anywhere. And the only way to clear the jam was shutting the machine off and turing it back on.
What I found out was that the gate (flag) on the fuser unit was heating up and the gate (flag) was sticking a bit. (Plastic that close to the fuser isn't the best design)
Anyway, the only way to resolve this problem was replacing the fuser that had a new gate (flag) already installed.
You can replace the flag by itself also.
The way to see if your machine has the same problem, is if you get a jam and you open the right side door, push the black gate and see if it moves a little bit. If it was stuck then your machine is doing the same as mine was.
Good luck.
Hope this helps.
Mac
Feb 29, 2008 | Sharp AL-1641CS Laser Digital Copier
Sharp al 1655 false paper jam message,
Check that the paper feed roller is clean as if the roller slips it causes a late paper pickup jam but nothing will be in there also maybe a small torn piece in the machine some where. and check the fuser make sure that is it not stuck in there if no to all these then is will need a control board.
Thanks J
Nov 17, 2007 | Sharp AL-1655CS Laser Printer
71 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
