Question about Opticon Computers & Internet
I try rplacing a RBL-5625B REV A with a RLB-5625B REV B and they dont work any idea why?
How do i fix a 2007 ford explorer radio back light and rear wiper stoped
Have you checked your fuses? The fuse block should have each one labeled in the lid that covers it, and would tell you if rbl and rw are on the same fuse.
Feb 23, 2015 | Ford Explorer Cars & Trucks
01 jetta 1.8t odometer and clock stoped working any ideas
abs light on ? abs controls the speedo (odometer).... dont know what you mean by clocks.... do you mean the rev counter and gauges ??
Jan 21, 2014 | Volkswagen Jetta Cars & Trucks
When i accelerate in my 06 focus 1.8 i get a whooshing sound from the engine for a few seconds, i dont get it when i just rev it, any more ideas ?? Phil
This is just the throttle sucking air when the engine is under a load. When you rev the engine in park it wont make the noise as much or at all. Try driving it and slowly apply the gas and see if it happens.
May 15, 2011 | Ford Focus Cars & Trucks
The top thread is looping every 30 or 40 stitches on my Juki DDL 8700. I put in a fresh needle, cleaned thoroughly, fresh throat plate and re-threaded. Any ideas? Thank you!
hi there
please check bobin case spring maybe need t adjust or rplace.
please check if you are wind bobin by correct way not too much titght or not too much loose. thread insaid bobin must be littel soft.
the last reason maybe the tip of stoper for hook id damaged and need to rplace.
best regards
ashraf abozid
aabozid@hotmail.com
Dec 01, 2010 | Juki DDL-8700
I HAVE A MAKITA RBL 250 BLOWER BUT I DONT KNOW WHAT PETROL AND OIL MIX TO USE THANKS
It should be about a 50-1 mix, the directions are on the side of the two stroke oil you buy, Some of those little tiny bottles mix with 1 gallon of gas, or something like that. Check it out.
May 03, 2010 | Makita Garden
I just had my tires replaced and the tire pressure light is blinking, will this stop or do i need to take it back to the tire place?
Some tire pressure monitoring systems don't care if the wheels were put back on in the same position they were in originally.Unfortunately I think Subaru's do.If the light hasn't turned within a few miles of driving you will need to have your monitoring system reset.Most tire shops have the needed scanners but if they don't,do you Have a Discount Tire in your area? The last I heard they do this for free.Good Luck!
Mar 01, 2010 | 2006 Subaru B9 Tribeca
97 dodge ram brake lites dont work but runin lites all work
locate your brake switch and see power going to it if so jump it see if brake works if so rplace switch or adjust if needed /also possible harness problem
Jan 18, 2010 | 2001 Dodge Ram 2500 Truck
Sky codes for beko 32' tv
on the sky remote press the following
TV
RED + SELECT (blinks twice)
TV
0125
press the volume button,if it works press SELECT if not press TV then VOLUME again repeat this process of TV then VOLUME until it works then press the SELECT button to save the code to your remote.
Enjoy
Littlle Dish Fitter
Dec 27, 2008 | Beko 324250WN 28" TV
DOOR WONT EJECT AND ZOOM NOT WORKING
JVC GR-AXM310
Will not eject!!! I have put in a fully charged battery and tried to eject it, it will not open at all. Please help me out if you can.
Thanks Shorty_007
Jun 07, 2008 | JVC GR-AXM310 VHS-C Analog Camcorder
Computers & Internet Logo
Top Opticon Computers & Internet Experts
David Payne
David Payne
Are you an Opticon Computer and Internet Expert? Answer questions, earn points and help others
