Question about Dell (0Y4801) for Inpsiron 600M, Latitude D600 Motherboard
When I press my Dell D600 power bottun the second LED (that indicated CAPS Lock on and off) on the left side of power bottun blinks but no display, I have tried changing RAMs but no result.
IB4G2008
  • 3587 Answers
SOURCE: Dell D600 latitude will not power up
you can try to replace the motherboard, which is apparently totally UnHappy
Posted on Mar 16, 2008
cheap to fix
  • 404 Answers
SOURCE: Dell D600 Lock Indicators and Volume Buttons not working
you need the dell's keyboard shortcut utility, dells hotkey and dells latest bios.
Posted on Mar 03, 2009
  • 10 Answers
SOURCE: when I press the power button, caps lock, scroll
they continue to blink every 5 seconds until you turn it off? It should blink all lights upon powering on but then remain off,
Posted on Aug 13, 2009
SOURCE: dell inspiron 1501, caps lock and scroll lock
i cant if my mute botton it all was say mute of and i cant hear anything
Posted on Sep 23, 2009
anandsharad
  • 137 Answers
SOURCE: will not boot
click here to find the details.
you may also like to click here
Posted on Oct 02, 2009
Tip
Laptop LED Blink on Startup There are many reasons that a computer does not...
There are many reasons that a computer does not startup or boot into the Windows operating system. If your computer will not start or boot, you will see or hear symptom to indicate the general area of the problem.
Startup Symptom: LEDs blink but does not start
The blinking LED lights on newer computers, or the beep tones on older computers, will help support agent determine what hardware component is not responding properly. The exact meaning of each code varies with the model, and the user cannot change any of the blink or beep codes.
DO THESE FIRST - Perform a hard reset.
If a PC suddenly fails to boot properly, you should perform a hard reset as the first procedure.
1. Disconnect all peripheral devices and remove all USB devices and media cards. You want to test the computer not the accessories!
2. Disconnect the AC power adapter, remove the battery and then press and hold the power button for at least 15 seconds.
3. Reconnect the AC power adapter (but do not connect the battery), Press the Power button, Look for glowing LEDs near caps lock and num lock keys, and Listen for sounds of a disk drive and fan turning.
Identify the number of blinks or beeps
When there is a start-up problem and you see LED lights on the keyboard blink a few times (between 1 and 8 blinks) do the following actions.
Table of Sample Blink Codes
The following table illustrates the meaning of blink codes used on some notebooks. The blink or beep codes on your computer may have different meanings.
Meaning of Sample Blink Codes for some EFI Notebooks:
1) Number of Blink: Continuous Glow, Blinking LED: Battery power LED, Component: Battery,
Error Condition: The AC adapter is attached and the battery is charging, but does not yet have sufficient charge to power the notebook.
2) Number of Blink: 1, Blinking LED: Caps Lock/Num Lock, Component: CPU,
Error Condition: CPU not functional
3) Number of Blink: 2, Blinking LED: Caps Lock/Num Lock, Component: BIOS,
Error Condition: BIOS corruption failure
4) Number of Blink: 3, Blinking LED: Caps Lock/Num Lock, Component: Memory,
Error Condition: Module error not functional
5) Number of Blink: 4, Blinking LED: Caps Lock/Num Lock, Component: Graphics,
Error Condition: Graphics controller not functional.
6) Number of Blink: 5, Blinking LED: Caps Lock/Num Lock, Component: system board,
Error Condition: General system board failure.
7) Number of Blink: 6, Blinking LED: Caps Lock/Num Lock, Component: BIOS,
Error Condition: BIOS authentication failure.
8) Number of Blink: Continuous blink, Blinking LED: AC power adapter LED, Component: Power adapter,
Error Condition: Insufficient power
Common solutions for issues that cause blinking LEDs or beep tones
When the computer can boot into the BIOS, run the memory test to identify other issues.
Check for loose connections and test the memory
Blink codes are often displayed after a user adds memory to the computer but does not seat the module properly. The LEDs may also blink error codes if a hardware component is loose because the computer was dropped or jarred. The problem could be that the stick of memory or one of the memory slots has a bad connection.
Check for loose memory modules
If a memory module is loose or is not making good contact with the memory slots, the computer does not recognize all of the memory. Reseating the memory module may resolve memory failure errors.
on Mar 21, 2011 | Computers & Internet
In dell inspiron 1525 laptop, all light blinking but display not coming
If you mean that your Num lock , Caps lock, and Scroll lock LED's are all flashing then this indicates there is a problem with your motherboard.
Jun 22, 2011 | Dell Inspiron 1525 Notebook
Have a dell laptop but it doesnt start when i push the power key a little lock with the letter a inside blinks what does this mean then the computer shuts off by itself
That icon is the indicator for Caps Lock (aka Shift Lock). When in the operating system (Windows), you can turn the icon on (or should be able to) by pressing the CAPS Lock key, and turn it off by pressing the CAPS Lock key again.
Jun 29, 2010 | Dell Latitude D600 Notebook
My loptop D610 turn on ,caps lock blinks and ater 3 to4 secons it
I would try clearing the cmos battery. It's located under a small door under the laptop battery. Unhook the wire (laptop unplugged) and let it sit for 20 minutes. Hook it back up and try to power up. If that doesn't work www.pcrepairhelp.net has techs that work on laptops.
May 04, 2010 | Dell Latitude D600 Notebook
When I press the power button, caps lock, scroll lock, num lock, power led and hard disk led blink in every 5 seconds
Aug 13, 2009 | Dell Latitude C600 Lcd LCD Display
Dell Inspiro 6400 not starting up
If the Num lock is lit constant, and the Caps Lock and Scroll Lock keys are flashing, the system is reporting a memory error. Power off the system, remove the battery, and follow the user manual from support.dell.com to reseat the memory module(s). If the error persists, you may need to replace the memory and/or the system board of the portable.
Mar 12, 2009 | Dell Latitude D600 Notebook
Mar 03, 2009 | Dell Latitude D600 Notebook
DELL D600NFULLY CHARGED WHEN ON BUTTEN PRESSED NO ACTIVITY
The Caps Lock LED flashing indicates a Motherboard failure on the system
Jun 17, 2008 | Dell Latitude D600 Notebook
Mar 16, 2008 | Dell Latitude D600 Notebook
Computers & Internet Logo
91 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
