Question about Casio Watches
Casio 1605 I need a photo or diagram of the spring(s) placement
Casio 1605 :ladys model Illuminator'' 2005 manufacture
I need a photo or diagram under the case cover of the spring location holes
2 springs are used 1 is brass colored seems to fit--locate in a hole next to the battery clip the other other is a steel
spring I need a diagram or picture of this watch with there proper location holes......these are coil springs about .05-1mm dia x 2-3mm length. Thanks
SOURCE: Battery replacement prg 40 model 2271
The silver spring goes in a very small hole in the plastic casing on the bottom side of the watch located next to the wristband under the sensor. Hope this helps
Posted on Sep 11, 2008
escapement
  • 2334 Answers
SOURCE: Model & spring issue with an old Casio G-Shock...
Yes, definetely thru that rubber gasket, otherwise there will be no contact and no sound respectively.
Posted on Dec 19, 2008
SOURCE: casio illuminator, w-94h
There is a tiny spring that must make contact with the back cover plate when you screw it back on. If the spring is missing, the piezoelectric buzzer will not work. The tiny spring is located toward the upper right in this photo of a Casio W-94H watch, directly underneath the "C" in CASIO that is etched in the metal. Note that the word CASIO is upside down in the picture, so if you can't see the picture for some reason, the hole for the tiny spring would be directly above the "C" in CASIO.
Posted on Feb 01, 2009
  • 183 Answers
SOURCE: Changing the battery on My Casio watch module 1848. Two
The contact springs most likely have nothing to do with your screen being black.
The watch will have an "AC" or all clear function that needs to be performed. Check the back lid for AC or reset instructions. If there are no instructions there then you will have to visit a watch repairman/technician to have this procedure performed as it involves touching the AC pad on the circuit board to the back of the battery already installed. The circuit board is easily damaged if not performed properly.
Posted on Sep 17, 2009
cmcduncand
  • 714 Answers
SOURCE: problem with WAVE CEPTOR watch band
http://world.casio.com/wat/download/en/manual/
There are so many applications use of the manual will be mandatory.
Use the four numbers on the back of your watch and you will have a PDF version of your instruction manual.
Hope this tip helps
R/
David
http://antiqueclock.clockstop.com/
Posted on May 07, 2010
How do I set the analog time on my Casio illuminator watch
Every model changes the way time is set , the watch should of come with a manual, If not Google ( Casio watch manuals) then in the search window type in the watch model, click search, then down load it.
Mar 03, 2016 | Casio Watches
Problem with WAVE CEPTOR watch band
Hope this tip helps
R/
David
May 06, 2010 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
G SHOCK!!!!!!!
Go to "www.columbia.com/Equipment-+-Accessories/Licensee_Landing,default,pg.html"
Under "Timing" you will see a link "PDF.............", click on this
and a list of diagrams will appear. Choose the one that looks like yours
and follow the adjacent instructions.
Mar 01, 2010 | Casio GShock Illuminator watch
Change annalog time Casio illuminator
Hope this tip helps.
R/
David
Dec 22, 2009 | Casio ILLUMINATOR DUAL TIME MEN WATCH...
Re-assembly
With the stainless back off you can see the white plastic cover. To the right of the large battery is a small hole (about 1.5mm in diameter). The spring goes in this hole and presses against the piezo sounder disk that is glued to the inside of the stainless back. Make sure you put the back on the right way up - the word CASIO should be at the top, the same end as the word ILLUMINATOR on the front.
Apr 11, 2009 | Casio AW43-7E1V Wrist Watch
Casio illuminator, w-94h
Nov 25, 2007 | Casio Sea Pathfinder SPS2011V Wrist Watch
Watches Logo
251 people viewed this question
Top Casio Watches Experts
Kazim ERGUNEY
Kazim ERGUNEY
Jimmy Accardi
Are you a Casio Watch Expert? Answer questions, earn points and help others
