Question about Dryers
No heat but dryer runs
Ler 5624bw2 electric dryer. No heat but dryer runs. Should I start w/thermostat and cut off?
    Genius:
  • 1,474 Answers
You could check cut off reset if need be it could of course be the element..hope you get on okay
Posted on Sep 29, 2009
  • Dryers Master
  • 3,361 Answers
First verify 220 volts of power to the dryer at the wire terminal where the cord hooks up. Look for a loose or burned connection here also. If power is OK,ohm the TCO and hi-limit thermostat on the heater canister. Ohm the heater. No ohm reading on any of these parts replace them.
My roper dryer REXEW1 runs the cycle but it dosen't heat. how di I fix it?
This is usually caused by a blown thermal cut-off located on the top of the heater housing. It blows and cut power to the heating element when the high-limit thermostat fails. The thermal cut-off must be replaced, together with the high-limit thermostat, if found open. Click on the link below for the detailed instructions in troubleshooting this problem.
Troubleshooting Whirlpool and Whirlpool-Made Electric Dryers (Filter on Top and with Removable Back Panel) Running But Not Heating
Mar 25, 2011 | Roper REX3614KW Electric Dryer
Kenmore dryer blows cold air. I replaced heat element still no luck? model 96263800
It doesn't necessarily mean the heating element is busted when an electric dryer stops heating. The heating circuit is not just composed solely by the heating element, it is composed by the thermal cut-off, high-limit thermostat, cycling thermostat, motor centrifugal switch, and the timer. The first thing to look at when an electric dryer stops heating is the thermal cut-off. It cuts power to the heating element when it blows most likely due to the failure of the high-limit thermostat. The thermal cut-off must be replaced, together with the high-limit thermostat, if found open. Click on the link below for the detailed instructions in troubleshooting this problem.
Mar 25, 2011 | Kenmore Dryers
Dryer wont heat
The problem is likely the thermal cut-off and/or the high-limit thermostat if the dryer runs but doesn't heat. Verify this by bypassing the thermal cut-off and the high-limit thermostat. Click on the link below for the detailed troubleshooting.
Troubleshooting Whirlpool and Whirlpool-Made Electric Dryers Running But Not Heating
Feb 18, 2011 | Whirlpool GEW9200L Electric Dryer
We have a Whirlpool LER 5636 Electric Clothes Dryer - the heating element gets too hot - starts to smell like it is going to burn. We have not used it since. Is it worth fixing? Thank you.
This can be a tricky fix. This could be the timer ? or High Limit Thermostat .First of all, I need you to do something...First, set the dryer to Air Fluff thats with no heat. Run it for 5 minutes see if the dryer is getting HOT. I know it should not but thats what I need to see . Then get back to me.
Dec 04, 2010 | Dryers
LER 5620KQO won't start. Any ideas?
I would think that you either have a bad thermal fuse, Thermal cut off or bad door switch. Most likely a bad thermal cut off.
Nov 17, 2009 | Whirlpool LER5636P Electric Dryer
Dryer will run but does not heat up
Either bad heating element or missing one leg of the 240V circuit. The motor runs on 120V.
Sep 24, 2009 | Whirlpool LER4600 Electric Dryer
Electric dryer has not heat model # ler 4600
Normally caused by bad thermostats and or heating element
Sep 24, 2009 | Whirlpool Dryers
Dryers Logo
51 people viewed this question
Top Dryers Experts
