Dell 942 All-In-One InkJet Printer
Problem for Dell 942 All-In-One InkJet Printer
Dell Printer IO942 not communicating with laptop
By carmela_bela on Sep 29, 2009
Dell Printer IO942 not communicating with laptop -I tried switching out usb cable and still unable to connect to this printer. When I disconnect and reconnect usb cable I do not get found new hardware pop up. I swopped-out printers and when I plugged in USB for new printer my laptop immediately found new hardware - is the problem with the Dell IO942 printer and is it bad?
Best Solution
posted on Oct 01, 2009
Very Helpful)
john_yap
Rank: Guru  Dell StaffDell Staff
Rating: 96%, 57 votes
You've tried to uninstall and reinstall the printer driver of your printer. But still no luck. The printer still won't print. Or it would say printing but it won't finish printing.
You can try these steps:
1.Check if the firewall is blocking any printer services
2.Check what port the printer is using (reenable the bi-directional support) and if it's on online mode
3.Disable all the firewalls
4.Uninstall the printer driver and software
5.Delete any items under the ff keys:
HKLM\System\CurrentControlSet\Control\Print\Environments\Windows NT x86\Drivers\Version-2
HKLM\System\CurrentControlSet\Control\Print\Environments\Windows NT x86\Drivers\Version-3
HKLM\System\CurrentControlSet001\Control\Print\Environments\Windows NT x86\Drivers\Version-2
HKLM\System\CurrentControlSet001\Control\Print\Environments\Windows NT x86\Drivers\Version-3
Optional***
6.Delete any non default items under the ff keys:
Note: ONLY THE NON DEFAULT ITEMS SHOULD BE DELETED
HKLM\System\CurrentControlSet\Control\Print\Monitors
HKLM\System\CurrentControlSet001\Control\Print\Monitors
Default items are as follows:
AppleTalk Printing Devices
BJ Language Monitor
Local Port
PJL Language Monitor
Standard TCP/IP Port
USB Monitor
Windows NT FAx Monitor
7.Delete any items under the ff keys:
HKLM\System\CurrentControlSet\Control\Print\Printers
HKLM\System\CurrentControlSet001\Control\Print\Printers
8.Completely remove drivers by doing the ff: (Option for comm failure because of the upgrade from xp to vista)
Ensure there are no documents in queue.
Disconnect printer’s USB cable.
Click the Start pearl, then click All programs, Printers, Dell xxx (where “xxx” is the printer model number) and then Uninstall. Complete the uninstall utility.
From the start search box type spool and press .
The spool folder located at c:\windows\system32\spool opens.
Rename c:\windows\system32\spool\drivers\w32X86 to c:\windows\system32\spool\drivers\backup.
Rename c:\windows\system32\spool\prtprocs\W32X86 to c:\windows\system32\spool\prtprocs\backup.
9.Restart the computer.
10.Check th services status
Start-Run- Type Services.msc and Click on Open
You will see long list of services
You need to make sure following 4 Services are set to Automatically start
Remote Procedure Call RPC
Remote Procedure Call RPC Locater
LexBce Server
Print Spooler
11.Reinstall the latest printer driver
good luck. :)
Was this helpful?
Yes
No
1 person thought this was helpful
Asker's Testimonial
" Thanks for the great advice. " - carmela_bela
Solution #2
posted on Sep 29, 2009
Very Helpful)
noobcybort
Rank: Wiz
Rating: 85%, 65 votes
Hello there !
Do you have its installation software? pls  install it again make sure the printer is not on .
After the  software installation is over  the  software will search for the added printer so the printer should be on at this time .
If found the printer will be installed and ready to use
If  no change  the printer registry (circuit board ) might be faulty
good luck
Was this helpful?
Yes
No
Asker's Testimonial
" Thanks for the quick response. I do not have the CD to reinstall printer software but I have reinstalled the driver from website. " - carmela_bela
Solution #3
Very Helpful)
cene765
Rank: Guru  Computers & Networking  Expert
Rating: 88%, 578 votes
Try to reinstall the driver or change the USB cable.In worst case there is a problem in logic board assembly in your printer
Was this helpful?
Yes
No
Asker's Testimonial
" Thank you for the quick response, I did change the USB cable so your answer confirmed my suspicions that it is a problem w/logic board in printer. " - carmela_bela
Popular Solutions for Dell 942 All-In-One InkJet
Questions and Unsolved Problems for Dell 942 All-In-One InkJet
Do you recommend Dell 942 All-In-One InkJet Printer?
Answer
Answer
I cannot activate my memory card manager for the dell aio 942 printer.
Answer
where can I get a replacement paper tray? One of the little plastic pieces that holds it in place... (More)
Answer
system says dell aio 942 driver not installed, when i use wizard to install or use disk to install... (More)
Answer
unable to set up home network to print to this printer from a wireless laptop
Answer
My dell 942 printer is printing white lines and/or blurred printing. Have cleaned the cartridges and... (More)
Describe your Printers problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Printer Experts
Top Printer Repairmen
in Beverly Hills, CA
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(918) 583-5483
Elite printer Services, Inc. is a full service HP...
Elite Printer Services
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
close
Add to My Products
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
Step 1: Select a category & subcategory
Appliances Cameras Cars Computers Electronics Home Audio TV & Videos Tools
Appliances Cameras Cars Computers Electronics Home Audio TV & Video Tools
Step 2: Select a product and click on add
I can't find my product
select
Cancel
close
Success!
Add another product
Close
close
Save This Product
Enter your email address
We will not share your email. Privacy Policy
I agree to the FixYa Terms of Use
Send to friends
Your name:
Your email:
Your friends email addresses: (e.g. Julie@email.com)
(Separate email adresses with commas)
Message:
Cancel
