Question about Refrigerators
Fisher paykel broken door handle T locks (adjusted with allen key.
  • Refrigerators Master
  • 19,396 Answers
If you want the replacement part , then you need to give us the full model number, and to tell us your location.
Thanks.
Posted on Sep 29, 2009
How to I change handing of fisher & paykel 2 door fridge
Hello friend
Not your machine but this is how it is done for standard Fridges , They are all similar http://www.youtube.com/watch?v=VEcPVbOjdUE
Extract From the fisher & paykel website user guide ....it seems to be all about the handles.
http://www.fisherpaykel.com/vault/pdfs//pdf_usecares/5339_NZ_AU_ActiveSmart__HR.pdf
Door conversion
If you need to hinge your door on the opposite side we recommend that you call your local
Fisher & Paykel Authorised Repairer or Dealer to make this conversion.
ActiveSmart refrigerator models with silver handles need to be ordered at the point of purchase either with left or right opening doors and can not be interchanged.
All other models need to have an appropriate conversion kit for that model refrigerator.
The kit is available from your Fisher & Paykel Authorised Repairer or Dealer. Full instructions are
included in the conversion kit.
This does not apply to French door mode
Sep 11, 2014 | Fisher and Paykel Refrigerators
Oven door on F@P oven not sealing
Check seal on door, and then see if your hinges are adjustable,
May 30, 2014 | Fisher Paykel Fisher & Paykel OB24SDPX1...
How to set up ovendoor
Check to see if you can adjust the hinges, it sounds like you also may not have the door completely set on the hinges
Broken door handle on fisher & paykel e388
look for the model number at the front, bottom of the fridge where the door meets the fridge body (eg 22021-D). Go to shop.onlineappliancespares.com.au and either buy the whole handle ($150) or just the broken lugs ($15)
Nov 17, 2012 | Refrigerators
Fisher and paykel nemo door latch
actually to me it seemed pretty easy ,, i am sure u can do it .
Aug 30, 2012 | Fisher and Paykel Dishwashers
I have a fisher and paykel E522B refridgerator and the door handle is coming off. I need to know how the door handle is attached so I can retighten it
In most case the screws are hidden, some of the handles have a cover that slides up or down, and the others have a little hole cover that have to be popped out and then you can access the screw
Dec 13, 2009 | Fisher and Paykel E522B Stainless Steel...
Door handle are loose
get a 2.5 allen wrench and tighten the bottom side of the handle
Nov 15, 2009 | Fisher and Paykel RF201ADUX Bottom Freezer...
Outside door handle loose - how do I remove inside panel to tighten handle?
I had the same problem with this model. Bluntcow is correct, 2.5mm hex screw at the bottom of the handles (the top one is a fair way in).
May 31, 2009 | Fisher and Paykel E522B Stainless Steel...
Fisher Paykel fridge door handle loose
Yes hello, I had the same problem - similar fridge model.  Mine was the fridge (not freezer) door handle ie. the upper door.  There are no small holes on the bottom of my fridge handle.  Working from the outer door edge, I gently prized loose the plastic trim located under the door.  I didn't take it completely off, just loosened about one quarter of the length, enough to flex the trim downward so that I could then access the phillips head screw that secures the fridge handle from the inside of the door.  The trim will prevent you from using a conventional screw driver to tighten the screw.  I used a screw driver bit which is only 25mm long.  It has an hexagonal end to which I applied a small spanner and voila - the handle is once more secure.  Good luck.
Nov 07, 2008 | Refrigerators
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
