Question about Whirlpool Refrigerators
I have a side by side whirlpool and when I open the refrigerator side the light doesn't come on, it will flicker some but mostly just out. and I hear a noise like a motor trying to run but cannot. When I push the button to simulate closing the door the noise stops. The freezer side seems to be running fine and no light issues.
    President:
  • Whirlpool Master
  • 1,922 Answers
Your control board is defective in the lower rear of the unit part # 4334000 appliance parts pros 1-877-477-7278
Posted on Nov 04, 2009
Light inside the refrigerator flickers (or not) and the door makes a buzzing noise when opened. There appears to be a small light flickering inside the fridge behind the vegetable bend. The refrigerator...
Sounds like the electronic control in the rear compartment by compressor may be bad . There is a light in the crisper as well I believe and that one and the main light are controlled by the control in back.
Dec 03, 2010 | Whirlpool Gold GS6SHEXNQ 25.6 Cu. Ft....
In the frig part their is 2 light bulbs1 doesn.t work at all the other flickers tried replacing it does the same it flickers
the bulb that does not work replace and the light sw mabe causing the flicker and if not you have a loose wire connection . mm
Sep 02, 2010 | Whirlpool Refrigerators
Light bulb flickers and strange sound
that is just a small problem..try check ur bulb..maybe its loose,tighten it back..then that strange sound maybe came from spark between the bulb and its connection..
Sep 18, 2009 | Whirlpool GS5SHAXN Side by Side...
Ref light bulbs and noise no cooling wh-pool GS5SHA
I had the same problem. There is a main controller board at the bottm of the refrigerator near the back by the compressor motor. One of the components on the board shorted out and the board had to be replaced. Total cost about $150.
May 30, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Refrigerator door light is clicking when door open; light flickers, or does not work at all
check the door switch to see if its working. also check the bulb it may be loose in the socket.
Jan 21, 2009 | Whirlpool GD5SHAX Side by Side...
Whirlpool refrigator side by side(2 doors side by side)
This sounds like the curcuit board has failed. No repair is able to be made to the board. Just replace the board and all should be fine..
Nov 06, 2008 | Whirlpool GB9SHKXL Bottom Freezer...
Whirlpool refrig side by side
flickering noises??? are they working at all. or are tehy flickering on/off along with the noiise. id be willling to bet that if you removed the back panel from behind the refrig, youll find a control board mounted on the left side(when lookin at from behind) alongside the compresssor assy in a white box. if thats the case that, that there is a board there and your lights are not functioning and you hear "chattering" when the doors open you have a faulty board, look up via model number and replace it
Oct 31, 2008 | Whirlpool Refrigerators
Whirlpool Gold Black on Black 21.9 cu
I had the same problem. The light would dimly flicker and make a sort of clicking noise. It was still under warranty and the repair man had to replace a circuit board in the back. Not sure of what the cost would be if not under warranty. Hope this helps.
Oct 23, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool Gold side by side SR2659325
are you hearing a hum then loud click hold my rating till we are done
Mar 31, 2008 | Whirlpool ED2FHEXN Side by Side...
Whirlpool refrigerator
unitsdworking though just no lights in refrig compartment??? if so i would pull unit out nad check laft side bottom of unit for contoil board, remove it and chances are you see a burn mark on one of the circuit, if so youll need to replace it
Feb 18, 2008 | Whirlpool GS6SHEXNL Side by Side...
Refrigerators Logo
65 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
