Question about HP OmniBook Vt6200 Notebook
Keyboard problems i have a HP vt6200 Omnibook laptop with German Keyboard. Recently my internal harddisk crashed and I replaced with a new IDE disk. I installed Windows XP (English US) afresh. Also installed the necessary drivers downloaded from HP site. Now the german keyboard is not working. It types multiple characters & behaves erratically. When I connect an external US English Keyboard, it works perfect. I tried changing the language/keyboard settings. It didn?t work. I donot want to use German anymore on that laptop. All I want to use is only English. Now I am unable to use the laptop keyboard at all. Pls help
    New Friend:
Is the keyboard flexible cable the same pin as the original keyboard? If yes and you are sure the new keyboard is okay, then you can change the language to the preferred language e.g US English, change its position to the first and make it referred. Its should work. You can also check online if there is any keyboard or input driver which when installed can be of help.
Posted on Apr 12, 2017
2 Suggested Answers
Fwayne
  • 97 Answers
SOURCE: English language support on laptop with German Keyboard
The easiest solution will be to locate a replacement laptop keyboard for that model. they arent hard to replace and usually cost between $40 and $80. I would web search HP Spare parts Third party is usually cheaper. Keyboards are pretty common replacements on laptops due to wear an tear. Most are replaced using a small phillips screwdriver. Its likley you can find removal instructions on the web as well (if they dont come packaged with the keyboard.
Posted on Dec 24, 2008
Harddisk drive ide connector
try replacing your ide connector.
Aug 22, 2012 | HP Compaq nx6125 Notebook
What is the function key to turn wireless on
How to turn on/off Wireless in various Laptop Models ------------------------------------------------------------------------------------
Vendor/Model-----------Type----------Location
Dell D600 & D610-----KeyBoard-----Fn+F2
HP nc4000 & nc4010-----Button-----Above Keyboard
HP nc4220-----Button-----Left Side of Laptop Near USB Port
HP nc6000 & nc6220-----Button-----Above Keyboard
HP nx9010-----Button-----Front side of laptop
HP Omnibook 6200-----Button-----Left side of laptop
IBM T43-----Keyboard combination-----Fn + F5-----Click "Turn On"
IBM X32-----Keyboard combination-----Fn + F5-----Click "Turn On"
Toshiba M1 & M2-----Switch-----Left side of laptop-----Towards
front
Toshiba R100-----Switch-----Right side of laptop
Toshiba TE2000-----Switch-----Left side of laptop-----By Vol ctrl
Toshiba Tecra 2100-----Switch-----Left side of laptop-----By Vol ctrl
Sep 09, 2011 | Computers & Internet
Our HP Pavillion dv8000 just recently started having problem with keyboard. No Virus. Caps Lock light will not go on (frozen) and "s" key does not work. Sometimes the keyboard properly- sometimes it...
Clean the keyboard wiith a compressed air can, if that doesn't do the trick try a usb keyboard, if the external keyboard works well then you need to replace the laptops keyboard.
May 13, 2010 | HP Pavilion dv8000t Notebook
Hi. On my Omnibook 4100 Keyboard following keys do not work. 4,5,r,t,f,g,v,b.. Is this a cable connection fault or circuitry fault that requires a chip replacement. thanking you. Alfons.
If you remove the keyboard you there will be on flat cable running from the keyboard to the laptop. At the end of the cable (the end that goes into your laptop) there is a hm.. "connector" (can't remember the real eng word, sorry)
Pull it out of the socket inside the laptop and reconnect it, making sure its not loose and all should work fine.
Dec 02, 2009 | HP OmniBook 4100 PC Notebook
I upgraded my hp omnibook 6100 from xp to windows vista. now it tells me that there is no audio device installed. is there a driver i can download for my laptop that is compatible with windows vista?
I had the same problem with my HP when l put vista on it and overcame that problem with using my XP driver. It worked for me no harm in trying your XP driver.
Nov 24, 2009 | HP OmniBook 6100 Notebook
How do i replace the keyboard on a HP Omnibook 6000? I have removed the panel covering the speakers and removed those screws but something is still hanging up in the middle of the keyboard
Check on the bottom of the Omnibook for a screw that might be holding the keyboard in place. Or it may be a ribbon cable that has to be disconnected. Try to peek under and see.
May 31, 2009 | HP OMNIBOOK 6000 3P800 128/10G CD 14.1 56K...
My hp omnibook vt6200 have screen failure... When I turn them on I have black screen and I can't see nothing....but when I plug other screen than he works perfect.... Thank you very much Regard...
Hi there.
while you have the external monitor plugged in and you have the display on that monitor, hold down Fn and look for a F key which has a TV/monitor icon on it and hit that key (you may have to hit this once or twice) this is whats called the keyboard toggle switch, if your laptop monitor comes on then the problem is sorted and you can disconnect the external monitor.
Post back with the results please
Good luck and thanks for using Fixya!!!
Feb 24, 2009 | HP OmniBook Vt6200 Notebook
Dec 24, 2008 | HP OmniBook Vt6200 Notebook
I NEED TO FIND AND REMOVE THE HARD FOR A HP OMNIBOOK XW3
hard? do u mean the harddrive? well the harddrive is slightly slimmer on laptops and looks like the box, harddrives are usually extremely internal depending on the laptop and can be found under the keyboard(open from the bottom).
Jul 02, 2008 | HP Computers & Internet
HP OmniBook Vt6200 Notebook Logo
91 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
