Question about Panasonic Technics SL-DZ1200 Turntable
The digital turntable is not reading my disks what can I do about it?
The sound is sounding blurry
Posted on Oct 15, 2009
All disks are eject without been read, looks like the engine making the CD's spin does not work.
HEAT THE CDS WARM FROM A DIXTANCE OR TRY TO CLEAN THE PLAYER'S LENS BY CD CLEANER.
Aug 28, 2011 | Pioneer CDJ-100 Turntable
CDJ 800 MK2 - when disk is inserted the disk attempts to spin but does not spin fast enough to read then ejects disk. I have had the transport replaced but this did not fix the problem. Could it be a bad...
For the record I own a pair of CDJ 400's. This is an odd problem as I could only really think of one problem. It may be extremely dusty inside to the point where it is not allowing the spinning of the discs. Try your best to also see if something was jammed in there or if anything at all is stuck. Your going to need to do a bit of cleaning in there and that's honestly my best advice, good luck!
Mar 02, 2011 | Pioneer CDJ-800 Turntable
What's the correct way to use the strobe light to set turntable speed?
The turntable may have a pattern on the edge of the turntable. If not you need a turntable strobe disk that you place on the turntable like a record. The pattern on the disk or on the edge of the turntable will be marked for 50 Hz or 60 Hz frequency.
The strobe marks on the disk or on the turntable are for 33 RPM and 45 RPM and for both 50 & 60 Hz mains frequency.
To adjust the turntable for the correct RPM, turn on the strobe light and the turntable set it to 33 RPM and shine the strobe light on these marks and adjust the speed setting until the 33 RPM marks appear steady and not moving. You may want to check it for 45 RPM as well.
Make sure you use the correct mains frequency marks ie. the 50 or 60 Hz that your electricity system uses.
Feb 25, 2011 | Audio Players & Recorders
My Western Digital Hard Disk is Getting Heated And Also Sometime Creating Noise.....But by far One Most Complicated Problem..My Hard Disk Is Not Detected By My System When Tried Several Times.. My Hard...
> is getting heated
Normal for any spinning device.
> sometime creating noise
Normal when the R/W mechanism moves (like the arm on a DJ's turntable) to read from "random" locations on the disk-drive. In general, "defragmenting" a disk-drive tends to reduce the noise, because the R/W mechanism moves less distance.
> not detected ... when tried several times ... 20 GB
Any 20 GB disk-drive is "out-of-warranty" -- like a bald car-tire, it should have been replaced before it totally "blew".
Does it actually get detected, after a few attempts? If so, then "backup" your files (write to CD/DVD recordable media, or write to USB memory-stick) before it totally "dies". Then, buy a new disk-drive, install Windows onto it, and then reconnect the "old" disk-drive as a "slave" disk-drive.
Copy all your files from the "old" disk to the "new" disk.
Oct 24, 2010 | Western Digital Computers & Internet
Will not read disk
Try to clean the optical lens using a optical head cleaner disc, the lens could be dirty and need to be clean to be able to read disc.
If the problem was still the unit may have a faulty lens and need a professional fix to replace the lens.
Sep 06, 2009 | Pioneer CDJ-800 Turntable
What is Error 9101, on the pioneer MK2 800. and how can it be solve
Error 9101 is a Disk-Read error. More than likely either your traverse assembly, or your loading motor is damaged - or both.
In either case, you'll have to take it to a qualified service center for repair.
- OPTiC
Master Tech
Digital Analog Therapy
Pioneer Repair : Pioneer Parts
Aug 10, 2009 | Pioneer CDJ-800MK2 Turntable
Pioneer CDJ-800 MK2 Disk Reading issue
You might have damage to the reader, and I can only suggest replacing the CD Traverse/Transport assembly.
- OPTiC
Pioneer DJ Repair Videos
Pioneer DJ Repair
Pioneer DJ Parts
DJ Parts
DJ Equipment Sales
Audio Video Accessories
Jul 25, 2008 | Pioneer CDJ-800MK2 Turntable
Panasonic Technics SL-DZ1200 Turntable Logo
79 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
