Tec RadiantWave Grill
Problem for Tec RadiantWave Grill
TEC grill went BOOM and caught our house on fire.
By Jimmyw71 on Sep 29, 2009
On Sunday, Sept 27, our TEC grill failed. We didn't know about the breaking screws. It had apparently flared up quite a few times, but we thought that it was just the meat catching when we opened the top up. On Sunday we were cooking a pork loin at about 33% gas levels across all burners. This should've taken about 30 minutes but we checked it after ten and found the loin was completely burnt on the outside and raw in the middle. We've been having bad luck with BBQ and couldn't figure out why.
So we were going to put some steaks on but before that we looked and noticed the temp gauge on the lid was showing over 800 degrees!!! It was off the charts! My friend also noticed some flames leaking out the lid on the right side of the grill. He quickly turned all the knobs off and BOOM! Something blew and propane started venting freely from the tank. It shot a column of fire about 4 feet wide that engulfed the grill and rose to about 10 feet hitting the bottom of our back porch. It blew nearby floodlights and our porch started to burn.
Extinguishers couldn't put it out. I screamed for him to call 911 and get the fire department. I told him to run inside in case the propane tank exploded. The flames were intense! I ran to a hose to try to put out the fire and was finally able to get it under control. What was left was a twisted, mangled grill and a LOT of fire damage to our home. I'm talking with an attorney today after she sees the damage. Luckily, no one was hurt or killed. Just a LOT of singed hair.
I'm very angry that TEC isn't correcting this problem that's been plaguing homeowners for two years and the information that people have had did not bring some kind of recall at Lowe's. Needless to say, I can't repair the grill nor would I want to. I now need to rebuild one side of my back porch and re-run electrical and cable connections to melted flood lights. Yes, they actually melted in the heat.
It appears to be the same issue I've read about in the 9 pages of this forum. Thank you so much for having this thread running. I hope that this helps others out there.
Popular Solutions for Tec RadiantWave Grill
Questions and Unsolved Problems for Tec RadiantWave Grill
Do you recommend Tec RadiantWave Grill?
Answer
Answer
grill ignites (LPG)but the the rear burners don't appear to be lit
Answer
instructions on how to put up a manner tent
Answer
heater, air not working and car at times over heat if idle
Answer
It looks like the Sterling I Model is no longer available. Is there no way to get this grill... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Grills and... Experts
Top Range & Oven Repairmen
(972) 859-0929
Honest, Dependable, Available &...
Accurate Appliance Repair & Parts Supply
(423) 303-3784
Oven and Range parts delivered overnight...
 Appliance Parts Pros.com
Best Grills and Smokers
Recommended by Owners
See more>>
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
