Question about Philips GEMINI GM-10 MIXER MICROPHONE (xlr connector) Microphone
Is a phillips 22rc026/50b compatable witha dc279/62p head unit fitted in a 2000 renault scenic thanks
4 Suggested Answers
SOURCE: please can you describe process for installing
hi
i am Rohit . just i want a driver of ssd-tv.670 tuner card driver
Posted on Jun 20, 2009
  • 4861 Answers
SOURCE: I need a radio code for my 2000 Renault Scenic.
Try code 1978
Posted on Dec 22, 2009
  • 27 Answers
SOURCE: Renault Scenic, 2000 how to input the code, I have
you will need to use the controls on your steering wheel not your radio. To enter the radio code you will need to locate the 'THUMBWHEEL' and the button below this. Entering the radio code is straight forward, simply switch on your radio, press the bottom button on the 'STALK CONTROL' then rotate the thumbwheel until the first digit of your radio code is shown on the display of your radio, then press the bottom button, next you will rotate the thumbwheel again until the second digit of your code is displayed, then you will press the bottom button, repeat this sequence until you can see the 4 digit code displayed on your radio, once you press the bottom button for the last time (hold it for a second or two) the radio will activate
Posted on Jan 11, 2010
Testimonial: "Indeed you are a master. Thank you very much! we been driving it for 4 months thinking the radio was duff meanwhile it was us being Dorf. Cheers"
Has anyone replaced the cd/radio head unit on a 2006 Mk2 Renault Megane and been able to retain the steering wheel controls and in-dash display using a non Renault radio? Pretoria/Centurion-S.A. area.
I have a 2004 Mk2 Scenic and when I bought it 18 months ago it was fitted with a non-Renault unit and that worked from the control stalks and showed up on the dash. I removed it and fitted the original unit back in as the previous owner wanted to keep the one that was fitted. I can't remember the make other than it was an expensive one. It was a straight un-plug the fitted unit and plug in the old one. No new wiring needed, so I am guessing that as long as you use the fitted plugs then the controls should still work. I hope that is of some help.
Jan 11, 2016 | 2006 Renault Megane 2.0
How do you put codes into the radio cd player for a renalt scenic 2000 modle
hi what you is supply the make of it ie phillips, sony, that sort of thing and the serial number on the head unit then i might be able to help with a code, although, if you have imputed the code incorrectly 3 or more times the radio will become locked out and be unusable as this is an anti theft thing to make it unsaleable to thieves....if you have not put it in 3 or more times then we can see if i can supply a code for you
Feb 26, 2010 | 2000 Renault 181
Scenic power steering not working on right turn.
yes its the pump torque unit you need to replace your pump.sorry
Sep 19, 2009 | 2002 Renault Sportwagon
How do you close the boot window on a 2001renault scenic
It could be that the catch is closed so the wire loop that is meant to fit into it cannot. What you need to do is to get a philips head screwdriver and put it in the catch with a slight outward pressure and click the open button for the window. It should then release open so you now can close the window.
Mar 23, 2009 | 2001 Renault Sportwagon
Rain Sensor wipers Renault Megane
Either the replacement sensor the windscreen technician should have fitted isnt connected properly to the glass or it has developed an intermittant fault - quite common with Renaults especially megane scenics and grand scenics....
Mar 05, 2009 | 2006 Renault Sportwagon
Renault scenic 1.4 2000
new auto choke sensor
Oct 13, 2008 | 2000 Renault 181
1998 renault scenic water pump replacement
to replace the pup the timing belt must be removed. water pump removed. new 1 saled and fitted and t belt replaced
Aug 21, 2008 | 2000 Renault 181
Philips GEMINI GM-10 MIXER MICROPHONE (xlr connector) Microphone Logo
402 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
