Question about Kodak EASYSHARE V1253 Digital Camera
Shoot button and spring fell off along with zoom tab - have parts but wont stay attached - camera was in hard shell case
  • 101 Answers
Call 1.800.235.6325
Posted on Sep 29, 2009
Can battery compartment be repaired when tabs are broken off which hold lid down?
possibly...if it is the body where the tabs are broken off the manufacturer (Olympus) might be able to replace the body shell. I'd check with them.
Aug 16, 2014 | Olympus SP-600UZ 12MP 15x OPT Zoom Digital...
My OLYMPUS C5060 WIDE ZOOM digital camera fell in to the sea, in its pouch, but still got slightly wet. Local service agents answer was: buy a new one. How can I open the camera? I have removed all screws...
Having been exposed to salt water this long they were right.There is probably a pin you need to remove with the back off holding the flash.It may have to be pulled out with needlenose pliers or it may be springloaded and need one of the ends pushed down.Spring loaded best image I can give.
'--=======--' The two ends are solid.The pin is spring loaded pushing out.The smaller tip is the part which pulls open and is spring loaded.The = is the pin main body.If you have any questions or need more help,just comment here and I will get an autolink to your post and reply ASAP.Greg
Nov 28, 2010 | Olympus Camedia C-5060 Wide Zoom Digital...
I'm not able to set the digital zoom
You can turn on/off the digital zoom. While on shooting mode, press MENU button and go to left end tab menu items. Navigate to "Digital Zoom" and select the desired¡red setting: ON or OFF. Remember that digital zoom can't be used if the screen is turned off.
Jul 15, 2009 | Canon PowerShot A620 Digital Camera
Top loading #110.29842990 Outer shell came
The outer case catches under the frame across the front and there is a tab on either side on the frame near the back these tabs go into a slot in the flange on the bottom of the case. You may need to loosen the control console to do this. 1. Disconnect the power. 2. Remove two screws, one at each top corner on rear of console. 3. Push a putty knife under the front of the console near the corner. You will feel the resistance from a spring steel clip. Push, firmly toward rear of machine. clip will release and console will be loose. Repeat at other front corner of console. 4. make sure outer case is hooked under front of frame. 5. Put case on both tabs(check at rear corners on back of machine to assure that back panel and case corner are in the modling that aligns the two. This is sometimes like a wrestling match. Take your time it can be a test of your patience. It is helpful to see diagrams available at www.sears.com under Parts direct. Find your model number and an exploded view is available. Good luck.
Jun 30, 2009 | Kenmore Washing Machines
Zoom button
Some time Zoom switch knob got broken internally and resulted the problem as you have with this camera.
You can replace upper part of camera with following part number..
A-1246-250-A CABINET UPPER(240),BLOCK ASSY
It is an easy job to replace above part.
Part available in Parts Store for $24
Feb 02, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
Olympus 8080 C 8080 wide zoom
It may have jumped a tooth, something like a car timing chain. The Zoom in this camera is a barrel that has 3 cams that rides inside another barrel that has "tracks" for the cams. The motor rotates the the outer barrel via gear teeth, forcing the inner barrel to extend or retract. There is a tab on the gear teeth that might index the position of the zoom lens. If this tab is in the wrong position, if the gear jumped a few teeth, the camera may not know where the zoom lens is in relation to the inner focusing lens, and cause the "zoom error" If that is the case, I can help you get it back into position. This is a theory, but does explain the tab on the gear and the constant zooming.
May 27, 2008 | Olympus Camedia C-8080 Wide Zoom Digital...
Zoom broke
Solution: Procedure for setting Digital Zoom PowerShot A520
Digital Zoom When the LCD monitor is on, images can be zoomed with the combined optical and digital zoom functions as follows (figures are approximate): 5.7 times, 7.1 times, 8.9 times, 11 times, and 14 times 1. Press the <DISP.> button to turn the LCD monitor on.
2. Turn the shooting mode dial to any Shooting mode except for stitch_assist_icon_a70.gifor movie_icon_a70.gif.
3. In the [ rec_icon.gif(Rec.)] menu, select digital_zoom_icon_a70.gif(Digital Zoom).
digital_zoom_menu.gif 4. Select [On] using the left_arrow.gifor right_arrow.gifbutton and press the <MENU> button.
5. Press the zoom lever toward tele_icon_a70.gifand hold it.
  • The lens will zoom to the maximum optical telephoto setting and stop. Release the lever and press it toward tele_icon_a70.gifagain to further zoom the image digitally.
  • Press the lever toward wide_icon_a70.gifto zoom back out.
digital_zoom_lcd_a70.gif 6. Shoot the image.
  • Shooting procedures are the same as for the auto_mode_icon_a70.gifmode.
  • The digital zoom cannot be used when the LCD monitor is off.
  • images become coarser the more they are digitally zoomed.
  • Since camera shake may become a factor when using the digital zoom, the use of a tripod is recommended.
  • Digital Zoom is disabled when the [Postcard Print Mode] is selected as a image quality setting.
IF this fails, your camera is in need of service.
Dec 30, 2007 | Canon PowerShot A520 Digital Camera
Opening a DMC-FX01 case
most electronic packages today use a combination closure of screws and tabs that interlock at mating points. It appears that you have found the latter method and are "stuck". No, I have not opened one of these, but I would try to determine where the mating tabs are located. Sometimes you can "feel" these tab locations by slight bending of the plastic body. Where it is stiffest to bend, that is usually where a tab is located. Also, sometimes mating parts use an additional "slide-locking" method where the mating parts must first slide laterally to unlock. In worst case if a tab breaks after repeated attempts, you can re-attach the tab using super glue and then (after drying) use a solder iron to make a few "spot" welds to mate the plastic tab by melting it to the shell body.
Jul 29, 2007 | Panasonic Lumix DMC-FX01 Digital Camera
Kodak EASYSHARE V1253 Digital Camera Logo
80 people viewed this question
Top Kodak Cameras Experts
Jerry Greenberg
Jerry Greenberg
Computer Links
Are you a Kodak Camera Expert? Answer questions, earn points and help others
