Question about Lexmark X6170 All-In-One InkJet Printer
Won't print unless you turn power off and then on again
I have a 2004 Dodge Neon and I just replaced the battery and for some reason sometimes when I'm running a lot of errands when I turn it off it won't turn on again. It won't even make any noises...
Something is wrong in your start circuit. From battery to ignition switch, and ending at the starter solenoid. You would have to start checking for where power is lost between the switch and the starter. If you have power to the starter solenoid on the small wire at the starter (can check with a test light while someone holds the key in start), then the starter would need testing.
Jun 08, 2013 | Cars & Trucks
Our Data light keeps flashing and the printer won't print. How do we get the data light to stop flashing so we can use our copier again with our computers?
Sounds like a bad print job stuck in a print spooler.
Turn off copier. Go around to all computers that print to it and open the print queue. delete all print jobs. reboot each PC. Power up copier and see if it clears
Jan 15, 2013 | Sharp Mx-M450nb Digital Copier
MY COMPUTER SHUT DOWN UNEXPECTEDLY AND WON'T TURN ON AGAIN
I usually try to hold the power button for >5 seconds to reset it. No lights even when plugged in?
Jan 01, 2013 | Computers & Internet
Printer won't print, says it does not recognise the cartridges. it flashes 1 then a C then an e. HELP.nd a C
The problem could be due to a communication failure between one of the printheads (cartridges) and the All-In One (AIO) or by a short in one if the printheads. Please follow the steps below to identify and fix cartridge issues:
  1. Make sure the printer is on.
  2. Open the printer cover. The print cartridge carrier moves and stops at the loading position, unless the All-In-One is busy. Note: If the carrier does not automatically move to the center, turn off the printer or unplug the printer from the power source and then carefully slide the carrier to the center.
  3. Remove both cartridges from the carrier.
  4. Close the printer cover.
  5. Re-brick your printer by pulling out the power supply - black box behind the printer where the power cord is plugged in to, and re-plug after 30 seconds.
  6. When the printer turns on, reinsert one cartridge first. Close the printer cover and check for any errors.
  7. If no error appears, reinsert the other cartridge. Close the printer cover.
  8. Replace whichever cartridge is causing the error to appear with a new genuine Lexmark cartridge. Try to print a document again to verify that the problem is fixed.
Mar 03, 2012 | Lexmark X2670 All-In-One Printer
Dell S2500 Laser Printer keeps printing test pages when it's turned on - won't stop unless you unplug it!
do factory reset - Turn printer off, open front cover, hold down Continue and cancel at same time and turn printer back on. Release when ERROR light is lit.
Jan 03, 2012 | Dell Office Equipment & Supplies
Why won't my printer print after I installed the software? It says its ready but nothing will print
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer. Reboot your pc. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer. Then try to print again once the computer fully recognizes the USB connection.
If that doesn't help, try the steps below:
1. Disconnect the printer from your computer.
2. Rebrick (pull out power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds).
2. On your computer, go to Control Panel > Printers and Faxes.
3. Delete the Lexmark print object.
4. Reboot your pc.
5. When your pc turns on, reconnect the printer.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, then try to print/scan again.
Aug 18, 2011 | Lexmark PhotoJet Z705 InkJet Printer
Error code 50c
Cartridge Error 50C
Your print cartridge has shorted.
  1. Power off your All-in-One and unplug it.
  2. Plug in your All-in-One again and turn it on.
  3. Uninstall and then reinstall your cartridges.If this does not resolve the issue then try the next steps.
  1. Power off your All-in-One.
  2. Use both hands to lift up the scanner unit until the scanner support holds it open.
  3. Turn the All-in-One on. The print cartridge carrier moves and stops at the loading position, unless the All-in-One is busy.
  4. Remove the color print cartridge.
  5. Lower the scanner unit until it is completely closed.
  6. If the error message reappears, replace the black print cartridge with a new print cartridge.
    If it does not repeat steps 1-3 and then go to step 7.
  7. Reinstall the color cartridge and remove the black print cartridge.
  8. Lower the scanner unit until it is completely closed.
  9. If the error message occurs again, replace the color cartridge.
  10. If an error message reappears, repeat steps 1-3 and reinstall both print cartridges.
  11. Lower the scanner unit until it is completely closed.
  12. If you receive the error message again, replace both cartridges.
May 26, 2008 | Lexmark X5150 All-In-One InkJet Printer
Television will not turn on
My Sony KV 32HV600 will not turn on, unless I take it for a car ride THen it will turn on and is fine until it shuts off again. Which circuit board should I change or send in for repairs? definately there is a loose contact as you have ezplained. please check connector or some print loose or parts loose in power supply. if it is ok then check h/output section for loose or print break. it is not a major problem &can fixed ar home. no need to change board remove board &check for print. it requires tech knowledge.
Oct 04, 2007 | Sony FD Trinitron KV-32HV600 32" TV
Lexmark X6170 All-In-One InkJet Printer Logo
22 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
