I have lost the product manual for the strong hd stb 5405. any idea how we can reprogram this as we lost all channels/ connection when we moved things around the house
  • 496 Answers
Posted on Sep 29, 2009
Testimonial: "Thanks heaps for that, didn't expect such a quick result."
Connecting rca tv model#F20352SF to a tv converter box
  • Connect ANTENNA OUT of STB to antenna terminal on rear of TV OR, for better picture, connect 3-wire cable to color coded L AUDIO, R AUDIO, and video outputs on rear of STB and connect other ends to L AUDIO, R AUDIO, and video inputs on rear of TV.
  • If STB connected to antenna terminal of TV, set CH 3/4 switch on rear to whichever channel is NOT used in your area.
  • Connect antenna to ANTENNA IN of STB
  • Connect STB to power and use STB remote to turn on
  • Turn on TV
  • If STB connected to antenna terminal of TV, use TV remote to select channel 3 (or 4).
  • Use STB remote to select SETUP and perform channel search.
  • Use STB remote to change channels.
Oct 23, 2016 | RCA Televison & Video
I have started setup for hd cable. Am connected to hdmi and have picture and sound but am unable to change channels. What do I need to do.
With the HDTV set for an HDMI Input that matches the HDMI Jack that you've connected to the cable HD STB (set-top-box or "converter"), use the cable STB remote to change channels on the STB - not the TV.
You can not change channels of the STB with your TV remote. You may however, be able to program your STB remote to operate your TV. Most will allow you to power the TV on / off; volume up / down / mute; change input (HDMI1 / HDMI2 / ANT / Composite / etc.) and even some of the more complex functions as well. Contact your cable company for more details.
Feb 25, 2016 | Sylvania Televison & Video
Wont receive digital channels after scan non found
Hi Patrick,
You must have a UHF / VHF antenna connected to the antenna input of the TV to scan for digital channels. Most new TV's have a threaded, round 75 ohm coax cable connection for this - but yours might even have connection consisting of 2 small screws to connect a 300 ohm twin lead antenna cable instead. Use which ever yours has.
If you are using this input for the input of a cable TV "set top box" (STB), satellite STB, or similar, you will likely only find a single analog channel (Ch3 or Ch4) after a scan as the scan will only find the output of the STB - which is usually on Ch3 or Ch4 - and not be able to scan the STB channels.
Additionally, the antenna input of the TV will only provide a standard definition picture if connected via coax cable from the STB. It will only provide a high definition picture if connected to a UHF / VHF antenna and a broadcaster is close enough for its signal to be received by the antenna. The way to obtain the best possible picture (high definition) when using an STB for tuning channels is to use an HDMI cable between the STB and TV. An HDMI cable will provide the very best picture and audio signals from the STB to the TV; all over a single cable and is the recommended practice.
I hope this helps!
Dec 26, 2014 | Televison & Video
Hi, I've connected a Philips 42PF9946/79 Plasma TV to a Beyonwiz DP-Lite i Digital Set Top Box. The connection is through a HDMI Cable and TV is viewed on the 'HD' channel/mode. Previous to the Beyonwiz...
@leemcdowall...
your concern points to some adjustments of resolution from your set top box, as we all know all TV'S has fixed resolution doesnt matter what brand and the only way you can change that is through your source which in this set up is your Beyonwiz, please consult their manual and see if you can change the resolution in their video set up page.
Feb 20, 2011 | Philips 42PF9946 42 in. EDTV-Ready Plasma...
Universal Remote Control code for Strong STB
i need the code of strong reciver for remote control
Feb 13, 2010 | Televison & Video
Unable to rescan channels AWA STB 262 set top box.Need to scan for lates channels. Menu button not working. AWA HD Digital Terrestrial Receiver Model STB 262
These STB262 box remotes won't work if they are not hooked up with the 720dpi option (Use HDMI Cable) -
Cheers - compac
Sep 01, 2009 | Televison & Video
Hitachi 42PD6000ta HDMI > Topfield HD STD HDMI issues
call hitachi sounds like you need a soft wear update
Jul 01, 2009 | Televison & Video
Zoom Function and Verizon Fios TV
On the verizon FIOS tv box, turn the FIOS STB on, and turn on the tv, tap the following buttons on the Verizon FIOS STB )in this order) 1-Power, then Select, then Menu. This will bring up the FIOS STB HD options. Arrow down to 4:3 Bypass and set the bypass option to 480P. Hit power 2 times, once to turn off, second time to turn STB back on. This should on standard channels give you the zoom feature back. This worked on my Samsunf 5053 TV model.
Apr 30, 2008 | Samsung HP-S5053 Television
How to see local channels in HD with a traditional antenna?
If your set does not have an ATSC tuner, for HD, then you need to be using a suitably equipped STB.
Your satellite STB - box - should take in OTA channels and display them as part of its normal operation, tho. It takes in the antenna signal from your roof antenna and displays the HD version of your OTA channels, if it is an HD STB, along with the HD channels it gets from the satellite overhead.
Mr Bob
Dec 19, 2007 | Mitsubishi WS-65809 65" Rear Projection...
Televison & Video Logo
165 people viewed this question
Top Televison & Video Experts
Electro Med Services...
