Question about Tadpole SPARCLE 650SX (D65S-80-D-09-2G) PC Notebook
Trying to see if wireless is turned on. I must verify
Trying to see if it is turned on. I must verify it is disabled. I checked eeprom, Network Setting, and Utilities and didn't see anything about wireless connections. Do I really have one?
  • 50 Answers
Go to hardware section and look under network adapters to see if you have a wireless card installed. Default setting if a card is installed is on.
Posted on Sep 29, 2009
Why my wifi disabled to connect
To verify the wireless network connection status, please go to the Network Connection Window. For Windows XP, Click on Start. Click on Run. Enter "ncpa.cpl" and click OK. For Windows 7 or Windows Vista, go to "Search programs and files" box. Enter "ncpa.cpl" and hit the Enter key.
If you see the wireless network connection icon is disabled in the Network Connections Window, you may double click on it to enable the connection. Should it is still disabled an no way to be enabled, you may have a AntiVirus software (for example, Kaspersky, ZoneAlarm, Trend Micro Internet Security...etc) installed in your computer and it disabled the wireless connection.
You may completely remove the antivirus software from your computer and restart the computer. Check the wireless connection can be enabled. Then you can re-install the antivirus software.
Jan 21, 2013 | TP-LINK Tenda W311R WirelessN Router AP...
Tip
BASIC Wireless Troubleshooting Steps in Windows XP
<p><b>BASIC Wireless Troubleshooting Steps:</b><br /> <p><b>Verify that the network adapter is being seen by the operating system:</b><br /> <br />Check Microsoft Windows Device Manager and look for an icon that appears as Network Adapters and see if the network card listed in Mini-PCI information table is installed:<br /> <ol> <li> Right-click the My Computer icon and select Properties. <li> Click the Hardware tab and press the Device Manager button. The network card should appear under Network Adapters.<br /><b>Note:</b> If the card has a exclamation mark over a yellow background, then this is an indication that the card is experiencing a problem. Go to Driver download step 5. </li></ol> <p><b>Verify that the radio is enabled:</b><br /> <p>It is possible to disable the transmitter of the wireless card without Device Manager showing any problems. Most wireless cards will put an icon in the system tray (the line of icons in the lower right corner of your screen). Right click this icon and it may have a menu option to enable/turn on the wireless radio.<br /> <p><b>Check for association to an Access Point:</b><br /> <p>If you double-click the previously mentioned system tray icon, the configuration utility of the wireless card will appear. This utility will be able to show the status of the wireless card, showing what channel the card is using and what signal strength is being received. It may be difficult to maintain a connection if signal strength is low due to either interference or distance. For example, interference can be caused by 2.4GHz cordless phones, other Access Points in the area, and physical structures such as load bearing walls or metal partitions.<br /> <p><b>Note:</b> The utility can be used to configure the wireless card settings, but if using Windows XP Zero Configuration or Access Connections, you will need to use those programs to actually configure the wireless card as they will overwrite the setting of the utility.<br /> <p><b>Check the SSID (the Network name of the wireless network you are trying to connect to) and security settings:</b><br /> <p><b>Note:</b> The SSID and WEP key are case sensitive.<br /> <ul> <li> The connection will fail if the SSID is incorrect. <li> The most common security setting is the use of a WEP key. This involves using a 5 digit alphanumeric key for 64bit encryption or 13 digit alphanumeric key for 128bit encryption. Some systems will only allow a hexadecimal (0-9, A-F) key of either 10 (64bit) or 26 (128bit) characters. It may be necessary to convert your alphanumeric key to a hexadecimal one in order to connect properly. </li></ul> <p><b>Note:</b> It may also be necessary to temporarily disable the security features in order to check for basic connectivity.<br /> <p><b>Verify that the most recent driver for the adapter is installed.</b><br /> <p><b>Verify the hardware compatibility with the Access Point:</b><br /> <p>Often, vendors of Access Points will add features to improve their product. Unfortunately, these extra features are not always compatible with all hardware. Consult the product documentation for the Access Point about the possible need to disable these features. Also, there are often new firmware updates to an Access Point that may solve some issues. Again, consult with the Access Point manufacturer for updates.