Question about Acer Aspire 5610-4648 Notebook
MY ACER 5610Z LAPTOP STARTS UP BUT WONT LOAD WINDOWS
MY ACER 5610Z LAPTOP STARTS UP BUT AFTER IT SHOWS THE ACER LOAD SCREEN WHERE YOU CAN ACCESS THE SETUP IT JUST GOES TO A BLACK SCREEN. I CAN GO INTO THE SETTING AND SEE NO PROBLEM. I HAVE ALSO TRIED TO RESTORE THE OPERATING SYSTEM BY PRESSING ALT AND F10 AT THE ACER SCREEN BUT ALL I GET IS A BLACK SCREEN AND A FLASHING CURSOR BUT NO PROMPTS
  • 50 Answers
WIth the limited fault description its a guess at best. you probably have a corrupted driver or hard disk fault. If you can try a replacement hard drive and reload OS you should get progress.
Posted on Sep 29, 2009
When it gets to the startup screen it shows some updates then shuts down
If you have your windows installation disk you can try to do a system repair. To do this, turn on you laptop and when the bios starts (usually white text on black background or an acer backgroud) press the F12 key to change boot order. Now select your dvd or cd drive. Windows will load files and then ask what you want to do. Select system repair and follow instructions.
Oct 20, 2012 | Acer Aspire 5920-6335 Laptop
How to brighten screen of laptop acer aspire 5610z without keybord ?
May be there is any facility in control panel depends upon the video driver
Jul 20, 2012 | Acer Aspire One PC Notebook
Acer Aspire 5610Z. Upgraded to Win 7. Screen resolution changes
Your laptop was not designed to run windows 7 or be compatible with it. It may run fine with windows 7 but issues might come up sooner or later like the one you're experiencing.
[EXPERIMENTAL]
Download both of these (as I don't know which one of thsese two your laptop needs). Keep mind that doing the following could render your system inoperable and use at own risk. When downloaded, extract ZIP , open desired folder and find SETUP or INSTALL program. Right click and choose properties, then navigate to compatibility mode, then select windows Vista from the menu. Then apply changes, ok and close window and attempt to start.
Acer Aspire 5610Z VGA Intel Driver Vista
Acer Aspire 5610Z VGA NVIDIA Driver Vista
May 27, 2010 | Acer Computers & Internet
ACER Aspire 4730z laptop wont load into Windows
Sep 18, 2009 | Acer Aspire 4730-4947 Notebook
ACER ASPIRE 5610z BLACK SCREEN
You could have a defective screen - follow this to determine the fault.
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Apr 19, 2009 | Acer Aspire 6930-6771 Laptop
Acer laptop wont start
pls try to restore or repair thru backup disk u made when u bought pc
otherwise follow this procedure for restoring the OS without backup disk but data might be lost on C drive only not D or other drives pls take care
cer: When you first turn on the laptop and see the Acer logo screen, hold the ALT key and press the F10 key (you need to do this before the Acer logo disappears).
pls rate FIXYA if it helps
Mar 13, 2009 | Acer Aspire 5720 Notebook
My Acer Aspire 5610z laptop drivers are corrupt
Hi Garvoyee, try this program which will help repair your windows registry& blue screens;
http://www.zaperrors.com/?t202id=911719&t202kw=code%2039&gclid=CP2Y1_3cw5gCFQpuGgodSBwR0g
Below is Acer link: (Drivers for both XP & Vista) There is no 5610z, only Aspire 5610.
http://support.acer-euro.com/drivers/notebook/as_5610.html
Feb 03, 2009 | Acer Computers & Internet
ACER Aspire One screen black out after start up.
OK, Not sure about the Aspire One, But I had the same problem with the Aspire 5610Z.
I simply found the Bios battery and with a small screw driver, created a short circuit of the bios by touching the two leads (just for a couple seconds) from the Bios Battery to the Motherboard. And It Works Fine Now!
Be sure to Disconnect all power from the laptop, and remove the Battery before doing this.
You can do as I did and download a free manual of your laptop which shows you where the bios battery is located.
Good Luck ô¿ô
Dec 27, 2008 | Acer Aspire 5610-4648 Notebook
START MENU AND KEYBOARD PROBLEMS ACER 5610z
Check to see if this happens when booting into safe mode.
Jun 05, 2008 | Acer Aspire 5610-4648 Notebook
MY VISTA WINDOWS WONT LOAD
Okay, I think I can help you but I need some more information. I'm assuming your Acer laptop currently has a version of Windows XP installed, yes? And Acer gave you a CD to upgrade your OS to a version of Windows Vista?
And when you mean that you go to your BIOS to access the CD, I'm assuming that you are talking about the boot options menu (selecting the cd drive vs the hard drive or floppy drive or what not) correct?
When you select the CD drive to boot from, what exactly happens? Do you get any error message? Does the computer turn off? Does it appear to try to load from the CD and then switch to your hard drive instead (and load your existing operating system)?
Nov 08, 2007 | Acer Aspire 3680 Laptop
Acer Aspire 5610-4648 Notebook Logo
309 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
