Question about Microsoft Windows Vista Home Premium with Service Pack 1: Windows
How do i get rid of total security the bogus anti virus software?
  • 103 Answers
  1. Print out these instructions as we will need to close every window that is open later in the fix. Due to this malware infecting Internet Explorer, it is suggested that you use Firefox or another browser when following these instructions.
  2. Before we can do anything we must first end the Total Security process so that it does not interfere with the cleaning process. To do this we must first download and install a Microsoft program called Process Explorer. Normally, we would have you use the Windows Task Manager, but this rogue will disable the ability to run it. Please download Process Explorer from the following link and save it to your desktop:
    Process Explorer Download Link
  3. You should now have the Procexp.exe file on your desktop. You now need to rename that file to iexplore.exe. To do this, right-click on the Procexp.exe and select Rename. You can now edit the name of the file and should name it to iexplorer.exe. Once it is renamed you should double-click on the file to launch it.
  4. Once the program is running, you should be presented with a screen similar to the one below.
  5. Scroll through the list of running programs until you see a process named tsc.exe. When you see this process, select the tsc.exe process by left-clicking on it once so it becomes highlighted. Then click on the red X button as shown in the image below. Newer versions of this executable may be using names consisting of random numbers or characters. If you see a process that is composed of random numbers or characters and has a shield icon shield-icon.jpg or a padlochow do i get rid of total security - padlock-icon.jpg"http://i.fixya.net/uploads/images/padlock-icon.jpg" alt="padlock-icon.jpg" class="h_mi" /> next to it, then you have found the process you need to terhow do i get rid of total security - tsc-process.jpg
  6. When you click on the red X to kill the process, Process Explorer will ask you to confirm if you are sure you want to terminathow do i get rid of total security - procexp-confirm.jpge image below.
    At this point you should press the Yes button in order to kill the process.
  7. Download Malwarebytes' Anti-Malware, or MBAM, from the following location and save it to your desktop:
    Malwarebytes' Anti-Malware Download Link
  8. Once downloaded, close all programs and Windows on your computer, including this one.
  9. Double-click on the icon on your desktop named mbam-setup.exe. This will start the installation of MBAM onto your computer.
  10. When the installation begins, keep following the prompts in order to continue with the installation process. Do not make any changes to default settings and when the program has finished installing, make sure you leave both the Update Malwarebytes' Anti-Malware and Launch Malwarebytes' Anti-Malware checked. Then click on the Finish button.
  11. MBAM will now automatically start and you will see a message stating that you should update the program before performing a scan. As MBAM will automatically update itself after the install, you can press the OK
  12. On the Scanner tab, make sure the the Perform quick scan option is selected and then click on the Scan button to start scanning your computer for Total Security related files.
  13. MBAM will now start scanning your computer for malware. This process can take quite a while, so we suggest you go and do something elhow do i get rid of total security - scanning.jpgdically check on the status of the scan. When MBAM is scanning it will look like the image below.
  14. When the scan is finished a message box will appear as shown in the image below.
    You should click on the OK button to close the message box and continue with the TotalSecurity removal process.
  15. You will now be back at the main Scanner screen. At this point you should click on the Show Results button.
  16. A screen displayhow do i get rid of total security - mbam-total-security.jpgt the program found will be shown as seen in the image below. Please note that the infections found may be different than what is shown in the image.
    You should now click on the Remove Selected button to remove all the listed malware. MBAM will now delete all of the files and registry keys and add them to the programs quarantine. When removing the files, MBAM may require a reboot in order to remove some of them. If it displays a message stating that it needs to reboot, please allow it to do so. Once your computer has rebooted, and you are logged in, please continue with the rest of the steps.
  17. When MBAM has finished removing the malware, it will open the scan log and display it in Notepad. Review the log as desired, and then close the Notepad window.
  18. You can now exit the MBAM program.
Your computer should now be free of the TotalSecurity program. If your current anti-virus solution let this infection through, you may want to consider purchasing the PRO version of Malwarebytes' Anti-Malware to protect against these types of threats in the future.
If you are still having problems with your computer after completing these instructions, then please follow the steps outlined in the topic linked below:
Preparation Guide For Use Before Posting A Hijackthis Log
Associated Total Security Files:
c:\Program Files\TSC
c:\Program Files\TSC\tsc.exe
c:\Program Files\TSC\Sc2C21UvvM.exe
c:\WINDOWS\system32\winsource.dll
%UserProfile%\Application Data\Microsoft\Internet Explorer\Quick Launch\TSC.lnk
%UserProfile%\Desktop\TSC.lnk
%UserProfile%\Start Menu\TSC
%UserProfile%\Start Menu\TSC\Help.lnk
%UserProfile%\Start Menu\TSC\Registration.lnk
%UserProfile%\Start Menu\TSC\TSC.lnk
c:\Program Files\Common Files\System\Uninstall
c:\Program Files\Common Files\System\Uninstall\Uninstall TSC.lnk
Associated Total Security Windows Registry Information:
HKEY_CURRENT_USER\Software\1FD92E3F7C34799BFB075C41DA05D1FE
HKEY_CLASSES_ROOT\CLSID\{D263FA6D-84CC-48A8-9AF6-C664362B7A5B}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{D263FA6D-84CC-48A8-9AF6-C664362B7A5B}
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Run "1FD92E3F7C34799BFB075C41DA05D1FE"
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center "AntiVirusOverride" = "1"
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center "FirewallOverride" = "1"
Posted on Sep 29, 2009
HOW I DELETE VIRUS HALP!!!!!!!!!!!!!!1?