<br /> <p><b>Verify that TCP/IP (or other appropriate protocol) is properly installed:</b><br /> <p>To check this: <br /> <ol> <li> Right-click the My Network Places icon and select Properties. The wireless card should be present as Local Area Connection. <li> Right-click the appropriate Local Area Connection and select Properties. In the Properties window, make sure that the Internet Protocol (TCP/IP) is installed. <li> If TCP/IP is not installed, click Install, click Protocol, and then click TCP/IP. <li> Once installed make sure that Obtain an IP address automatically, and Obtain DNS server address automatically are checked (if using DHCP). To verify this, highlight the TCP/IP protocol, and select Properties. </li></ol> <p><b>Note:</b> Only use a Static IP Address if your network/Service Provider requires one. <br /> <p><b>Verify the TCP/IP address:</b><br /> <ol> <li> Click Start, select Programs, select Accessories, and then click Command Prompt. <li> Type the command, ipconfig. This will list the IP address for the local machine. <li> If this returns a 169.x.x.x or 0.0.0.0 address, then type the following commands, ipconfig /release and then ipconfig /renew. You should then receive a TCP/IP address appropriate to your network, along with a Default Gateway address. <li> Try to communicate with it by typing this command ping x.x.x.x where x.x.x.x is the IP address of the Default Gateway. <li> If this does not give a reply (see the example in step 9) or you did not receive a TCP/IP address, go to the next step.</li></ol> <p><b>Ping the loopback address:</b><br /> <ol> <li> Click Start, select Programs, select Accessories, and then click Command Prompt. <li> Type the command, ping 127.0.0.1. This will send a message to the internal network stack on the machine. You should see a response like this: </li></ol> <p><b>Pinging 127.0.0.1 with 32 bytes of data:</b><br /> <p>Reply from 127.0.0.1: bytes=32 time&lt;10ms TTL=128<br />Reply from 127.0.0.1: bytes=32 time&lt;10ms TTL=128<br />Reply from 127.0.0.1: bytes=32 time&lt;10ms TTL=128<br />Reply from 127.0.0.1: bytes=32 time&lt;10ms TTL=128<br /> <p>Ping statistics for 127.0.0.1:<br />Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),<br />Approximate round trip times in milliseconds:<br />Minimum = 0ms, Maximum = 0ms, Average = 0ms<br /> <p><b>Verify that the hardware is functioning using diagnostics. </b><br /> <ul> <li> Run diagnostics on the wireless card. </li></ul> <p><b>Install latest Service Packs for Operating System or Network Client:</b><br /> <p>It may be necessary to install Service Packs for either the operating system or for any additional network clients that may be installed. Contact the software vendor for these updates which are usually free downloads.<br />
on Jan 24, 2011 | Computers & Internet
I keep having this problem with my wireless saying validating Identity. And I can not connect to the inernet
Hi
for resolving your problem Click the network properties and select wireless properties,go to "Wireless Networks" tab and then to Properties of the chosen wireless network you are trying to connect to. Then go to "authentification" tab and untick the box saying "Enable IEEE802.1x to the availiable network" and that should solve your problem
Chher
Jun 28, 2011 | D-Link DIR-615 Wireless Router
My asus will not detect a wireless connection
Hello
check if the led is turned on,if the lead is turned on make sure that the network card is not disabled . check it under network connections and see if it is disabled, enable it.
what does it say when you are trying to scan for the wirless netwroks..
it should either say A) No wireless were detected in the range ... if you get this message it means that you wifi is working fine on the laptop .. check if you can see the wifi turned on the router .
Windows is not configured for this device( or something like that ) .. if you get such kind of message it means you have not enabled WZC(wirelesss zero configuratioin).. for that click on start -- Right Click on MyComputer -- Manage -- Services -- Find wireless zero configuration -- enable.. (After this go to network connstion -- Rightclick -- Propterties--Wireless networks -- Check the box that say use Windows to configure the device.
Apr 12, 2011 | ASUS L8400-C Configurator (ASNB100) PC...
Dell inspiron 6400 wireless capability turned off. need to find switch or function key combination
Hi, How do u do? You can easily turn it on by pressing Fn + F2.
have nice day. Babak
Mar 13, 2011 | Computers & Internet
My wireless does not work!How I can turn on again?
