Question about Dell Inspiron 6000 Notebook
When i turn on my computer i get File nvrd32.sys not found....
    Scholar:
  • 77 Answers
Nvr32.sys is a NVIDIA nForce RAID Driver, this driver essentially controls your hard drive in connection with the motherboard.
If you are able to boot into safe mode (pressing F8 during start up until the option becomes available), then you should be able to install the drivers
Inspiron 6000 Drivers can be found here, look for Chipset:
http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&ServiceTag=&SystemID=INS_PNT_6000&os=WW1&osl=en&catid=&impid
If this does not work for you then you will most likely need to re-install windows.
Posted on Sep 29, 2009
  • 250 Answers
Open link read instruction and do it
solve your problem .....
http://www.nforcershq.com/forum/manual-nvrd32-sys-nvgts-sys-textmode-integration-t72273.html
2 Suggested Answers
raph quintos
  • 94 Answers
SOURCE: dell latitude d610 upon boot, msg "The file nvrd32
You need to reinstall your operating system.
If you encounter this while installing XP, then you need to use another CD
Posted on Jul 17, 2011
I downloaded the contents of my Tascam DR-05 to my computer because it was full, but, instead of doing it as always, by just downloading the soundfiles, I copied the file folder dr005 to my computer,
Eric have you tried to do a "Quick Format"? If I'm not mistaken when that is done, you re-format your card and the small memory in the DR05. I had trouble with mine at first but when I did the formatting after I put the bigger 2GB memory card in the DR05 worked great. I record on "All Files" too, that seems to work well also.
Hope that helps,
Patrick
Oct 14, 2014 | Tascam DR-05 Portable Digital Recorder
System32 drivers ntfs sys
To resolve this problem, replace the missing or corrupted Ntfs.sys file:
  1. Use the Windows XP startup disks or the Windows XP CD to restart your computer.
  2. When the "Welcome to Setup" screen appears, press R to select the To repair a Windows XP installation using Recovery Console, press R option.
  3. Type the number of the Windows installation that you want to access from the Recovery Console, and then press ENTER.
  4. Type the administrator password when you are prompted, and then press ENTER. If no administrator password exists, just press ENTER.
  5. At the command prompt, type the following commands (press ENTER after each command):
  6. --->cd \windows\system32\drivers
    --->ren ntfs.sys ntfs.old
    Note This step renames the corrupted Ntfs.sys file to Ntfs.old. If the Ntfs.sys file is not found, the file is missing.
  7. At the command prompt, type the following command, and then press ENTER:copy cd:\i386\ntfs.sys drive:\windows\system32\drivers
    Where cd is the drive letter for the CD-ROM drive that contains the Windows XP CD, and drive is the drive where you installed Windows XP.
  8. Remove the Windows XP CD from your CD-ROM drive, type quit at a command prompt, and then press ENTER to quit the Recovery Console.
  9. Restart the computer.
May 17, 2014 | eMachines Computers & Internet
My win xp wont start due to nvrd32.sys missing file...please help.
Insert the windows xp reinstallation disc and boot up your computer. It will load up the missing files. Do a start up repair.
I hope this helps!
David
Mar 25, 2013 | Dell Dimension 3000 PC Desktop
Nvrd32.sys could not be found
The file is an Nvidia Raid driver. You may have to copy the raid drivers to a floppy drive and install them via F6 during installation.
Apr 15, 2012 | Dell Dimension 4100 (-JM0TB01) PC Desktop
Dell latitude d610 upon boot, msg "The file nvrd32
Jul 17, 2011 | Dell Computers & Internet
I turned on the PC, was asked to choose between WIN and WIN XP. When I choose WIN XP, the message comes up that "file nvrd32.sys could not be found" and so then I had to reboot the PC, choose WIN...
need the xp disc someone or thing has deleted a system-32, made the same mistake and had to reload the OS. System 32 is a main part of Your OS with just one little whoops of deletion you render the program useless. it should save your old stuff in a win.old file which it'll explain as you redo the whole thing over again good luck hope I can help
Jan 20, 2011 | Computers & Internet
Hi i am trying to reinstall win xp but its saying nvrd32.sys could not be found
That is the driver file for your NVidia graphics card
You should be able to continue the install by skipping the file and using the generic XP drivers. On completion download and install the NVidia drivers and all sholud be OK
May 11, 2010 | Dell Inspiron 6000 Notebook
Missing or corrupted file C:\windows\himem.sys
If you are running Windows 95, Windows 98, type:
copy himem.sys c:\windows <press enter>
If when typing any of the above commands you receive a prompt that the file already exists, ensure to overwrite it.
Reboot the computer; if the issue continues to occur, verify that the config.sys is properly setup. The line himem.sys should read:
DEVICE=C:\Windows\HIMEM.SYS
or
DEVICE=C:\DOS\HIMEM.SYS
Additional information and examples of the config.sys can be found on our autoexec.bat / config.sys page.
Dec 27, 2008 | Compaq Presario Notebook
Nvidia driver issue with vista I think
you are right insaying that is video porblem. here is the fix.
This is what appears to happen.during the installation of the most current drivers 100.65 Vista, an OLD file nvlddmkm.sys is copied into windows/system32/drivers and not the current one
in the install. As a result the new drivers are attempting to access a file
dated 11/2006 instead of 2/2007 ver 7.15.11.0065 which is in the newest WHQL
driver ver 100.65 vista 32.
Fix: Go to windows/system32/drivers and rename nvlddmkm.sys to
nvlddmkm.sys.old. Go to the nvidia directory and find the file nvlddmkm.sy_
and copy it to windows/system32. Using the cmd window (DOS box) type
EXPAND.EXE nvlddmkm.sy_ nvlddmkm.sys. When the expansion is complete, copy
the new nvlddmkm.sys to windows/system32/drivers and restart the computer.
Your computer should now work properly.
You will notice that any uninstall and reinstall of nvidia drivers will not
remove the old nvlddmkm.sys file and will not overwrite it with the newer
version. You have to do it manually. I do not know why this happens but who
cares as long it is fixed.
Good luck...
Oct 30, 2008 | Computers & Internet
Dell Inspiron 6000 Notebook Logo
2,441 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
