Question about Kenmore Elite HE4 Electric Dryer
How do I balance the drum in the dryer. I vacuumed the interior of the dyer to clean it and all was ok. When I whent to start it the motor locked up and the drum was not turning. I removed the drum belt and tested the motor and it works fine. I reinstalled the belt but it seems the drum is restricting the motor from turning. Any help would be appriciated. Thanks, Mark
    Scholar:
  • 103 Answers
Did you pull the drum out when cleaning this unit, if so the when you put it back in you got it off the wheels in the rear or the sliders/wheels on the front. Either way pull the from panel again and as you do pay close attention to how the drum is sitting on the front frame and rear supports. You may have damaged the drum, check to make sure that you didn't split the drum.
Posted on Oct 01, 2009
Lg dryer fuse keeps blowing but the heating element and thermostat all have continuity
I have been using an LG domestic dryer in a commercial application (motel) for 5 years and the only problem has been a lint build up inside the dryer because of an improper vent installation. The problem is likely in the dryer drum motor, it runs for a short time heats up because of bad motor bearings, improper motor cooling or bad drum bearings (motor drives the drum) increased heat = increased amperage= blown fuse. Motor should go out on overload but it may blow a fuse first. Is the fuse in the electrical panel or in the dryer? Try turning the dryer drum by hand and check for resistance, there shouldn't be much. The motor needs to cool so pull the dryer panels apart and vacuum the inside first and make sure the motor and interior has been thoroughly cleaned. Try this for a quick fix first.
Jan 31, 2015 | LG DLE3777 Electric Dryer
Dyer not spinning, taken it apart, belt seems fine and on pulley. Could it be timer switch?
It could be your motor. Ifyour dryer is not starting then it is your motor. To determine this there is a trick you cantry. First, put a piece a tape over thesafety switch on the dryer. Take onehand and spin your drum of your dryer as your press the start button.
May 15, 2011 | Dryers
Dyer motor in our LT7000XTHO quit - faint hum when start is activated. Does this motor have brushes or is there another problem?
you may have a bad bearing on the tumbler
dryer motors do not use brushes but you may have a bad start capacitor or start switch
If I were you I would check that the drum is turning free and the drive belt is complete and on place
Mar 09, 2010 | Dryers
Install dyer belt MAYTAG
Hello there
Here is a detailed instruction for you ok
  1. Remove the two screws that hold the control console to the dryer; they are located on each end of the console. Turn the control console forward onto its face. Disconnect the wiring harness from the dryer to the console. Press in on the locking tab and pull the connectors apart. Set the control panel out of your work area. To remove the top, insert a putty knife between the front and top panels. Locate the retaining clip and push in on it to release the corner of the top panel. Lift up on the corner and release the opposite retaining clip. Set the top panel out of the way. Two screws that attach the front panel to the sides are located at the top corners. Remove the screws and swing the top of the front panel out so that you can access the door switch wiring harness. Disconnect the wiring harness from the door switch and lift the front panel away from the dryer.
  2. Replace the Belt
  3. Locate the idler pulley by reaching behind the drum and motor assembly. Using your hand, push the idler pulley to the left to release tension on the belt2.gif. Notice the routing of the belt around the motor and idler arm for reference when attaching the new belt. Remove the belt from the motor pulley. Lift up on the drum slightly and remove the belt from the drum.
    With the rib side pointed inward, lift the drum up and set the belt around the drum. Route the belt through the motor pulley and idler pulley. Pull the idler pulley to the right to reapply tension to the belt. ok?
  4. not too hard
  5. hope this is verry helpful for you
  6. Best regards MIke
Oct 15, 2009 | Maytag PYE4500AY Gas Dryer
Gas dyer won't start, have to kick start it.
If your bearing,glides, and idler are all fine then your motor is gone.
You could apply some zoomoil to that motor but you will have to drill some access holes as the manufacturer does not provide any. For $150 bucks a pop I would try a $2 bottle of High temp zoomoil from ace hardware first.Use a 1/6th inch drill bit and do not hit the shaft. The bearing wells are on either side of the motor and you will have to take the drum out to get to the motor. To access the dryer innards open the door and remove the screws holding down the top. Get the top out yer way and remove the front. Get the drum out and clean out the dryer. Send me any folding money you find. LOL You may find enough change in the dryer to buy some oil. Zoomoil is use for HVAC. It is heat resistant and does not disapate. After filling each bearing work the motor by hand till it loosens up. Oil the idler check the slides and the rear bearing for wear.743d531.jpg
Mar 10, 2009 | Frigidaire Dryers
My dyer is not turning. it makes a noise like the motor is trying to turn but does not have enough to do it. my husband took it apart, belt seems to be ok, but when he took off the top he can spin the drum...
Either the motor windings have too much electrical resistance or the start windings are shot. Replace the motor and install a new belt while your at it.
TIP OF THE DAY--To reduce the suction draft and drying time your drier and save some cash, remove the lint catcher and take it to the sink. Run water into it, if there is excessive pooling of the water (water not running straight through) then fabric softener is fouling the lint screen. Use a small brush and dish detergent to clean it and then shake off all the water and dry the screen. Remember this tip on future driers and you will make the dryer blower motor last much longer.
:?) DRRXR
Jan 31, 2009 | Dryers
How to open the dryer and replace the belt
all dryers open from the top so open the dryer door and look inside the top edge you will see two screws . remove the screws and lift the top panel . the front panel has two screws on the top one on the left and one on the right remove them both and lift up the front panel to remove it. the only way you can install the new belt is removeing the front panel because the belt goes around the drum from the front. once you remove the old belt out put the new one in . the belt goes around the drum from the front and then to the motor and idle roller . you can reach the idle roller from the front left corner or from the back of the dyer? i like to install them from the back cause its more easy. in the back of the dyer where the hose goes connected to the blower is the top with four screws remove the hose from the blower tube and remove the four screws. after you remove everything you should be able to see the dryer motor and idle rooler put the belt over the motor first then over the idle rooler .always make sure when you do this the dyer is unpluged and after your done plug it back and turn it on to make sure it runs correctly . if it runs ok put everything back together again.
Dec 21, 2007 | Dryers
Kenmore Elite HE4 Electric Dryer Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
