Question about Poulan Pro 42CC 2 Cycle Chainsaw, 18"
My Poulan chainsaw is hard to start and will not re-start once it is warm. Any suggestions besides junk it.
    President:
  • 2,220 Answers
Spend $ 40 for a tune up at a local chainsaw seller/mechanic. Most Stihl outlets are very good. It sounds like carburation needs adjustment, but they also do a good visual inspection. Mine get done about every 3 years worth of use. HTH
Lou
Posted on Sep 30, 2009
  • dontbother10
    dontbother10 Sep 30, 2009
    They put in a new plug too. If you do this ask the fuel/oil ratio used to tune your saw. Continue with the same ratio until your next tune up
I HAVE A NEWER POULAN PRO CHAINSAW.STARTS AND RUNS FINE FOR 10-15 min. THEN DIES AND WON'T RESTART UNTILL COLD. THEN IT REPEATS THE SAME PROBLEM.
If it pulls easier than it used to when you try to start, you have low compression. Once the saw warms up, it doesn't have enough compression to run. If that's the case, there is no easy fix, it needs piston rings.
Dec 11, 2016 | Poulan Garden
Poulan chainsaw starts but won't stay running
Try choking it a little longer and it will warm up and should run
Jul 25, 2016 | Poulan Garden
Poulan pro brushcutter ppb150e is starting but cutting off after a few minutes, why is this?
FAQ Trimmers ' Poulan Pro
www.poulanpro.com > Customer Support > FAQ
If the unit has an on/off switch, move it to the on position (usually indicated by the ... This should happen between 1-6 pulls, but no more than 6 pulls. 7. ... Some units use a carburetor which does not require holding the throttle trigger. ... If you smell fuel after following the starting procedure, assume the engine is flooded.
Poulan Pro Trimmer dies when I give it gas.? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
May 22, 2007 - If you remove the two springs holding that cover on the muffler off you can ... Put it all back together and you should be able to crank up and cut. ... Poulantimmer PPB 100 JUNK, since new hard to start cannot keep running ... If, it sit with fuel in the carb then it may still need cleaned with some Carb Spray.
[PDF]OM, PPB150E, 2007-01, TRIMMERS/EDGERS - Poulan
Nov 25, 2015 | Poulan Garden
Poulan Wildthing Chainsaw cord stuck/jammed?
are you sure you mixed the gas/oil mixture properly?and if not the engine might have locked up
May 20, 2012 | Garden
Poulan pro 220 chainsaw owner's manual for tune-up
you could try cleaning the carb and filter. make sure your fuel lines are clean too
Feb 27, 2010 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Poulan Pro 18 inch saw. Once the unit is warm it
start saw when cold and work it hard. if it stalls or quits remove spark plug and hook the plug wire to the plug and ground to the cyl head have switch on and pull the start rop briskly a few times or use a test plug. if there is no spark disconnect ign switch from from the ign wires and pull rope a few more times.spark?= replace ign switch,no spark until engine is cool,replace coil.
Sep 23, 2009 | Poulan Pro Chain Saw 46cc 20"
Recoil has hung up twice on new saw never got to use it
Return it to the bix box store where you purchased it; get a refund. Find a chainsaw shop that sells and services their product.
Lou
Sep 08, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Poulan wild thing will not start
check the fuiel filter in the gas tank, it might be dirty, or need to be replaced
Jan 19, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Poulan 295 chainsaw won't start when warm
Hi
Check the spark plug first (when the engine has warmed and died).If you have a good spark,check the fuel pump from the carb(it shuld not to be tighten).If everything is ok check the seals(they are sealing the engine).Good luck!
savumihai71
Dec 11, 2008 | Garden
Poulan Pro 42CC 2 Cycle Chainsaw, 18" Logo
2,331 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
