Question about HP OfficeJet 6210 All-In-One InkJet Printer
Printer problem with 6210 all in one.
Printer does not print entire letters along lines of a document. I omits the top portion of capital letters, and does not print complete lower case letters along the same line. Tried tech support, with no luck. Performed all the service items in the printer software. No change. Reinstalled printer driver software. No change.
Any suggestions?
T. Scott
  • scalzi Jan 06, 2008
    Great help. Cleaning the print cartridge was the fix that worked. Thanks very much. I was just about to give up and junk the thing! Scalzi
  • 16 Answers
Try to print a self test page from the printer itself, do these:
  1. Press and hold the Cancel and the Color buttons at the same time.
  2. Release both buttons.
  3. The Self Test Report will be printed.
and check if it is the same output, if yes then follow the steps below:
  1. Some of the ink cartridge ink nozzles may be clogged with dry ink. Use the ink cartridge cleaning service to try to clear them. Follow the steps below:
  2. Verify that there is plain white paper in the Input tray.
  3. Press Setup .
  4. Press Printer problem with 6210 all in one. - c00712200.gif or c00712201.gif to select Tools and then press OK .
  5. or c00712201.gif to select Clean Print Cartridge and then press OK . The unit prints a test page.
  6. Examine the test page. If the print quality of the page is good, stop here. If the print quality appears to be getting better, run the Clean Print Cartridge utility again
  1. If the self test appears better, Increase the copy quality setting (Normal or Best) and try copying again. If the quality is still poor, continue to the next step.
  2. If the quality is still poor, one or more of the cartridges may be low on ink or empty. Follow the steps below to check the ink levels.
  3. Open HP Solution Center .
  4. Click Settings .
  5. Click Print Settings .
  6. Click Printer Toolbox .
  7. Click the Estimated Ink Levels tab
  • Replace any ink cartridge that is low on ink.
  • If the ink levels are not low, clean the cartridge face and electrical contacts at the back of the print carriage.
    1. Open the front of the unit to access the ink cartridges.
    2. After the ink cartridges are at the center, unplug the power cord from the back of the unit, and remove the ink cartridges. The power cord must be removed to ensure that the unit is not damaged during the cleaning process.
    3. Clean the cross-hatched area of the ink cartridge with a soft clean cloth that is slightly dampened with clean water to remove any build up. Avoid cleaning the ink cartridge nozzle plate. Cleaning this area can force foreign matter into the ink nozzles and plug them.
  • With a soft lint free cloth slightly dampened with clean water, clean the copper-colored contacts on the back of the ink cartridges.
  • Allow the cartridges to dry before reinserting them.
  • Close the unit, and plug the power cord back in.
  • Print a self-test page to check the results. Follow the steps below to print a self-Printer problem with 6210 all in one. - c00712200.gifi>
    1. Press Setup Press c00712200.gif or c00712201.gif Press c00712200.gif or c00712201.gif until Self-Test Report displays and then press OK . The self-test report prints.
    If the problem is not corrected by cleaning the ink cartridges, replace the ink cartridge(s).
    IF THE SELF TEST REPORT IS CLEAN, THEN TRY TO PRINT FROM ANOTHER SOFTWARE LIKE PAINT, NOTEPAD AND IF THE OUTPUT IS OK THEN THE PROBLEM IS ON THE SOFTWARE THAT YOU ARE USING
  • Posted on Jan 05, 2008
    WOW nicely done...
    Why is my printer 7310 all-in-one omitting last line of text when printing
    mabe you are printing on the wrong paper size: Your text is set on A4 and you are priting on a letter sized paper.
    May 19, 2015 | HP OfficeJet 7310 All-In-One InkJet...
    How can i get this printer to print larger letters
    Usually, the size of the letters depend on how large you have them in your document. Open your document, highlight the letters you wish to change (or the entire document if you want to change everything) and from the menu bar at the top of the screen, (Usually under "Format") you will find a "Font" selection. Increase the size of the font by selecting a larger number. This will change it on your screen as well as when the printer prints it. You may have to save the changes before printing.
    May 14, 2009 | Lexmark C533DN InkJet Printer
    Having trouble entering wep key for wireless printing. It is stuck on alpha and wont't do numbers. (J4680)
    As you press the keys it will cycle thru the small letters first then the capital of the same letters then numbers just take your time and you will get it to go to the numbers.
    Mar 28, 2009 | HP Officejet J4680 InkJet Printer
    HP printer not printing entire document
    Normal 0 Could have a corrupt driver.
    Disconnect the printer or at least be sure it is turned off. I'd do both and when the CD software program asks you to connect the printer to the USB port, do so and it should again work properly.
    Hope this helps. Bud
    Dec 30, 2008 | HP OfficeJet 6210 All-In-One InkJet...
    A940 printing issue
    hmm..now..that sounds more like a software issue, than a hardware issue. Can you check on all version updates for the software from MSoft, and ensure that the drivers for your printer, by application, are up to date. From what I'm seeing, this MAY not be a printer issue.
    and, if you want, we do this sort of service call remotely. see my link here for more on that.
    http://www.inbusiness4good.net
    There's a profile link on top right, that may be of some value, if this becomes unsolvable from your end.
    Aug 20, 2008 | Dell A940 All-In-One InkJet Printer
    Poor printing quality on text
    so, what sort of text is it you are attempting to print? what program is in use?
    Aug 15, 2008 | Dell A940 All-In-One InkJet Printer
    Print is missing along a one inch width patch for the entire lengh of mdocument
    try a new toner cartridge
    if it doesn't fix your problem then you willneed a new fuser
    it is probably delaminated
    Dec 22, 2007 | HP LaserJet 3055 All-In-One Printer
    HP Officejet 6210
    Hi, I can help you with your printer problem. Please open this document and follow the instructions to the letter. http://h10025.www1.hp.com/ewfrf/wc/fastFaqLiteDocument?lc=fi&cc=fi&dlc=fi&product=12019&docname=c00249509 Let me know how it goes. Good Luck
    Sep 17, 2007 | HP OfficeJet 6210 All-In-One InkJet...
    Tops of characters cut off
    Go to www.fixyourownprinter.com for expert help on this particular problem
    Jul 12, 2007 | HP OfficeJet 6210 All-In-One InkJet...
    HP OfficeJet 6210 All-In-One InkJet Printer Logo
    216 people viewed this question
    mukhtar21 shaikh
    mukhtar21 shaikh