  1. Right-click the My Computer icon and select Properties.
  2. Click the Hardware tab and press the Device Manager button. The network card should appear under Network Adapters.
    Note: If the card has a exclamation mark over a yellow background, then this is an indication that the card is experiencing a problem. Go to Driver download step 5.
Note: The utility can be used to configure the wireless card settings, but if using Windows XP Zero Configuration or Access Connections, you will need to use those programs to actually configure the wireless card as they will overwrite the setting of the utility.
Note: The SSID and WEP key are case sensitive.
  • The connection will fail if the SSID is incorrect.
  • The most common security setting is the use of a WEP key. This involves using a 5 digit alphanumeric key for 64bit encryption or 13 digit alphanumeric key for 128bit encryption. Some systems will only allow a hexadecimal (0-9, A-F) key of either 10 (64bit) or 26 (128bit) characters. It may be necessary to convert your alphanumeric key to a hexadecimal one in order to connect properly.
Note: It may also be necessary to temporarily disable the security features in order to check for basic connectivity.
To check this:
  1. Right-click the My Network Places icon and select Properties. The wireless card should be present as Local Area Connection.
  2. Right-click the appropriate Local Area Connection and select Properties. In the Properties window, make sure that the Internet Protocol (TCP/IP) is installed.
  3. If TCP/IP is not installed, click Install, click Protocol, and then click TCP/IP.
  4. Once installed make sure that Obtain an IP address automatically, and Obtain DNS server address automatically are checked (if using DHCP). To verify this, highlight the TCP/IP protocol, and select Properties.
Note: Only use a Static IP Address if your network/Service Provider requires one.
  1. Click Start, select Programs, select Accessories, and then click Command Prompt.
  2. Type the command, ipconfig. This will list the IP address for the local machine.
  3. If this returns a 169.x.x.x or 0.0.0.0 address, then type the following commands, ipconfig /release and then ipconfig /renew. You should then receive a TCP/IP address appropriate to your network, along with a Default Gateway address.
  4. Try to communicate with it by typing this command ping x.x.x.x where x.x.x.x is the IP address of the Default Gateway.
  5. If this does not give a reply (see the example in step 9) or you did not receive a TCP/IP address, go to the next step.
  2. Type the command, ping 127.0.0.1. This will send a message to the internal network stack on the machine. You should see a response like this:
Reply from 127.0.0.1: bytes=32 time<10ms TTL=128
  • Run diagnostics on the wireless card.
Mar 28, 2010 | Acer Aspire 4520-5582 Notebook
Wireless connection is gone
under network properties enable the wireless network. Or toggle off and the back on. Some notebooks disable wireless when removed from wall
Jun 29, 2009 | Toshiba (PA3212U) Wireless Adapter
802.11g Network Adapter Radio Control Switch
Try FN+F2 to toggle the wireless radio on / off. Also check to make sure that driver has the radio enabled. (right click on the network adpter select properties. Click on the advanced tab. verify that radio on/off is set to on.
Feb 19, 2009 | Computers & Internet
Wireless antnena
Verify the wireless network power switch is on. The wireless network device in the computer can be turned on and off. The network power switch is located in different places on different computers. See the User Guide for the location on your model. Most models have a blue LED c01481711.jpg that glows when the wireless network switch is on Verify the wireless network connection is enabled The connection to a wired or wireless network can be disabled or enabled. To verify the status:
  1. Right-click the Network Connection icon c00814097.gif in the system tray, and select Network and Sharing Center .
  2. Select Manage network connections .
  3. Verify the status of the wireless network. c01481714.gif In this graphic, the wireless network is disabled.
  4. To enable the network, right-click the connection, and select enable . It may take a few seconds for the connection to become enabled.
Post back results so I may assits further if required
Jul 11, 2008 | HP Compaq Presario V6000T Notebook
Tadpole SPARCLE 650SX (D65S-80-D-09-2G) PC Notebook Logo
47 people viewed this question
Top Tadpole Computers & Internet Experts
David Payne
David Payne
Are you a Tadpole Computer and Internet Expert? Answer questions, earn points and help others
