Question about Vinten Photography
How do you balance the head? - Vinten Photography
  • 25 Answers
Conect a large weight to underneath the apex of the tripod ...more weight more stability
Posted on Oct 02, 2009
How do i know for sure if it is a 360 or a 318?
With out pulling the heads or sump and measuring the bore or stroke. A 318 is internally balanced and a 360 is externally balanced.
The harmonic balancer on a 360 is dished and a 318 balancer is flat.
The fly wheel on a 360 has a weight on it and a 318 does not have that weight.
May 09, 2015 | Cars & Trucks
What is the torque spec for a 2003 jeep wrangler 2.4 connecting rods
  • ENGINE 2.4L
DESCRIPTION
N·m
Ft. Lbs.
In. Lbs.
Balance Shaft Carrier to Block-Bolts
54
40
Balance Shaft Gear Cover-Double Ended Fastener
12
105
Balance Shaft Sprocket- Bolt
28
250
Balance Shaft Chain Tensioner-Bolts
12
105
Balance Shaft Carrier Cover-Bolts
12
105
Camshaft Sprocket-Bolt
101
75
Connecting Rod Cap-Bolts
54 +1/4 turn
40 +1/4 turn
Crankshaft Main Bearing Cap/Bedplate - M8 Bolts
34
250
M11 Bolts
41 +1/4 Turn
30 +1/4 Turn
Crankshaft Damper
136
100
Cylinder Head Cover- Bolts
12
105
Flex Plate to Crankshaft
95
70
Flywheel Mounting Bolts
81
60
Engine Mount Bracket Right-Bolts
61
45
Exhaust Manifold to Cylinder Head-Bolts
23
200
Exhaust Manifold Heat Shield-Bolts
12
105
Intake Manifold - Lower -Bolts
28
250
Oil Filter
20
15
Oil Pan-Bolts
12
105
Oil Pan Drain-Plug
27
20
Oil Pump to Block-Bolts
28
250
Oil Pump Cover Plate-Bolts
12
105
Oil Pump Pick-up Tube-Bolt
28
20
Oil Pump Relief Valve-Cap
41
30
Spark Plugs
28
Timing Belt Covers - Front Covers to Rear Cover-Bolts
12
105
- Rear Cover-Bolts
12
105
Timing Belt Tensioner Assembly-Bolts
61
45
Sep 27, 2014 | Cars & Trucks
What is wrong with my dog
bring her to some vet. There might be something inside her ear/head..humans vomit and is out balanced (dizziness) when the head is wounded or bruised.
Nov 14, 2013 | Sewing Machines
Unable to pull the harmonic balancer
need a harmonic balancer pulley you can rent them at your local auto part store
Feb 20, 2013 | 1999 Cadillac DeVille
Record player head goes a few songs in on start up
not sure what you mean Ryan ... do you mean the arm swings to the middle of the record when you set it down in the groove? if so the arm is out of balance and you need to balance the weight forward. if there is no weight adujustment then your works off a spring and there a million ways to adjust that. Try balancing a penny on top of the head where the cartridge is to hold it done, if this temporarily solves the problem then teh arm is out of balance.
Feb 14, 2012 | Audio Players & Recorders
I have a 2002 aztek in the shop with a leak in the intake manifold gasket. the mechanic wants to also remove the heads and check and balance them. this increases the bill by about 500 bucks. should this be...
never heard of check and balance a head. I would ask him what he's trying to fix. What were your symptoms/reasons for pulling the intake manifold?
Sep 28, 2010 | 2002 Pontiac Aztek
I need a how to to change harmonic balancer for 1995 nissan maxima. step by step
First remove right front tire and support vehicle with a jack stand. Remove splash guard lower portion near the harmonic balancer. Remove all drive belts. First remove the A/C alternator belt. Loosen the 14mm bolt at the front of the belt tenioner and then loosen the tensioner bolt (it is the one that stands out, you use a socket on it.). The power steering adjuster bolt with be gained from the bottom. It has a 12mm bolt head on it. You will break the jamb bolt loose first and then loosen the adjusting bolt. Pull down on the belt the help move it after you've loosened it some.Then remove harmonic balancer bolt (19mm).If the harmonic balancer will not slide off the crankshaft then use a two finger gear puller. Place the harmonic balancer bolt back in the crankshaft but do not tighten it. Leave it about a half inch from being all the way in. Next place the puller onto the harmonic balancer (one finger on each side securely press into the belt groove. The center puller bolt will rest against the harmonic balancer bolt head. Tighten the puller bolt and make sure the harmonice balancer bolt does not turn. The balancer should come off at this point.
Aug 26, 2009 | Nissan Maxima Cars & Trucks
SHAKE
Steering head bearings not correctly tightened. Play in forks, poorly balanced wheel, too much rake... shrug.
Nov 20, 2008 | 2005 BMW R 1100 S
Photography Logo
125 people viewed this question
Top Vinten Photography Experts
pontelemon
pontelemon
Are you a Vinten Photography Expert? Answer questions, earn points and help others
