Question about Rowenta Precision DM580 Iron
My rowenta iron tripped the switch after I descaled it.
  • Rowenta Master
  • 43,501 Answers
Here is a tip that will help you to troubleshoot your iron and figure out what is wrong with it.
Electric Iron not Heating Up or not Working Right
http://www.fixya.com/support/r5300202-electric_iron_not_heating_up_or_not
heatman101
Posted on Jul 14, 2010
Rowenta superpress DG 050 leaks water while steaming all over garment. Do I need to Descale the unit?
I've had the same problem with two Rowenta irons. When set to a lower temperature, the iron has a bad habit of leaking water when the steam option is on. I have to either turn up the temperature setting or shut off the steam option.
Feb 28, 2015 | Rowenta Irons
Why has the steam function has just stopped working - power on but nothing happens
My wife has one of these irons and she loved it. Now it steams for a while, and a red light starts blinking and it stops steaming. It can be turned back on and works for a while, then the same thing happens. I read that it needed descaled, so I bought OUST descaler and ran it through the iron, but it did not solve the problem. Any one have a solution to this problem, I would like to hear from you.
Jul 07, 2014 | Rowenta DG8430 Pro Precision Steam Station
The tank in my rowenta iron is producing steam but the iron is not producing steam
Yes the iron needs to be cleaned. They do have a descaler to clean. the Steam valve with a electronic switch is broken, that is what opens and lets the steam out of the iron when you press the button.
Google Rowenta repair Centers.
Jun 30, 2014 | Rowenta DG5030 Iron
The steam button is producing no steam, how to fix it?
have u descale it .I use pure white vinegar in the iron switch on the hottish setting then keep pressing the stream button. But getting rid of the lime scale is a lot harder.
May 16, 2014 | Rowenta Irons
NO STEAM COMING OUT....IRON IS HOT AND WATER IS HOT, BUT PUSH SWITCH FOR STEAM??NOTHING COMES OUT
you need to use a descaler, the holes have become clogged. you can buy this in most hardware stores
Mar 23, 2010 | Rowenta DG-980 Iron
DG050 Rowenta how do you clean out the base(where
If you live in a hard water area add a bottle of kettle descaler and some hot water , leave for 1 hour then rinse out thoroughly
Aug 21, 2009 | Rowenta Steam Generator DG050 Iron
Rowenta steam iron no longer steams
Your local grocery or hardware store will sell "descaler" for coffee pots and irons.
Mix as instructed (water/descaler) and pour the disolved mix into the iron. Set the iron on the highest steam settings (heat and steam volume). After it is hot, let it steam into the sink, pressing the steam button over and over to let the descaler work through all the tubes/passages, until it has all been pumped out.
Refill with more descaler (if it is not completely unplugged) and repeat until you are satisifed with how the iron is working.
After descaling, run clean water through it with the same process (but no descaler) several times.
aymloekh0fg4hpz2e87n86udvs4fowqwshuaaaaasuvork5cyii=
Mar 24, 2009 | Rowenta Professional DE841 Iron
Rowenta Effective
The rust spot are probably caused by iron in your tap water. I would suggest you put a solution of half vinegar and half water into the water chamber and leave in the iron overnight.
Then switch it on to steam and holding the iron over the sink or over an old towel, the dirt (residue) comes out of the holes on the soleplate. Sometimes if the iron is badly scaled you might need to repeat the descaling.
Once complete, fill again with clean water and steam away, to flush any of the remaining vinegar out of the iron.
Depending on how often you use your iron and how much iron is in your water, you might consider performing this flush process every 2 or 3 months. It will help extend the life of your iron.
Another option is to use distilled water in your iron. Distilled water has all the minerals removed.
Good Luck!
Aug 11, 2008 | Rowenta Powerglide DM273 Iron
Rowenta Precision DM580 Iron Logo
309 people viewed this question
Top Rowenta Irons Experts
Henry  Thomas
Henry Thomas
Are you a Rowenta Iron Expert? Answer questions, earn points and help others
