Question about Xerox Phaser 7400/DXF Laser Printer
I have a Phaser 7400DT printer with no display and the red status indicator light is red. I have rebooted it several times and still nothing. Any suggestions?
4 Suggested Answers
duane_wong
  • 6826 Answers
SOURCE: after printing several hundred sheets
Well, if the toner light is on, you're probably out of toner and the only reason it ran, was because it was low but not completely depleted.
Try new toner drum off of Ebay or Amazon for the best prices for your brother printer.
Posted on Jul 05, 2010
wheatlandsvc
  • 1110 Answers
SOURCE: I have an old Xerox XD155df printer that needed a
Press these keys in sequence and rather quickly like within 4 seconds.
Press
"C" Clear, then the far left button which is the exposure mode button, then C again then the far left key again.
So in short form: C,far left, C, far left
If done properly the display should go blank.
Now key in 24 as if you were making 24 copies.
Now press the print button.
Now key in 7 as if you were making 7 copies.
Press Print again.
You should now have flashing 000 in the display.
Press C several times to exit the mode and your drum light should be gone.
Good Luck and Thank You for using Fixya.
Posted on Jan 03, 2011
  • 9 Answers
SOURCE: when the red light blinks
The blinking toner cartridge is low. Order a new toner cartridge. You can temporarily improve print quality by redistributing the toner. See "Redistributing Toner" on page 5.2
from the manual online as pdf: http://download.support.xerox.com/pub/docs/6110/userdocs/any-os/en/Guide_XP.pdf
Posted on Apr 06, 2011
Xerox phaser 7800 rebooting all time
Most likely cause is corrupted software which requires an alt boot which requires the Xerox laptop to reinstall.
Apr 09, 2016 | Xerox Office Equipment & Supplies
My printer wireless indicator is flashing red and I cannot print
The flashing status of the WiFi light on the printer indicates that it's either trying to connect to a wireless network or it has gotten disconnected from your wireless network.
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Reboot your pc. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, check the WiFi light status. Try to print again.
You may also refer to this article: Wireless & Network Communication Issues with 2008 Lexmark Inkjet Products
Jul 05, 2011 | Lexmark Z2420 Printer
My CLP315 WON'T PRINT - IT HAS THE RED LED LIGHT ON. HAVE CHECKED THE PAPER LEVEL, WASTE TONER CARTRIDGE NAD REBOOTED SEVERAL TIME BUT RED LIGHT REMAINS ON
The problems you checked are indicated by a blinking red light (it denotes minor errors). A solid red light usually means that one of the toners is exhausted. If you look in the task bar, there's a little blue S; double click on this to launch Smart Panel, our monitoring software. It will tell you the specific error message. If one of the toners is showing empty already, are you sure this wasn't a used model or possibly a display unit that people would have been printing on?
Nov 27, 2010 | Samsung SAM CLP315 COLOR LASER PRINTER
Xerox Phaser 8200 goes through post then hangs.
Sounds like a RAM problem. Go to the back of the machine, You will see  2 large, thumb Screws, Twist them about half a turn and remove the main board. Remove and reinsert the memory stick. If that does not fix it the main board or the electronics module has probably failed.
Mar 03, 2010 | Xerox Phaser 8200 Laser Printer
My xerox phaser 8550 displays as offline. how do i get it up and ready to print?
First you need to find out why its offline, it could be the printer is off or the connection to the network or computer is unplugged or loose or just a wacky problem when there is a power outage from time to time or you changed some settings and never reboot your computer.
Try going to Start > Printers and Faxes > Right click on the Phaser printer to check the status there and right click > properties >Ports tab > select your printer and then configure port. a port settings window should open which displays the printers name and IP address. You can also find the IP address on the control panel on the printer scroll down to Information > Printer Identification and the IP address and other printer info should be displayed there.
Copy the IP address and paste it in the browsers address bar and check the status of your printer there, check if there are any jobs waiting to print, try clearing all of them, check the status page to see if there are any issues such as low ink, etc.
After running thru trouble shooting options and help menus there if all else fails, restart your printer by powering down, do the same for your computer and restart them both. I've had these issues before and sometimes just a reboot will correct itself.
Sep 09, 2009 | Xerox Phaser 8550/DT Thermal Printer
WHAT DOES RED STATUS LIGHT MEAN WHEN IT STAYS ON ALL THE TIME
It can mean several things. Try cleaning the corona wire on the drum unit.(the blue plastic slider on the drum).
Jun 17, 2009 | Brother HL 5250DN Laser Printer
A red light all the time on xerox phaser 6110.
I think I might know what this is. Mine did the same and I removed the waste toner cartridge (grey L shapped unit to the right of the colour cartridges under the front panel) I noticed it was quite full but a rocked it from side to side to settle the contents (be carefull as they can come out) and when refitted the light stayed off when powered up. I'm not sure if this waste cartridge needs to be replaced or you can simply tip it out into a bin, but I'll try that tomorrow when I can empty out side.
Jan 24, 2009 | Xerox Phaser 6110 Laser Printer
HL-5140 Brother laser printer red status light remains on.
The red lite indicates one of the following needs to be looked at:
Cover open (Front cover) Close the front cover.
Cover open (Jam clear cover) Close the jam clear cover of the fuser unit.
Memory full - Press the go button.
Print overrun - Press the go button.
Clean drum unit - Clean the corona wire.
Jan 15, 2009 | Brother HL 5140 Laser Printer
Xerox Phaser 6110 - what does continuous red light mean ?
Lemmor, without being rude it sounds like you know nothing about this machine at all.
The printer version of this machine has 5 lights in total. 4 of them refer to the toner carts (flashing means toner low, on solid means run out) the other light (the status light) can mean many things. The most common problem people overlook with red status light is that the waste toner bottle is full and needs replacing. It can mean lots of other things depending what colour it is and whether it is flashing or not. These can all be found in the user manual, or if the status monitor has been installed (usb connection) it should show on the PC screen. With a network install, you can browse to the machine using it's IP address to see the error message.
Feb 02, 2008 | Xerox Phaser 6110 Laser Printer
Xerox Phaser 7400/DXF Laser Printer Logo
82 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
