Question about Maytag PAV2300 Top Load Washer
I have water leaking out of the bottom of the drum. We came home one night and the floor and carpet were all wet after running a load of laundry. My husband and I,after cleaning up the mess, investigated and and could not find the problem at that time. We checked the hoses, both water and drain, we filled the tub and drained it. Still we couldn't get it to leak again. Well I went to wash clothes this morning and low and behold it started leaking after the wash cycle. We drained it and removed the clothes. We then took the front off and looked at the drum. When we filled it and moved the drum we saw the drum was leaking at the base. It appears it has been leaking a little bit for a while because there is some rust and splash marks on the inside of the shell. What do I do.
    Genius:
  • Maytag Master
  • 1,467 Answers
Could be damage to drum ie hole in it .Pour some water in to it with a kettle or alike, this should tell you..Is it quite old or has damage happened due to coin,,Kind regards...
Posted on Sep 29, 2009
Magkakatuluyan ba kami ni shelumiel
Instructions
things you'll need:
* Laundry detergent
* Clean cloths
* Measuring tape
* Plywood (if necessary)
* Wrench (if necessary)
1.Verify that the Kenmore top-loading washing machine is completely plugged into a grounded, three-prong power outlet. Reset the fuse or circuit breaker, if necessary; do not plug the washing machine into an extension cord.
2.Make adjustments to the feet on the washing machine if it is shaking or vibrating. The front and rear feet must all be touching the floor evenly. If the floor under the machine is flimsy and cannot adequately support the washer, set a 3/4-inch piece of plywood under the machine for better stability. Load the tub evenly when placing items inside the washing machine and do not overload the tub.
3.Examine the washing machine drum, including between the inner and outer basket, if the machine is clicking or rattling during use. Remove loose objects from inside the drum. If objects are caught between the drums, unplug the washing machine and pull the items out with a pair of pliers, if possible.]
4.the fill hoses behind the washing machine if there are water leaks and ensure the drain hose is connected to a laundry tub or drainpipe. Look at the plumbing throughout the home for drainage problems and correct as necessary.
5.Turn on the water valves behind the washing machine and clean the water inlet hose screens if the water is not running or filling. Do not overload the tub, and use only high-efficiency (marked HE) laundry detergent in high-efficiency Kenmore washers. Note that energy-efficient washing machines often use less water than other machines; this is normal.
6.Choose a wash cycle with a higher spin speed if the water is not draining as expected or items are extremely wet when washing is complete. Reduce overall load size and select a new drain/spin cycle to remove the extra water from the washer. Ensure the drain hose is properly installed on a drainpipe or tub and is not set more than 96 inches above the floor.
7.Reduce the number or volume of items inside the washer tub if the clothes are not rinsed when the cycle is complete. Verify that the water valves are turned on and the correct type and amount of laundry detergent is used.
Mar 12, 2011 | Kenmore 22422 Top Load Washer
Water lesking from vax rapide carpet washer
i have been using a vax v26 carpet cleaner and the washing water is leaking from the bottom then the solution will not come out has the pump given up?
Jun 07, 2009 | Dirt Devil CE5500 Floor Keeper Upright...
Leaks when being unloaded
I may not have the full solution here, but to avoid (expensive) sub-floor damage, I recommend you do the following.  Assuming that the water is not coming from some dripping between the opened door at the hinge....
-Remove the kick plate that is in the bottom, front of the dishwasher.
Use a flashlight to look for wet flooring.  Run the dishwasher with the kick plate removed, watching for leaks/dripping.  It is possible for a leak to seep under the floor.  If leaking is found, do not ignore it.  Pull the dishwasher, fix the leak or replace the dishwasher.  Remove the first layer of sub-floor under the dishwasher, looking for deeper damage.
You should probably do the same with the carpeted area.  Pull the carpet back and decide if the sub-floor needs to be replaced.  A flooring expert should probably inspect.
Sorry to be such an alarmist, but I have been around floor damage that was unnoticed and ignored.
Apr 14, 2009 | GE 24 in. Profile PDW9880JSS Built-in...
Water trickles into Kenmore front load while machine is off and door is open
sounds like a bad water inlet valve stuck open and permitting watertto enter even though not on, untill you replace the valve turn off water between uses part number 8181694
Oct 31, 2008 | Kenmore Elite 45986 Front Load Washer
There is a water leak somewhere in my 98 toyota camry that leaks into my passenger side floor. There is no sun roof and no visible leaks from the windows or doors. Any thoughts? A/C leak maybe? water...
I am the original owner of camry xle 1998 with wet floors. In 2000 I had drivers side door seal leaking at welt. Removed old door seal and new weather strip on drivers side installed. The door panel was never wet, but wet at bottom of door where there are drain holes...slowly leaking under carpet.
In 2001 later water again. Coming from overflowing A/C evaporator-drain plugged/ tank full of debris. Removed evaporator, cleaned + drain cleaned.
In 2003, driver door seal against window rotted. Removed door panel and found leak at window belt molding at the mirror joint inside + out. Lots of mold under carpet needed to replace! Made a fuss at dealers for reacurring problem and they replaced the carpet for free.
Sep 07, 2008 | 1999 Toyota Camry
Floor carpet in rear is wet.
If it is not the drainage holes from the sunroof as suggested above, then it is almost certainly the seal at the bottom of the door nearest the wet patch. Remove all plastic interior door trim and you will see a rubber seal running around the lower part of the door which prevents water ingress. With age, the seal leaks and water enters the inside of the vehicle at the bottom of the door. It is easily resealed with a suitable sealant from an autoparts' shop. About one hour's labour. Good luck.
Jul 01, 2008 | 2001 Volkswagen Golf
Mildew/Stagnant water smell in washer
you know, this does happen.
run it on a full cycle, warm, with either of these in solution.
baking soda, at 1/10 concentration
non chlorine bleach, at 1/6 concentration
you most likely need to do this more than once, until your nose is happy.
Also, consider doing this at least once every 200 wash cycles.
essential oils have same effect, and do a nice anti microbial as well.
we did this in commercial laundries all the time, as part of standard health code compliance issues.
Feb 18, 2008 | Maytag Neptune MLE2000A Front Load Stacked...
Lg wm1812cw front load washer
We had the same problem- for us it was because we were mixing laundry booster (Oxyclean) with liquid soap in the dispenser. It seems the water running through the tray had insufficient pressure to properly flush the tray out, so residue accumulated on the back & underside of the tray. Our water pressure is good here, and we don't use a water softener or filters that can reduce the pressure. Unfortunately it seems to just be a bad design of the soap dispenser tray.
We also had a problem with water/bleach leaking from our soap dispenser- when we used the bleach compartment in the dispenser we got leaks dripping onto the floor from behind the front cover of the washing machine. It was running down the front of the washer behind the front cover & coming out onto the floor. The repair guy said this was because the dispenser tray was pulled out too far, but the reason we were pulling the soap tray out so far was because the bleach compartment was too far back in the tray to use if we didn't. Now we just leave the drawer partially closed & pour the bleach directly into the soap compartment along with the soap.
Jan 16, 2008 | LG WM1814CW Front Load Washer
Water leaking from wash machine
It is probably a seal that is on or near the bottom of the tub. Dirt and grim wears at this seal over time. The leak is slow so it is hard to visually see.
Dec 09, 2006 | Frigidaire MWS939Z Top Load Washer
Maytag PAV2300 Top Load Washer Logo
175 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
