Question about Brother Office Equipment & Supplies
I have brother tn 350. it is saying drum error.
I have brother tn 350. it is saying drum error. i take the cartridge out slide the blue tab and still same thing. what else do i do.
maria
  • 4 Answers
Depending how old the drum is, you may have to replace it.
If its new then take it back to were you bought it and tell them its faulty
Posted on Sep 29, 2009
Change drum
You need to go buy a Brother DR-350 drum unit cartridge. The drum unit is the thing that the toner cartridge (TN-350) clicks into. Pull out the drum/toner unit and separate the two halves. Place your TN-350 into the new DR-350 cartridge and put back in the printer.
Jan 18, 2010 | Brother IntelliFax-2820 Laser Fax
Having replaced cartridge now says drum error, remove drum and slide blue tab. How do you remove drum>
The drum is the piece that holds the toner cartridge. Once you remove it you'll see a pale blue tab at the rear of the drum unit. Slide it side to side a couple of times to clean debris from the drum area.
Dec 08, 2009 | Brother DCP 7010 Multifunction Laser...
REPLACING A CARTRIDGE
you take the toner and drum assembly out of the printer, set it on a level surface, press the blue lever on the left side rear, and lift and remove the toner. Remove any packing material from the new cartridge, set the front toward the drum in first and lower the rear down until the blue lever clicks. Re-install the assembly into the printer...good to go!
Sep 15, 2009 | Brother MFC-7820N Printer
Toner for fax machine 2920
If your machine is a Brother Intellifax 2920, it does take a TN-350 toner cartridge. Maybe you were wanting to replace the Drum Unit instead, DR-350. I'll bet this info is useful, yes?
Jul 03, 2009 | Brother FAX-2920 Plain Paper Laser
Brother 4070 CDW Drum Unit Error
The green tabs that you have to slide are under the color cartridges, so remove the three color cartridges and you will see three green tabs, to slide the tab across the wire you have to first open the translucent plastic wire cover, then slide the green tab across the wires and return it to it's original position, close the wire covers, replace the color cartridges, and reassemble the printer. All the Best
Jun 11, 2009 | Brother HL-4070CDW Printer
Printer catridge
If you just want to REPLACE the toner cartridge, open the front door and jiggle the combined toner & drum units out. push down on a blue tab on the side to release the TN-350 toner cartridge and lift it out of the DR-350 drum cartridge. If you have the toner cartridge out and want to refill it you7rself, DON'T. You can buy toner with about the right size grains, but Brother uses toner with grains that are much smoother and rounder than that aftermarket stuff. The toner is constantly stirred during the print process, and the rough-grained aftermarket toner puts up so much resistance that it often breaks a gear in the body of your MFC. Brother usually doesn't cover that one in their warranty.
Feb 05, 2009 | Brother MFC-7820N Laser Printer
Brother Printer MFC-7420
Open the front cover and take out the toner/drum unit. On the top of the drum unit you will see a blut tab that you can slide side to side. Do this 10+ times and this should fix your issue. Make sure to put the blue tab back in the original start position which is believe is to the left on that model.
Sep 06, 2008 | Brother MFC 7420 All-In-One Laser Printer
DRUM ERROR
  1. Open the front cover.
  2. Press the Options key on the control panel.
    The display will show "REPLACE DRUM - 1.YES 2.NO".
  3. Press 1 to reset the drum count.
  4. Close the front cover.
It happens because Brother decide that we are morons and cannot figure out when a drum is dead and so they make the printer refuse to work after a certain amount of time. This resets their dummy counter.
Jul 07, 2008 | Brother MFC-7820N Printer
Toner/drum problems
This seems to happen some of the time. Brother has an FAQ for this:
1. Verify the toner cartridge is installed correctly by following the
steps listed below:
a. Open the front cover.
b. Lift the drum unit slightly and pull it out. Place the drum unit on
adrop cloth or large piece of disposable paper to avoid spilling and
scattering the toner.
c. Remove the toner cartridge from the drum by holding down the lock
lever (blue tab) on the left side of the drum unit and lift the toner
out.
*Handle the toner cartridge carefully. If toner scatters on your hands
or clothes, immediately wash it off with cold water.
d. Gently rock the toner cartridge from side to side five or six times
to distribute the toner evenly inside the cartridge.
e. Place the toner cartridge into the drum (be sure it clicks into
place).
f. Clean the primary corona wire inside the drum unit by gently sliding
the blue tab on the top of the cartridge from right to left several
times. Return the blue tab to the home position before reinstalling the
drum unit assembly.
g. Reseat the drum unit into the machine.
h. Close the front cover.
2. If the message "Toner Life End" continues to appear on the display,
contact Brother Customer Service at 1-877-Brother (276-8437) Monday
through Friday, 9:00am - 7:00pm EST, excluding holidays.
May 12, 2008 | Brother MFC 7420 All-In-One Laser Printer
410 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