The best way to get rid of a virus is not to get them in the first place by running Internet Security Software. My favorite is Kaspersky Internet Security, I've never had a virus and I go on all sorts of websites.
Since you already have a virus, here are some things that you can do to get rid of it:
First, buy a professional anti-virus software program or download a free one. My favorite free anti-virus software program is AVG Antivirus.
http://www.avg.com/us-en/free-antivirus-download
If you cannot install a software program because the virus is so bad, you can try an online virus scanner. My favorite is Bit Defender's online scanner. It is free to use.
Free Online Virus Scan
Sometimes viruses turn out to be a result of something other than a virus like Malware, Spyware, or Adware. These nasty problems are not always caught by anti-virus programs, so you may need a combination of an anti-virus program and Malware Bytes (also free) to get rid of your problem.
Malware Bytes free edition
Free Anti Malware Malware Removal
Good luck to you!
Jan 04, 2017 | Preschool
I want to get Quick Heal Total Security 2011. But I want some suggestions...can anyone review it?
I do not recommend it. Personally I would go for kasperky. They tend to be up to date with their definitions, and they wont hog up your system memory.
I'm running Kaspersky Internet Security and i couldn't be any happier
Cheers!
May 05, 2011 | Computers & Internet
Wife opened a e-mail from ''security tools'' Now it dominates the computer and does not allow access to norton nor anything (such as remove software) that could help get rid of this problem. It is...
Try start up in Safe Mode press F8. Choose Safe Mode, when at the choice window, to select either Safe Mode Desktop, OR, System Restore, choose System Restore and choose a time before you had the "Problem" and got the Virus, and follow instructions. This should get you back to the time prior to opening the attachment and unleashing the virus. If this doesn't work. please let me know.
Feb 18, 2010 | Symantec Norton 360 for PC (037648318846)
I've got a virus on my inlaws dell. It keeps
Remove any previously installed Spyware programs / download Malwarebytes Anti malware update off internet / disable Antivirus program and install.
Go to safe mode and access Malwarebytes / run through and remove all offending programs. Run a couple of times. Then reboot and run in windows.
Jan 07, 2010 | Dell Dimension 3000 PC Desktop
There are total 29 spyware,trojan rougeand adware viruses in the pc software.how ican get rid of all these please .product is window vista.hp pavilion intel core 2 quad processor
You gave no mention of anti spyware or antivirus programs.
You need to reboot your computer in safe mode (F8) as it is starting.
Once in Safe Mode, run your antispyware, antivirus and antimalware programs. then restart in normal mode and run them again.
If you have none of these programs, try:
Advance system Care
- anti spyware
AVG AntiVirus
Security 360 - anti malware, trojans
good luck
Nov 17, 2009 | Microsoft Computers & Internet
Windows Security won't reconnize my CA Security Suite 2008 Antivirus software. It says my virus protection is not found. All scans done and product is up to date.
Windows does not recognise the software is all. Just turn off the warning in windows control panel.
BTW. Anti virus is a waste of money, a big rip off, you have to visit very dodge sites & download strange looking files to do this. Anyone who is web savey & not a total pervert has no need to worry about viruses. Windows has a decent firewall built in & if you use a router then that probably a firewall too. Any more is overkill & will just slow down your system. So firewall yes but what you have is fine. AV. Get rid of it.
Jul 19, 2009 | Computer Associates CA Internet Security...
Nju viruss tika manaa Mp3 U ntagad meginu vinju parinstaleet
if you are a facing a problem with virus goto http://xviruslab.blogspot.com and click on hot downloads download required version of Quick Heakl Anti VIrus ( For example need including mobile scanning and Data Theft Protection and Anti Phishing go for QUick Heal Total Security else go for Quick Heal Anti Virus Plus) and get rid of all your virus problems.
bye bye
keerthy
Apr 01, 2009 | Insignia NS-DV2G MP3 Player
I want to free downlodable anti virus for nokia 3500
if you are a facing a problem with virus goto http://xviruslab.blogspot.com and click on hot downloads download required version of Quick Heakl Anti VIrus ( For example need including PC to Mobile scanning and Data Theft Protection and Anti Phishing go for Quick Heal Total Security else go for Quick Heal Anti Virus Plus) and get rid of all your virus problems.
bye bye
keerthy
Mar 28, 2009 | Nokia BNIB NOKIA 3500 Classic Unlocked/Sim...
Green color virus message onscreen and the phone is hanging again and again
bye bye
keerthy
Jan 12, 2009 | Nokia N70 Cellular Phone
I need anti virus software for my mobile k559i
Hello Ramana, note this
  1. Trust me,there is no anti-virus software for SE K550i.
  2. K550i is totally built on secure JAVA platform and it doesn't need an Anti-Virus.
Your phone is all ways safe bro !!
Dec 22, 2008 | Sony Ericsson K550i Cellular Phone
Microsoft Windows Vista Home Premium with Service Pack 1: Windows Logo
394 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
