I have a blue flame gas vent free wall heater that does not stay on I belive its the o2 sensor can i replace it?
  • 3,361 Answers
You probably have soot in the gas orifice causing low pressure flame that does not keep the thermocouple energized.
Posted on Sep 29, 2009
My heater runs for about 10 minutes then the flame cuts out and can't be turned on again till it cools down for half an hour...
Hi.
Replace the flame sensor, if that does not fix the problem, check the thermostats, if it cuts off in ten minutes and then restarts when cooling down, then it is either flame sensor or thermostats.
Sep 24, 2010 | Rinnai Desa Vent-Free Infrared Gas Heater:...
Vent Free Blue Flame heater: shuts off
Sounds like a gas pressure problem. Have your gas company check the pressure.
Jan 31, 2010 | Procom (177653) Utility Heater
When it goes to the second and third stage on the dial to make it hotter the flame goes out. If you re-pilot it, it comes right bak on, but it will not stay on the higher settings.
there is a flame rod that looks like a thermocouple at one end of the burner. Pull it back away from the burner toward the front of the heater slightly.This will allow the heater to operate at higher temps without shutting off the gas to the burner. The high limit will still work but the sensor is in the flame to close and is getting to hot as the flames get higher
Jan 03, 2010 | Blue Flame Charmglow 30K BTU Propane Vent...
Vent less gas heater wont stay burning. starts nice blue flame and than goes out no polite lite no flame.
If your heater does not stay burning then you should check each of the internal components over to ensure that they are working properly. Look at your heater's manual to do this. Failing this, the best thing to do is to buy a new one as the cost of repairing one can cost loads of money. Good luck :)
http://www.ventless-gas-heaters.com
Nov 29, 2009 | Desa International Comfort Glow Infrared...
It ignites but then goes out...like not enough gas is getting through
Sounds like the flame sensor needs to be cleaned or replaced.
To clean it, first turn the power off and take a piece of fine steel wool and rub it up and down the sensor. That should fix it if it doesn't then you need to replace the sensor.
Aug 10, 2009 | Rinnai Desa Vent-Free Infrared Gas Heater:...
Blue flame heater pilot wont stay lit
There is a therma-couple that the flame burns against. When it is working correctly it allows gas to travel to the flame. When it goes out you get no gas, as a safety feature. Replace the therma couple and it should work again.
Oct 06, 2008 | Dyna-Glo D-E36 Infra-Red Wall Mounted...
Natural Gas Heater Dyna-Glo
it s the thermocouple excannge it should solve the problem , try national energy they do spares
Feb 16, 2008 | Dyna-Glo D-E37 Wall Mounted Panel Heater
Glo-Warm Wall Gas Wall-heater parts...
We had a problem keeping the pilot light to stay on, and this site recommended that it could possibly be the thermocoupler that was causing our problems also. We ordered the thermocouple, put it on,hooked it back up and it worked great! Thank you so much.
ordered thermocouple from www.masterparts.net
Nov 19, 2007 | Rinnai Desa Vent-Free Infrared Gas Heater:...
Heating & Cooling Logo
155 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
