Question about Ruud Heating & Cooling
I need a Ruud Contour Comfort Control manual. When I try to set temperatures for different times of the day it defaults back to 68 degrees. I need a manual to see what I am doing wrong.
4 Suggested Answers
  • 61 Answers
SOURCE: thermostat issue with comfort zone II.
Is this an electric or gass furnace - Eather of these can can have this problem its most recomendable that you call a seviceman .
in the case of electric furnace you may requier a new heat sequencer. And in the case of gass you may requier a new relay.
Posted on Feb 19, 2009
skrbin
  • 121 Answers
SOURCE: Thermo King Super II SR BM#092170 will not lower its temperature
try to clean gas cooler (it is radiator outside),unplug it from power (wall) then clean it with brush up-down (not left-right),wait 1hour and turn on
Posted on Jul 08, 2009
motor1258
  • 6674 Answers
SOURCE: I have a comfort control 2200 thermostat. I
May be the location of the thermostat. Try another thermometer right beside wall thermostat & see what it reads.
Posted on Jul 19, 2009
My thermostat is set on 68 degrees and it shows room temperature is 68, but the furnace still kickson, Honeywell said it has a 1 degree difference. so what's the problem then?
Yes there is a one degree tolerance, in fact my heater just kicked on and it is set to 67 and the inside temperature reads 67. It is also a Honeywell.
Dec 28, 2016 | Heating & Cooling
Just need to know if the temperature should be higher to keep the room cool or lower...mine is in F and goes from 68 to 86 degrees F...Please advise if it should be lower at 68 degrees to keep the room at...
Lower temperature will keep the room cooler. For efficiency sake, lower the temperature gradually to
68 degrees.
Hope this helped you. Thanks for choosing FixYa.
Jul 21, 2011 | Sunbeam Heating & Cooling
My Whirlpool wall-mounted air conditioner is not allowing me to lower the degree temperature. I only had it installed several months ago, and it worked great and I was able to continuously keep it at the...
Try un plugging it for a while like a munite or 2 and plug it back in .. befor eyou plug it back in though remove the batteries from the remote as well I MIGHT rest it .. I'll keep my finger crossed for ya
Jul 19, 2011 | Heating & Cooling
My Oaisis II hot tub stays at 103 and now it's dropped down to 68 degrees for the past 3 days? Could there be a problem with my heater element? Or is there a sequence of resetting the temp buttons on top...
Information on the care of your product and troubleshooting is available here:
http://www.oasisleisure.ca/customer_care/SpaCare.html
Did you have a recent power outage? It is necessary to reset the temperature after a power outage.
Check the temperature setting on your hot tub; if it has defaulted do to a power outage reset to the desired temperature. If it is still set at your desired setting and is operating at 68 degrees then there is a problem that is preventing the tub from reaching the set temperature.
Some possible causes and actions are:
Pull filter (see if light comes on) / Replace filter
Knife valves not fully open / Open knife valves
Pressure switch cut of calibration / Adjust pressure switch
Faulty Pressure Switch / Replace pressure switch
Air leak, check pump suction line / Tighten pump union
Heating element corroded / Replace element
Faulty control panel / Replace panel
Find the Manual for you specifc model for more explansyion on Troubeshootig.
Feb 06, 2011 | Home
My nonprogrammable Honeywell thermostat th5110D is no matching temperature settings (desired and actual). There is about 4 degrees difference. I have looked at the manual and reset the system and changed...
Your thermostat is reading the temperature where it is located.
If it is located next to a heat source maybe it is picking up that added heat .
Try relocated your thermostat
May 30, 2017 | Heating & Cooling
I have a ruud heat pump that tries to run aux heat
depending on your wireing,
you may have an off set in your thermostat
look at your programming guide
sometimes its set at the default of 1 but you can change that to anything your comfortable with
Oct 18, 2009 | Ruud UBHC Air Conditioner
Freezer temperature v
This sounds like your motherboard,computer or control board(they call it different things in different models) is bad. It is responsible for the fan speed and timing of the defrost cycle. To locate your timer, motherboard, control or adaptive defrost control , enter your model number and search for the part or post back on Fixya.
http://www.searspartsdirect.com/partsdirect/index.action?psid=26129238&sid=PSx20071217x00001a
Sep 20, 2009 | Freezers
What do set the thermostst at? and do you keep it on all the time
Your first problem is the AEV1000 come with a Dehumidistat on not a Thermostat.
Best place in Summer time is 90% or unplug the unit if you open your windows.
Best place in winter time is around 40%-50%
For the manual. contact Fantech at 1-800-565-3548 ask them for the 1 or 2 page manual for MDEH1 They can email it to you of Fax it. They can probably even Mail it.
Nov 27, 2008 | Fantech AEV1000 Air Exchanger 120 cfm
Heating & Cooling Logo
623 people viewed this question
Top Ruud Heating & Cooling Experts
Donni Steen
Bill Long
Tim Whalen
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
