Can I change the Presario 1200-XL103 Laptop video mode from VGA
Presario 1200-XL103 Laptop Can I go from VGA to SVGA?
If the question is can I convert my composite video output to a super video input then the answer is NO,
Not really the question!
I have a Presario 1200-XL103 Laptop. It is in VGA mode! How can I get it into SVGA mode?
I would like to get out of 2 or 16 colors to SVGA. Can you tell me where I can get help with that?
Thanks,
Douglas
  • Jaye Ellen Burke
    Jaye Ellen Burke May 11, 2010
    Have you tried going into Display Settings in Control Panel and reset the slider to an appropriate resolution?
    Problem Solver:
  • 17 Answers
U just went to ur brand site.. and there u enquire about ur problem.
Posted on Dec 12, 2009
How do i connect my hp2560p to tv
You can use a VGA cable to connect from your laptop to your TV.
10FT 15 PIN BLUE SVGA VGA ADAPTER Monitor Male To Male Cable CORD FOR PC TV
Just make sure you have a connector on your TV....If you only have RCA inputs, you can buy an adapter. just plug it into your laptop and run the Red, White and Yellow to your TV with RCA cables.
VGA SVGA to Video 3 RCA AV TV Out Cable Adapter Converter PC Computer...
Thanks Hope this helps!
Please rate
Gary
Mar 17, 2014 | HP Elitebook 2560p Notebook 12.5" 2.5gI5...
Netflix fro 5315 laptop vga
Can ur laptop set to SVGA modes like to 800 or 1024 resolutions modes.Yes?Than Netflix should play and will work find at these resolutions.
Jun 24, 2012 | Acer Aspire 5315 Notebook
My Video Controller(VGA Compatible) does not respond My laptop is Compaq Presario V2000 Win XP
-do you have any display at all?
--if yes
can you try to boot to safemode with VGA Mode?
-press F8 when booting up, then it will give you the boot option, select boot to VGA mode, then roll back the friver or re install it
-if you don't have a video at all, try to remove the LCD cable and plug it back in ( you have to open the laptop's chasis
Sep 04, 2010 | HP Compaq Presario V2000 Notebook
Cant get any sound on tv
The only computer (or laptop) connection that carries both video and sound is HDMI. If you do not have a HDMI/DVI connector on the back of your computer, then you will have to use the VGA-composite or s-video connectors to display your PC's output on an external monitor like an LCD TV.
On both my HP and Dell laptops the display settings (Start/Control Panel/Personalize/Display Settings) allow two modes - single or dual monitor mode. Single monitor mode allows me to switch between any one of three possible video outputs - VGA-composite, S-Video or laptop screen, or a split-desktop (display spread over two separate monitors). Dual monitor mode allows the same display on any two of three possible video outputs.
Switching is performed using the fn keys on the keyboard (fn key plus the F2, F8, etc. function key with the display marking). You guys use single monitor mode until you figure out what your are doing. Select VGA-composite or S-Video.
Non-HDMI sound to your TV monitor or sound system must be obtained from your laptop's Headphone or S/PDIF jacks. Headphone is stereo and S/PDIF is 5.1 surround sound. Headphone is electrical, but S/PDIF may be electrical or optical (laser light). You must set the sound jack that you intend to use as the default on the PC control panel (Start/Control Panel/Sound).
None of these connectors is two-way in the context of an LCD monitor - your PC cannot record a TV picture or sound from the external monitor. To accomplish this you must purchase a video converter box that converts cable TV or video + sound inputs to USB format usable by your laptop. Do this and you can turn your laptop into a Tivo recorder/DVD burner using Beyond TV, Sage TV or a variety of other software packages.
Please let me know if you have any further questions or concerns.
Thanks.
May 07, 2010 | HP Compaq Presario C700T
The composite is coaxial (2 wires) the S-Video uses 4pins and there is no S-Video output on a Presario 1200 laptop.
You can however use a Multi-AV SCART adaptors with Input/Output signal switch where you plug in the composite video output into the top video and 3.5 mm jack stereo audio into the mono audio connections on top.( via a stereo to mono cable)
http://upload.wikimedia.org/wikipedia/en/thumb/a/a7/Multiconnector-scart-chti.jpg/200px-Multiconnector-scart-chti.jpg
Hope this is the answer you are looking for !
Sep 27, 2009 | Compaq Presario 1200XL103 (155726-163) PC...
My Dell D610 laptop monitor has went completely white.
I don't have a Dell D610 with me, there should be a VGA/SVGA port on the back. If not, there's a DVI port.
If the video has not gone bad, you should be able to. Connect the monitor to the back vga/svga port or DVI port.
The are several controls to activate the monitor for Dell computers.
CTRL ALT <
CTRL ALT F10
FN F8 (CRT/LCD)
FN D
FN F12
Good Luck.
Dec 30, 2008 | Dell Latitude D600 Notebook
My hp pavilion laptops video card messing up
Actually you should be able to use S-Video. But with S-Video your digital display is converted to display of a Television(S-video
mode). So if you compare the quality of SVGA and SVDO the resolution is completely different and no other way to make the 2 the same(base on different format).What I use is a VGA cable connnect to my VGA Output for my LCD TV.I have very good output the same as my computer.
takecare.
Apr 26, 2008 | Computers & Internet
VGA CONNECTION
You are trying to run a VGA signal to your television? Usually you need a scan converter to do that so the signals will match. Does your laptop have S-Video out? That would be the ideal method.
Jan 08, 2008 | Compaq Presario M2000 Notebook
Computers & Internet Logo
53 people viewed this question
David Payne
David Payne
