Question about Cameras
Used ink cartridge is full and needs replaced or emptied, on a Cannon i560 printer.
jackboy
  • 2985 Answers
SOURCE: Printer will not print.
http://www.fixya.com/support/p169991-brother_mfc_420cn_all_in_one_inkjet See if any of these solutions help
Posted on May 17, 2007
  • 286 Answers
SOURCE: Screen reads "Near empty Cyan" but I just replaced the Cyan ink cartridge, its full.
If the firmware update doesn't work, you can reset this error.
Unplug unit. Remove offending cartridge. Plug unit back in, wait until all startup noises have stopped. Open lid and reinstall cartridge. This will solve the fault as long as the sensor is working.
Also, please be aware, you should not have to change a cartridge if it says "Near Empty", only if it says "Ink Empty Magenta".
Also, please make sure none of your other cartridges are empty. I have seen this over and over. Two cartridges empty at the same time, and the person replaces one of them but thinks they actually replaced the other one.
Turn the power off and pull all the cartridges out. Look a the side of the cartridge, you should see a window with a little plastic tab sticking out. This tab should be blocked by a black float inside the cartridge. If you cannot see the float, and the tab is clear with no ink in it and no float tab blocking it, it means the cartridge is empty even if you still see some ink in the bottom.
To be sure plug the machine in without any cartridges. When all the noises have stopped, open the lid and install the cartridges. If you're still getting an error saying either a cartridge is not installed or is empty, then one of your cartridges is empty. Redo the previous paragraph.
Posted on Dec 30, 2007
graemevm
  • 519 Answers
SOURCE: Colour Ink Jet Cartridges emptying during a black ink print run
If you go to your printer properties, there should be a setting whereby you have to select the option to "PRINT USING BLACK CARTRIDGE ONLY". Make sure this option is selected, otherwise your printer will use ALL colors even if you only print black.
Let me know if you need any further assistance.
Best wishes,
Graemevm
Posted on May 07, 2009
komguy
  • 2306 Answers
SOURCE: The waste ink tank is full. Where is it located?
There's no 3 year clock and those instructions won't reset the counter. The absorber pads are under the print engine and if you did manage to reset the counter with proper instructions, the waste ink will probably overflow and ruin something.
Posted on Oct 02, 2009
nonontech
  • 4737 Answers
SOURCE: Printer won't recognize new ink cartridges
Follow this simple instructions:
Remove all the cartridges, clean the contact points on the cartridges and on the printer using soft brush/cotton dipped in alcohol/acetone/spirit. While they are drying, reset your printer; Turn it off > Disconnect usb cable, power cord, inthernet cable; >remove the papers from the tray >open the back panel door (the rear door where you clear paper jam). Also turn of the main switch which the dc adapter plugged in. After keeping it Off for about 5 minutes, turn on again using only the power cord, and again leave it on for few minutes > turn it off > connect all the cables > again turn it On and keep pressing the power button while it boots up. Now you can install the cartridges.
Good luck.
Thanks for using FixYa.
Posted on Jul 31, 2010
Canon W6400 error message E02525 mean?
If you used a non-cannon refill, the cartridge may not have the microcontroller inside to tell the printer the ink level.
Use replacement cartridges from Cannon or SOPHIA GLOBAL (available from Amazon or ebay).
Jul 31, 2014 | Canon imagePROGRAF W6400 InkJet Printer
After printer said ink cartridge was empty I removed it & found it was not-I put it back in printer & now getting error message that the cartridge is used & needs to be replaced. How can I
your only option it to replace it with a new one . printer mfg's have chipped the cartridges and they can not be reused.unless the chip is recoded as new .
Aug 16, 2017 | Ricoh Aficio GX3050N Printer
The black is not printing but the cartridge is full
Are you sure that you removed the protective film cover from the terminals of the cartridge before plugging it in?
Also make sure it is seated firmly in it's carriage.
If you have an ink level indicator with your printer's software, and it shows the cartridge to be full, then there might be a problem with your drivers. I would re-install them.
If the indicator shows empty, then the protective film just might be on there.
Lyle
May 03, 2010 | Canon BubbleJet i560 InkJet Printer
I refilled my printer cartridges.they are full i did all the diagnostics cannon maitenance said and they are still not printing. it printed for a little bit then it stopped.it says that both of the...
You can't reset the ink level on all Canon Pixma printers.Press the resume button for 5 seconds.This operation releases the function for detecting the remaining ink level of the above ink.The printer shows empty cartridges but it will printing.
Nov 02, 2009 | Canon Office Equipment & Supplies
This is something that needs to be done by a service department..... however it may not be full. Cannon has a 3 year clock on these so you may be able to clear the error code and continue printing.
Waste Error Reset
1: Power off printer
2: Hold Resume button then press and hold POWER, the beeper will sound once.
3: Hold POWER and release RESUME
4: Press RESUME twice
5: When the indicator lights steady, press RESUME three(3) times. The indicator should be orange.
6: Press Power to set data
Sep 26, 2009 | Canon BubbleJet i560 InkJet Printer
Cannon mp180 ink reservoir full
If you do a google search on this you will find all the instructions you need to sort it out. - you will get ink all over your fingers though.
Sep 10, 2009 | Canon PIXMA MP180 All-In-One InkJet...
My error message says the used ink tank is full. How do I empty it?
You can't empty it, it's a set of pads covering the whole bottom of your printer. They only cost around $10.00 but you need a shop to replace and reset the waste ink counter.
Sep 02, 2009 | Canon BubbleJet i560 InkJet Printer
Canon i560 not printing, status light flashes 4 amber 1 green
4 blinks of the amber light says that the ink is empty, at least 1 cartridge is empty.
Jun 21, 2009 | Canon BubbleJet i560 InkJet Printer
Only black cartridge empty, but 3 full color crtrige say empty
Remove the color cartridges. On one end you can see the opaque
ink tank inside the main cart. housing. Cut a piece of black electrical
tape to fit around the three sides visible of the ink tank. Make sure the tape fits inside the housing and adheres to the tank itself. This makes the printer think your ink is always full but you can always tell when you need to refill/replace the ink(right?). Good Luck!
Dec 27, 2008 | Brother MFC-440CN InkJet Printer
Cannon MPC200 Printer
If this is an inkjet printer there is large tank below the home station that fills with ink from the machine testing & priming the cartridges. This needs to be removed and cleaned out. Very messy job! Wear gloves.
Jan 24, 2008 | Office Equipment & Supplies
Cameras Logo
13 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
