Question about Kenmore 57029 Side by Side Refrigerator
After changing the filter the ice maker would not work.
    Problem Solver:
  • 18 Answers
It needs to get the air out of the line before the water will fill the tray. When the line is opened up air will get inside and needs to bleed out first. On units with a water dispenser it is good to run it after a filter change to make the ice maker usable faster. An ice maker times the water for a fill not the amount of water since it uses a pressure regulator, so it does not know there is air in the line.
Posted on Sep 29, 2009
shaggyrat
  • 1224 Answers
SOURCE: Ice maker not getting water after changing filter
Check the following:
 Is the freezer door closed completely?
 Is the ice storage bin installed correctly?
 Is there ice in the storage bin?
 Has the ice frozen in the storage bin?
 Is ice stuck in the delivery chute?
 Has the wrong ice been added to the storage bin? Use only
cubes produced by the current ice maker.
 Has the ice melted around the auger (metal spiral) in the
ice bucket?
Dump the ice cubes and clean the ice storage
bin.
 Is the ice dispenser stalling while dispensing “crushed”
ice?
Change the ice button from “crushed” to “cubed.” If
cubed ice dispenses correctly, depress the button for
“crushed” ice and begin dispensing again.
 Has the dispenser arm been held in too long? Ice will stop
dispensing when the arm is held in too long. Wait 3 minutes
for dispenser motor to reset before using again.
The ON/OFF switch is located on the top right side of the freezer
compartment.
To turn the ice maker on, slide the control to the ON (left) position.
To manually turn the ice maker off, slide the control to the OFF
(right) position.
NOTE: Your ice maker has an automatic shutoff. The ice maker
sensors will automatically stop ice production, but the control will
remain in the ON (left) position
REMEMBER:
 Allow 24 hours to produce the first batch of ice. Discard the
first three batches of ice produced.
 The quality of your ice will be only as good as the quality of the
water supplied to your ice maker. Avoid connecting the ice
maker to a softened water supply. Water softener chemicals
(such as salt) can damage parts of the ice maker and lead to
poor quality ice. If a softened water supply cannot be avoided,
make sure the water softener is operating properly and is well
maintained
The Dispenser Lock (on some models)
Your dispenser can be turned off for easy cleaning or to prevent
unintentional dispensing by small children and pets.
NOTE: The lock feature does not shut off power to the product, to
the ice maker, or to the dispenser light. It simply deactivates the
dispenser levers. The ice and water dispensers will not work.
Style 1: Press the LOCK BUTTON to lock the dispenser. Press the
UNLOCK button to unlock the dispenser.
Style 2: Press and hold the LOCK OUT button to lock the
dispenser. Press and hold the LOCK OUT button a second time to
http://www.ajmadison.com/ajmadison/itemdocs/2261717.pdf
Posted on May 15, 2008
  • 10865 Answers
SOURCE: Ice maker not working
If your ice maker has stopped producing ice completely, check these, in this order:
  • It may be turned off. Look for the wire along the right side of the ice maker that looks a bit like a coat hanger. If the wire is in the raised position, the ice maker is turned off. If so, try one of these:
    • If your ice maker has a small red plastic lever, lower it to lower the wire.
    • If there's no plastic lever, simply lower the wire.
    In either case, the ice maker should begin producing ice again. Also make sure that the temperature is 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won't cycle properly.
  • The ice maker fill tube may be blocked with ice. If so, melt the blockage using a hair dryer-but be careful to not melt any plastic parts! Also replace the water shut-off valve or water-inlet valve, or both, if necessary.
  • The ice maker head assembly may have broken parts. Look to see if the gears are broken. Check to see if the small plastic arms that rest against the ice rake are broken. If the ice maker head assembly is modular and you've found broken parts, you can just replace it.
Posted on May 30, 2009
  • 1073 Answers
SOURCE: GE GSH22SGRE - water dispenser not working but ice cube maker working fine
check the water valve on the back of the ref. it sends water to the ice maker and water in the door one can work and the other one not
Posted on Apr 30, 2008
I just used the hair dryer and it worked the water is flowing again out of the dispenser
Posted on Dec 19, 2008
SOURCE: Maytag plus MSD2756GEQ ice maker not working
I had similar problem in that the fan in the freezer that blows freezing air into freezer and over to fridge was not working. Fridge was running warm (over 40 deg and freezer up near 20) Service call around $160 with new fan.
Posted on Apr 12, 2009
Ice maker doesn't work after changing filter
The filter and the ice maker should not have anything to do with each other unless you raised the wire shut off on the ice maker and did not put it back down after changing the filter.
Apr 22, 2017 | Refrigerators
Ice maker doesn't work. changed filter. light on ice maker door still on.
You need probably to change the dispenser solenoids which swith water on dispenser
Apr 05, 2008 | Jenn-Air JCD2389G Side by Side...
Ice maker no longer making ice after changing filter,GE Eterna ESS25LG refrigerator
recheck filter install is water valve on and is ice maker itself on
Jul 24, 2016 | Refrigerators
pour water in your ice maker. when it dumps ice cubes, keep filling it up again.after 5 or 6 times it should start working on its own
Oct 21, 2012 | Frigidaire Refrigerators
Do i need to change the filter in order to get the ice maker to work? the water still come out but not into the ice maker. please help!
no you donot need to change the filter first. all of the water goes through the filter first. you either have a bad water valve for the ice maker. a bad ice maker. or bad optics that sense the ice bin on the door is full. can you move the ejector blades on the ice maker? that will tell you if the ice maker gear is broken.
Apr 25, 2010 | Whirlpool GS6NBEXR Side by Side...
Whirlpool Side by side Ice maker
check water valve for ice maker how old is the ice maker is more than 3 years then it might need replacement as well
Nov 03, 2008 | Refrigerators
Changed filter, red light flashes, not making ice at all
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
kjkjl
Aug 08, 2008 | U-Line Refrigerator Ice Maker
ice bucket?
bin.
ice?
compartment.
(right) position.
REMEMBER:
maintained
May 15, 2008 | Whirlpool GS5SHAXN Side by Side...
Apr 30, 2008 | Whirlpool ED2FHEXN Side by Side...
Kenmore 57029 Side by Side Refrigerator Logo
354 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
