Question about Acer Computers & Internet
I have an Acer Extensa 4420 with a fresh install of Vista that I just purchased on eBay. After I installed Vista I put all the drivers on that I found from the Acer website by downloading them on my desktop and transferring them over. The Broadcom wireless driver gave me a problem and said either there was no wireless or it needs to be turned on, so I used the switch in the front but nothing happened. After some research I learned that you have to have to install a piece of Acer software to make the switch work, so I did this and now when I use the switch some green text appears on the screen saying Wireless LAN Enabled or Wireless LAN Disabled. Unfortunately nothing appears to actually happen; the light for the switch doesn't light up, and the driver still can't find a wireless card. In the Device manager I have an Network Controller device that is in the Other Devices field with a yellow triangle and exclamation point meaning it needs drivers. This is not the wired port as that one has been installed and is working just fine and appears in the device manager properly. One last thing: in the BIOS there is no wireless option. Under the advance part of the BIOS there is an option for the infrared port, but no wireless. If the internal wireless is working, should there be something there? Any Ideas? I really want to get my internal wireless working.
  • 1 more comment
  • WebKill Sep 29, 2009
    I've done more research and found that if it's in the device monitor but not 'on' then it could be it's not switching on properly. I tried the trick of covering pin 20 (this is a mini PCI express card) with some tape, but it didn't seem to make a difference. Card is still recognized as needing a driver, but won't take a driver because it's not in an 'on' state.
    This isn't a driver issue, the Atheros driver doesn't install either; it gives the same message.
  • WebKill Sep 30, 2009
    I did re-install the Ethernet controller, and I am using a PCMCIA wireless card right now to get around this. I ordered a new mini pci express wireless card so we'll see if that fixes it I guess.
    Scholar:
  • 98 Answers
Sounds like you have done some extensive work on this? just a question did you reinstall you Ethernet controller? If not do so, since you will not bet able to connect unless this is installed. It may also be hardware problem you could also try buy and external receiver and see if its works, then you would be certain that its the hardware itself and not software.
Posted on Sep 30, 2009
  • 75 Answers
Use atheros, i use atheros and didn't encountered anything from it.
Posted on Sep 29, 2009
Is there a FREE software download to fix my acer Extensa 4420. It says (No audio output device installed) I assume it needs the driver?
all drivers are available from acer tech support on acer website simply download the correct 1s for your model to your documents folder then go to device manager and ask computer to update the drivers and add the documents folder to location to check it should find and fix them automaticly hope this helps
Oct 24, 2009 | Computers & Internet
Acer Extensa 4420 webcam problem
If you don't have the install disk, go to the Acer WEB site to download the drivers you need, make sure it is Windows XP or Vista version for your particular MODEL laptop and Windows OS.
Use this link :-
http://global.acer.com/support/download.htm
Apr 25, 2009 | Acer Extensa 4620 Notebook
WLAN does not work after reinstalling vista
If by WLAN not work you mean its totaly off then the chip burned out and you should send it ini to your computer maker for repairs. If its not then you should remove and reinstall the latest wifi drivers. (save old ones first) also make sure its not your WLAN Modem
Apr 23, 2009 | Computers & Internet
How do I enable bluetooth in my Acer Extensa 4420-5963
Actually Acer use the same laptop case for some of their models, so the acer 4420 doesn´t have built-in bluetooth, you won´t find any driver for the bluetooth cause that reason. I have an extensa 4420-5910, have a bluetooth switch in the case but no bluetooth, if you check at Acer´s web page it say thet some models doesn´t have built-in bluetooth but the switch is in the laptop case... On the other hand, if you install an external bluetooth device, the case switch will be usefull to turn it on and off.
Mar 13, 2009 | Acer Computers & Internet
Looking for Modem driver, Vga driver and PCI driver for an Acer Extensa 4420, and need help with installing.. where can i find the download?
You can download all the drivers from :
http://support.acer-euro.com/drivers/notebook/ex_4420.html
Regards
Jan 26, 2009 | Computers & Internet
Installing drivers
Can you give some additional info on what you are using for OS. In general the ATI software for Vista will install with no problem right from there website.
If you have jumped ship for Linux, then there are different issues with each distro. I currently use Ubuntu 8.10 and it comes with the ATI driver. It will recognise the hardware right after bootup. Other flavors like Fedora 9,10 are not as easy.
Dec 10, 2008 | Acer InviLink 802.11b (91.49C10.002)...
OS/Drivers incompatible Acer Extensa 4420
i can solve this easy,i had the same problem when i installed xp pro on my comp.it should be easier now than when i did it.first go to microsoft.com,go to their support and downloads section,then go to drivers and have them show you all the drivers you need ,then download them and install them,if that does'nt work let me know and i'll get you a program that will work.
Dec 05, 2008 | Acer Aspire 5610-4648 Notebook
Cd drive Acer Extensa 4420
After inserting the cd into the drive click on "My computer" and then click on the leeter of the cd drive. this will show files on the cd.
There should be a file called setup. Just double click it to start installation.(double clicking is clicking on something twice quickly in succession).
Oct 11, 2008 | Acer ASPIRE 3680-2022 Notebook
Acer extensa 4420
Well, I did the same thing, replaced vista with XP Pro, and couldnt get the wireless to work (the xp runs incredibly faster on this machine, B.T.W).
After days and days of trying to figure out this same problem, I finally found the driver. I found it at gateway...the link is here... http://support.gateway.com/support/drivers/search.asp?param=Wireless_Broadcom_4312_v4.170.25.12_XPx86&st=kw
Hope this helps all of you who did the same!
Peace...
T...
Oct 02, 2008 | Acer InviLink 802.11b (91.49C10.002)...
Computers & Internet Logo
309 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
