Question about Dryers
Our dryer does not completely dry cloths even with small loads they have to be run 2 or 3 cylcles but there seems to be plenty of heat.
  • 2 more comments
  • evergetis Sep 29, 2009
    Sorry the dryer is electric and yes the most common reason is the vent which has been cleaned.
    The unit is 2 yrs old and has been like this since the first year
  • Lynn May 11, 2010
    Is it an older dryer? The heating element may be going out. Most manufactures dont tell you this but the average heating element is only good for three years. It then starts loosing its heating ability. It is fairly easy to replace and no to spendy.
  • Lynn May 11, 2010
    Is it electric or gas? Have you cleaned your vent pipe lately?
    Problem Solver:
  • 13 Answers
The only other thing that i can think of is the thermal resistors. They control the heating element and the temperature it reaches, as well as shut it off and on. It sounds like the dryer is not reaching adequate or maintaining the temp it needs. It may be a safety item from the manufacturer
Posted on Sep 29, 2009
  • 67 Answers
You have an exhaust problem, you must take the venting apart starting from the dryer all of the way to the outside of your house, and clean it.
    Genius:
  • 1,466 Answers
Maks sure exhaust is fully flowing. plenty of air also filters are clear no fluff...good luck
Our Maytag Centennial Electric dryer is not cycling in auto dry mode but will in timer mode. Any thoughts?
There is a sensor that the clothes have to touch when the drum spins. This sensor measures how wet the clothes are. If you don't have enough of a load in the dryer then the sensor wont detect the dryness. Or it could be a bad sensor or connection or main board.
Nov 02, 2015 | Maytag Centennial 7.0 Cu. Ft. Super...
Timer goes to 99 minutes and clothes note drying all the way
Hi cayjr1
Clogged Vent
If your dryer seems to run forever, it could be because of a clogged vent or internal ductwork. Your dryer may have an automatic cycle that turns off the dryer when the clothes are dry. It does this with a special thermostat or moisture-sensing system.
Normally, this is what happens during an automatic cycle:
The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees.
When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.)
The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again.
This cycle continues until the clothes are dry.
But...if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
Heating Element
Your dryer's heating element may be partially burned out. If it is, your dryer still heats, but at such a low temperature that it takes three or four times as long to dry the clothes. If the element is partially burned out, replace the heating element. You can check for an ohm reading but will need to refer to the service manual for proper reading. This sometimes on the tech sheet located somewhere on the dryer. Usually between 9-13 ohms.
Cycling thermostat
Although this isn't a common problem, one of the thermostats that controls the temperature in your dryer may break and cause the dryer to heat poorly. If so, you need to replace it. The thermostat is usually a small, round, black device mounted to an oblong steel plate. The plate is mounted to the internal ductwork . This thermostat usually has four wires going to it. Check the 2 terminals that are opposite each other and are the closer together of the 2. These 2 terminals should have continuity. If not replace the thermostat.
Please take time to rate me
Bud
Oct 09, 2012 | Maytag Neptune MDE5500AY Electric Dryer
LG Dryer takes too long to dry clothes
Sure the outside vent is not clogged up? If so it will overheat and turn it self off and do a poor job of drying the clothes.
Also check and make sure that all of the heating elements are working properly.
Jul 09, 2017 | Dryers
Dryer takes a long time to dry. How long should an average cycle take?
The normal drying cycle for a normal load of clothes should be around a hour if you dryer is 220 Volts.
Chances are you have a Clogged Vent
This cycle continues until the clothes are dry. But...if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
Heating Element
Cycling thermostat
This is a Free answer, Please rate me.
Apr 11, 2011 | Maytag SDE4606A Electric Dryer
Dryer takes forever to dry clothes. now it will not dry clothing
Clogged Vent
Heating Element
Cycling thermostat
Apr 11, 2011 | Dryers
It takes 3 cylcles to dry clothes
Heating Element
Cycling thermostat
This is a free answer, Please rate me
Oct 04, 2010 | Miele T1302 Electric Dryer
LG dryer (model DLE3733W) takes forever to dry the clothes.
check your vent hose for a clog. If dryer dont vent clothes wont dry.
Aug 25, 2009 | LG DLE3733 Electric Dryer
Dryer has to be run repeatedly to complete one load. shuts off before clothes are dry. is this a sensor issue, and how is it replaced?
  • The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees.
  • When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.)
  • The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again.
This cycle continues until the clothes are dry. But…if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
Aug 05, 2009 | Dryers
Dryer doesnt dry clothes
I suspect you have a blocked air vent. A blocked vent will definitely extend your drying time. You may even find yourself having to run a load twice to get it fully dried. One way to confirm this is to disconnect the vent hose from the back of your dryer and dry one load with the machine venting directly into your laundry room. If that load dries quickly then you know the problem is a blocked vent. Most vents get blocked by lint near their exit to the outside. There's usually a screen at this location to prevent small animals from crawling into your house. Often this screen gets clogged with lint. Most vents are designed to allow removal and cleaning of this screen from the outside.
Jun 06, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Clothes dryer not getting hot enough to dry in a good time frame
I have the same issue with my DLG3788W dryer. It seem to have only one setting for heat, rather than multiple heat settings. What can I do or do I have to call someone to repair this.
Oct 03, 2007 | LG DLE0332 Gas Dryer
Dryers Logo
64 people viewed this question
Top Dryers Experts
