Question about Primavera Project Planner P3 (PRIMAVERAP3) for PC
In Windows vista registry virtual device is invalid
I am using Windows vista. When I tried to install P3.1 it says "Virtual driver format in the registry is invalid" and did not install. I need help Thanks.
    Problem Solver:
  • 10 Answers
Use some free registry defrag tool to ask for a help
Posted on Jan 29, 2010
Hi there, I am trying to install windows Vista as a virtual machine but I keep getting an error saying something that I have recently installed has caused a problem. The app I installed was vmware which I...
Hello there, usually when you want to install a virtual machine the first thing to do is determine if the virtual machine platform is compatible with the OS you are planning to install. I had similar problems with VM ware when i was trying to use it with vista and it was one error after the other.
Needless to say VM Ware is not so compatible with vista. If you really want to use a virtual machine for vista without hassles simply switch to Virtual Box from sun micro systems. You can download this for free from virtual box.org the system is straight forward, easy to use and has great support capability for vista OS.
Hope this support has been helpful?
Thank you for visiting FixYa.
Jul 25, 2011 | Computers & Internet
I want to install the CanoScan Lide30/N1240U but there is no driver for Windows7. So it looks like I cannot use the scanner anymore. Is there anyone who knows a solution?
Go to site
http://software.canon-europe.com/products/0000466.asp
and select OS as Vista and language as English and press submit
and download windows vista drivers.
you can use Vista driver in Windows 7 using Compatability Mode.
Step required..
1. Right click on driver installation file.
2. choose properties
3. choose compatability tab
4. select Vista
5. press ok
6. Install the driver
I hope it will help you.
Thanks for using FixYa.
May 23, 2011 | Canon CanoScan LiDE 30/N1240U
I need the drivers umax astra 5600 for windows 7
Hi, You could try and use it in an XP Virtual machine
Steps to take to check, if you can use Virtualization http://www.microsoft.com/windows/virtual-pc/support/configure-bios.aspx
Give info on all Cpus From Intel and AMD http://en.wikipedia.org/wiki/X86_virtualization
Virtual PC & Xpmode. http://www.microsoft.com/windows/virtual-pc/download.aspx
When you have XPmode and Virtual PC set up add the XP drivers for the scanner to the XP virtual Machine then connect the usb cable to W7
You should now be able to use the scanner in the XP machine.
Please contact the scanner manufacturer and see if they can provide the driver for Windows 7. Also, if the driver is for older operating systems, you can install the device driver in the Compatibility Mode.
thanks for rating Good luck
Jan 14, 2011 | Umax Office Equipment & Supplies
I absolutely hate vista....i wasn't able to transfer my microsoft money so had to download quicken and transfer info...then twice now i have had to reinstall quicken because it won't open up...i guess it...
There is a work around to getting Windows XP programs to work under Windows Vista - Virtual PC 2007.
Virtual PC 2007 is a free download from Microsoft and it allows you to install any operating system and run it in a "window" on your Vista desktop.
Download Virtual PC 2007, create a Windows XP virtual machine, install Microsoft Money and transfer in your data. You can install Quicken as well.
The virtual machine will use your PC's actual connections (network, serial and printer but not USB) to connect to devices and the Internet.
Again - this is a work around that is proven to work. One side benefit - you can copy the virtual machine to an external hard drive / USB memory stick and run it on any comptuer that has Virtual PC 2007 installed on it.
Hope this helps
Nov 18, 2009 | Microsoft Windows Vista Ultimate Edition
Find free driver for umax astra 5600 scanner for OS windows7
I have Umax Astra 5600 scanner but it dose not work in Windows 7
Nov 16, 2009 | Office Equipment & Supplies
Gets error code 0x0000007B when I attempt to install XP on hp pavilion dv6-1245dx pre-installed with Vista
Nomally on a vista installed lap you will have reverse compatibility issues when you try to install xp cause vista is a newer editon than xp. So it would be advisible to use a virtual machine software to install xp inside vista.By doing this you can simultaneously run vista and xp at the same time.you can download free software line SUN VMWare.
Oct 10, 2009 | Computers & Internet
I have installed virtual pc in windows vista. in virtual pc i ave installed windows xp. in virtual pc my usb ports are not working
Virtual PC for Windows does not support USB devices (other than a mouse and keyboard ... which are not actually emulated via USB, but are simply "used" through the host) ... but just to confirm the "official" statement of this:
http://support.microsoft.com/kb/824511/en-us
Unfortunately, Microsoft did NOT add USB support in Virtual PC 2007 (a widely anticipated addition that simply didn't happen).
VMWare Server DOES support USB devices (through the host) with some exceptions. From the documentation: "... Modems and certain streaming data devices, such as speakers and Web cams, do not work properly." You may want to read the details of using USB devices with a VMWare virtual machine starting on page 232 here: http://www.vmware.com/pdf/server_vm_manual.pdf
You can download Virtual Server for free here (You'll need to register and request a free key ... a painless process): http://www.vmware.com/download/server/
Dec 28, 2008 | Microsoft Virtual PC 7 with Windows XP...
Hp pavillion dv6000 laptop drivers for microsoft windows XP prof.
try to download belarc advisor software. Run this in your vista OS and send it to me so I can check your hardware specs. This is the only way to avoid problems in the future or before you start the formatting.
Dec 01, 2008 | HP Pavilion dv6000z Notebook
NEED DRIVER TO VIEW SOFTWARE
Have you went to the software manufacturer's website to see if they have an updated driver for their software/. Have you checked the playstore ? Or windows store or Apple store, whichever applies and just do a simple search in the search box for the drivers...
Oct 21, 2017 | Cosmi Computers & Internet
On vista i have vmware 6
Your Guest OS uses a Virtual VGA adaptor. As with a normal computer it needs drivers. This usually is installed through VMware Tools. (VMware tells your guest OS there are all kinds of virtual devices. They don't exist physically but need their drivers since VMware uses the virtual devices to handle the Host PCs physical devices.
In order to install VMware Tools, go to:
VM > Install VMWare Tools.
Remember that you need Administrator rights.
Need more help? See the link below:
[Installing VMware Tools]
This should do the trick, let me know if this solved your problem.
Greetings,
DarkNeogen
Jan 23, 2008 | Microsoft Windows Vista Ultimate Edition
Computers & Internet Logo
114 people viewed this question
Top Primavera Computers & Internet Experts
Tom Chichester
JEfromCanada
john smith
Are you a Primavera Computer and Internet Expert? Answer questions, earn points and help others
