Question about Nikon Coolpix S210 Digital Camera
Blurred focus & pictures on Nikon s210 - Nikon Coolpix S210 Digital Camera
  • 90 Answers
Can u try to reset the factory settings of the device....
Posted on Sep 29, 2009
Nikon D5000, when I try to take a picture everything is blurred and of course as a result the picture is as well.
Hi, the focus indicator LED lights, and some part of the scene is in focus, but not the object of your photo (af afs central area).
This is perhaps a back focus problem and needs service from Nikon to make the correction.
Grethings
Feb 23, 2011 | Nikon D5000 Digital Camera with 18-55mm...
My nikon coolpix s202 had the "lens error" now the pictures come out blurry and the camera will not focus.
Hi,af motor or its gears locked for a small particle (sand grain i.e.).Need cleaning.
Greethings
Feb 19, 2011 | Nikon Coolpix S210 Digital Camera
Red focus light never turns green and pictures are not clear/focused - what it the problem?
The focus motor is not adjusting the lens to focus - the gear may have broken or slipped off the motor or the motor itself is bad. It will need to be taken apart to fix.
Nov 03, 2010 | Nikon Coolpix S210 Digital Camera
Can nikon colpix S210 be used for webcam.
You can't. The S210 was designed as a camera, storing high-resolution pictures (and videos) to a memory card. It was not designed to stream low-resolution videos live to another device.
Jun 20, 2010 | Nikon Coolpix S210 Digital Camera
NIKON Coolplix S210 can't take photo in flash mode
If the flash is on and you can't take photos, it could be that the flash circuit has gone bad. Make sure the camera is focused first though, before you try to take the pictures. Many times if the camera can't focus on something, it wont take a picture.
Mar 30, 2010 | Nikon Coolpix S210 Digital Camera
Nikon S210 pictures always out of focus
Is the lens clean? Are you pressing the shutter button half-way and giving the camera a chance to lock in the focus (it will beep) before pressing the rest of the way? Do you actually move while pressing the button? Try taking a few pics while the camera is on a tripod or a firm surface to eliminate movement.
Mar 27, 2010 | Nikon Coolpix S210 Digital Camera
After taking pictures it come out blurry
1) Make sure all settings are set to "Auto".
2) The picture button has 2 stages, it takes a little practice, but after a while you can feel them.
The first stage tells the camera you're about to take a photo so get to it, setup the focus and set up the exposure setting.
The second executes the photo.
3) What you have to do is pause between stages 1 and 2 to give the camera a moment to focus properly. Then continue with taking the shot.
4) The other thing which can cause blurred photo's is camera shake, try and hold it as still as you can.
Mar 06, 2010 | Nikon Coolpix S210 Digital Camera
How do you set the picture timer on coolpix nikon s210
According to the manual on page 30 (linked below):
  • Press the self timer button (to the left of the OK button (marked with a clock symbol).
  • Select how many seconds to delay and press OK
  • Set the camera on a stable surface and aim and press the shutter half way to focus and then all the way down.
http://www.nikonusa.com/pdf/manuals/noprint/S220S225ENnoprint.pdf
Nov 21, 2009 | Nikon Coolpix S210 Digital Camera
Ive got the nikon d40. when i take photos close up they are blurred. there r 2 settings on the focus lense one is letter a one letter m. you have to move switch to indicate one or other. camara wont take...
The letters you're referencing is the M/A (manual / auto) focus switch. The lens has this switch and operates in Auto Focus mode when set to "A" and manual focus mode when set to "M".
You have to manually focus on the subject when in letter "M". If you do not, the result will be out of focus. From your description, it sounds like the camera / lens combination is attempting to focus and operate the shutter in auto, and focusing in manual; but due to some type of damage resulting from possible mishandling, exposure to dust, dirt or even moisture is interfering with the successful completion of the process.
You could isolate the problem to determine if the cause is in the lens or camera by simply attaching the lens to another compatible Nikon camera or placing a different auto-focus lens on your D40. The problem will either stay with your D40 or follow the lens when attached to a different camera. It is also *possible* that due to numerous attempts of auto-focusing with your D40 & lens combination, that both the lens *and* the camera have been damaged. If the problem is severe enough, the problem in the failed device could cause failure in the otherwise normally working device, too.
You might be best served by contacting Nikon Service & Support below:
http://www.nikonusa.com/Service-And-Support/Service-And-Repair.page
You also said you lost your manual. You can download the manual for the D40 directly from Nikon in your choice of English, French or Spanish from the link below:
http://support.nikontech.com/app/answers/detail/a_id/14157/session/L3NpZC9YRTgxQVpKag%3D%3D/kw/D40%20manual/p/19%2C334/c/187/r_id/116678/sno/0
Oct 09, 2009 | Nikon D40 Digital Camera with G-II 18-55mm...
Nikon Coolpix S210 Digital Camera Logo
318 people viewed this question
Top Nikon Cameras Experts
Steve
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
