Question about Samsung Digimax L730 Digital Camera
Camara been fully charged but wont power off,
Camara been fully charged but wont power on, camera lens is half open
jugnu
  • 30 Answers
SOURCE: Camera Wont Turn on
Please eject camera battery and clean with a pin your battery tip in your camera with care fully.d36f20d.gif
Hope its helpful to you
Posted on Oct 17, 2007
SOURCE: Samsung digimax D103 10 million pixel camera
This error is due to the lens mechanism being jammed and unable to extended, usually due to dirt or grit getting inside. The motor times out and the camera beeps 3 times before shutting down.
If you are unable to have Samsung fix this under warranty, you can carefully prise the lens out using a feeler gauge while powering the camera on, giving the motor a little help.
Posted on Jul 13, 2008
SOURCE: The lens on my L730 digital camera does not open.
Hi, I had exact the same problem with mine Samsung L730. I opened it and took the 2 flatcables from the circuit board (to the lens-unit) out of there connectors. After I put them back in again, the camera worked. I geuss it was a bad electric connection of the lens-unit. Maybe this will solve your problem. If the camera is older than 1 year and has no warrenty, just try this. Good luck.
Posted on Jun 03, 2009
  • 5 Answers
SOURCE: L730 wont turn on, lens stuck half way
i had this problem. what i did was, i used a small screwdriver (like the ones from a tech deck :D) to open up the camera. i then turned the camera on and twisted the lens at the same time and it became free. just fixed it today even though its been broken for a year!
Posted on Nov 29, 2009
BillB-SA
  • 2761 Answers
SOURCE: Battery is fully charged but camera does not work
If the camera has recently been dropped you may have lens damage that is preventing it from powering up. If it hasn't been dropped your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera and give them a full charge (assuming that you are using rechargeable batteries). This cleaning clears the problem about 90% of the time. If it doesn't work for you, your batteries may need to be replaced or the camera may have a problem that requires professional repair.
Posted on Dec 09, 2009
My camera lenes wont stay open
Usually the lens closing is a sign that the battery is dying. If there's not much power left for the camera, it will first close the lens so it's protected before powering down. Make sure you have fresh batteries, fully charged. If the battery is going bad it may not hold a charge for very long but appear to be charged when you first intall it.
Dec 25, 2014 | Kodak EASYSHARE M340 Digital Camera
I turn on my camara and then the lens makes a noise and it turns of right away,i charge the battery (fully) and it still turns off
maybe because you have a lens error trouble, Lens errors (system errors) are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...Here are some troubleshooting steps that you can try that may (or may not) correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them:wish you luck thanks
Feb 21, 2012 | Sanyo VPC-X1250 Digital Camera
The camara got wet. We removed the battery and let the camara open (lens out) to get dry. After it was dry, we put the battery back in (fully charged) but we can not close the lens any more. Non of the...
I would put the camera into a bowl of rice (sounds crazy, but it works). The rice will **** the remaining water from the camera. If you are still having problems you will probably need to replace the camera.
Aug 05, 2011 | Sony Cyber-shot DSC-W200 Digital Camera
My Ricoh R7, the shutter is jammed and wont close or open, its stuck half way. I live near Glasgow. Know where I can get a repair done?
If you are sure that your battery if fully charged but still does not do any good, then do this little trick:
1. Hold the camera on your right hand with the lens facing the ground.
2. As you press the power on button, tap or hit the camera's base to your left palm. Do this several times.
Chances are, there could be a sand or granule of dust that got stuck on the sides of the lens, preventing it to retract properly.
Hope this helps.
Nov 03, 2009 | Ricoh Caplio R7 Digital Camera
My camara wont turn on
Here are the steps:
1. Make sure you will install a new or fully charged battery/batteries into your camera.
2. Clean the battery contacts.
a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth.
b. Reinstall the battery/batteries into your camera
3. Without the memory card,turn on your camera.
If issue persists, call 1.800.235.6325 for repair.
Thanks.
Neerak21
Aug 27, 2009 | Kodak EasyShare M863 Digital Camera
Lens cover only opens half-way
If the lens barrel isn't fully extending on power up, that will prevent the lens cover shutters from springing open. There is a stationary prong that pushes the cover closed when the barrel is retracted.
Does the camera work otherwise? Take pictures thru the half open lens?
Jun 15, 2008 | Panasonic Lumix DMC-LZ7 Digital Camera
I have a sony cybershot DSC-P200 an while using it at the weekend it just froze on me the shutter closed half way and wont go any further it was fully charged and charged again when i got home and still it...
Hey pauline04,
There are a couple of reasons you would be told to turn the camera off and then back on. I would first make sure the battery is fully charged, and if it is not I would charge it. The most common reason for this message is something is obstructing the movement of the lens (i.e. sand), which can sometimes be fixed by blowing compressed air into the side of the lens in hopes to dislodge what is stuck in the lens. If neither of these options works you could try a manual reset of the camera by pressing the reset button inside the memory card compartment with a pointed object, and then turn the power on. If this works it will reset the camera to the factory specifications. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
Jun 13, 2008 | Cameras
Casio EXILIM camera lens will not extend fully!!!
Try plugging the PC interface cord into the external connector. No need to hook it up to your computer, just plug it in and out a few times. Then try to power up the camera.
Good luck.
Zductive
Jun 02, 2008 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Lens stuck halfway open
Fully charge the battery or connect the camera to the power supply (if you have an ac adaptor).
If it still does not work, it means that the lens is broken.
Reason can be that the camera was in your pocket pr carrying bag and the camera inadvertantly open and the lens mechanism was damaged. In this case, it needs repair.
Apr 21, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
Casio EX-Z55 wont turn on after lens error
A lens error is something that can only be fixed my sending in to the repairs department. There is nothing that can be done at home to fix that.
Nov 29, 2007 | Casio Exilim EX-Z55 Digital Camera
Samsung Digimax L730 Digital Camera Logo
82 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
