Question about Graco ComfortSport 8639 - Grey
We took it apart to clean it and are unable to reassemble the harness. How do the straps go and where do the metal peices fit?
  • 496 Answers
I went to the Graco website and got stuck when it didn't recognize the number 8639.
Here is a link to their product instructions web page. You might need to get some information from the car seat. I hope this helps... Good luck!
http://www.gracobaby.com/customerservice/productinstructions/Pages/default.aspx
Posted on Sep 29, 2009
Need instuction on how to reassemble safety straps on cosco car seat. I took apart to wash seat cover and don't remember how to reassemble
1. Find the same seat at your local store and take photos with your phone.
The position of the harness (slots in the plastic shell) is dependent on the height of your child.
2. Contact the manufacturer for detailed instructions
3. Find a certified Child Passenger Safety Technician or Instructor at safercar.gov.
Jun 21, 2015 | Cosco Scenera Convertible Baby Toddler Car...
I HAVE A CAR SEAT THAT I TOOK APART IN ORDER TO WASH THE CUSHIONS BUT NOW I DONT KNOW HOW TO PUT THE STRAPS BACK TOGETHER
There is normally a splitter in the back, a metal piece with two hooks that is attachted to the adjustment strap. the sholder straps latch onto this. You can locate the appropriate manual here: http://www.coscojuvenile.com/usa/eng/Instructions The pages in the back normally discuss reassembly after cleaning.
Mar 19, 2010 | Cosco Alpha Omega Elite 5-Point 22-155
Cosco Alpha Omega Elite can't get straps back on right!
replace harness: 1) take **** harness and place metel bracket through the base of the seat(slot in shell) make sure buckle is facing out and not inwards. slide metal clip under small tab and push down on clip until it snaps in and locks into place... 2) thread harness without latch plate or harness retainer down through slot on one side of shell, under seat and up through slot on other side. 3) thread latch plate(clip that goes into ****clip)harness retainer onto the harness making sure they are correct. 4) thread harness end through other slot 5) make sure the harness goes over the barbut under the plastic bar, then fit loops on harness ends onto the harness bracket that looks like a triangle(kind of) 6) from the front even up harness to fit properly. And there you go the rest is pretty straight forward the base is pretty sraight forward to attach...
Aug 17, 2009 | Cosco Alpha Omega Elite 5-Point 22-155
Need help reassembling the straps after washing the seat cover
First turn seat upside down. There should be a slot on each side under the seat, run strap through each slot and turn back over. Pull strap up evenly, put on clasp part on each side, then put chest clasps on, run your straps through back and secure to strap comes between legs.
May 08, 2009 | Century Encore 5-point Harness
Harness straps off cosco car seat to wash cover, help reattaching
I need help putting the straps back on a Cosco 5-point car seat. Took it apart to wash and can't get it back together
Mar 08, 2009 | Century Encore 5-point Harness
I need help putting my childs care seat back together
Bring the straps up through the holes on the bottom of the seat, one on each side. The metal plate on the end should pull in flat and snug against the plastic. Slide the buckle pieces back on, making sure they're facing the right direction to snap in. Slide the chest clip back onto both straps. Place the ends of the straps through the slots you want the harness at (at or below the child's shoulders for rear-facing, at or above the shoulder's for forward facing), making sure that they don't twist. Pull them down low behind the seat. The adjuster part of the strap has a kind of Y shaped metal plate - pull it up to meet the ends of your straps, making sure that it doesn't twist, either. There are loops at the end of the harness straps. Feed the curved part of the Y through the loop of the strap that's on the same side of the seat. Pull it all the way through, so that the fatter part on the ends of the metal plate are exposed and curve around a bit beyond the strap so that it doesn't slip back off. Do the same with the other side. Now adjust the harness to fit your child. When it's tightened properly, you should not be able to pinch up any slack, lengthwise, at the hips or shoulders, and it should lie in a straight line down the front, with no drooping. Also adjust the chest clip - it should lie even with your child's armpits - not up in the neck, and not over the belly, where it can't do it's job properly. (It's job is to hold the straps over the center of the shoulders...if it's over the belly, they're likely to slip down off of the shoulders in an accident or sudden stop and also poses the danger of internal injuries.) If you also took the **** buckle out, it goes back in from the top. Turn it so that you can slip the metal plate through the slot, slide it through, and then pull the plate flat underneath, so that it can't come back through. One other thing - car seat harnesses should never be submerged in water, as it can damage and weaken the webbing. They should only cleaned with a damp rag. If you put your harness in water when you washed the rest of the seat, I'd strongly recommend contacting Cosco (contact info here) to order a replacement harness.
Dec 30, 2008 | Cosco Juvenile Scenera Convertible Car...
Having trouble with straps in car seat
Need help with putting straps back on
I know this is months later, but here you are in case you (or anyone else) needs the info again. First, though, I feel that it wouldn't be responsible to neglect to tell you that if you got the seat in 2000, it is expired and no longer safe to use. Car seats generally expire after 6 years because the plastic degrades over time - in a 10 year old seat, it can look fine but actually be brittle enough that the entire harness can rip out of the seat if it's an accident. For the manual, visit Cosco's website and fill in the product number and date of manufacture. It will bring up a PDF file of the manual that you can download. To rethread the straps, first replace the **** strap. Slide the metal plate down through the slot in the seat, with the buckle facing out. Slide the metal clip under the tab and push it down to lock it in place. Facing the seat, start by threading the end of the harness strap down through the slot of the left side of the bottom (where the child's right hip would be). Under the pad/cover, thread it across the bottom of the seat and up through the matching slot on the right side. Pull it until you have equal lengths on both sides. Thread the buckles onto the the strap (one one each end) and buckle them. Thread the chest buckle onto both ends, making sure that the harness doesn't twist. Buckle it, too. Push the ends through the harness slots. Pull the harness through to the back, making sure that it goes OVER the metal bar, but UNDER the plastic adjuster handle. There is a loop sewn into each end of the harness. The adjuster strap has a splitter plate, kind of shaped like a Y. Slide each loop over the ends of the plate and all of the way into the slot, so that the curved ends of the splitter plate are exposed and the strap is secure in it's slot. Adjust the harness height by squeezing the metal bar on the back of the seat (the one behind the harness) forward and moving it and the plastic adjuster bar up or down to the correct position (at or below the shoulders for rear-facing, at or above the shoulders for forward facing). Do note that the very top slot is NOT for use with the harness - it's only to adjust the headrest when the seat is being used as a seat belt positioning booster and is not reinforced to support the harness in an accident! Adjust the tightness of the straps with the button/extra length on the front of the seat. Properly tightened straps should lay in a straight line without sagging and you should not be able to pinch up any slack (lengthwise going down the harness, not across the width of it) at the shoulders or hips. Adjust the chest buckle to lie in line with your child's armpits, never his neck or belly.
Oct 15, 2008 | Cosco Alpha Omega Elite 5-Point 22-155
Car seat straps
ON THE BACK OF YOUR CARSEAT ARE 2 METAL LATCHES ON EACH SIDE. REMOVE ONE BE PUTING THE STRAP THROUGH AND ADJUSTING IT TO YOUR CHILDS FIT.YOU COULD ALSO PUT IT THROUGH A SECONDARY HOLE IF YOUR CARSEAT HAS ONE TO PROPERLY HOLD YOUR CHILD SAFELY.LET ME KNOW IF I WAS ANY HELP...
Jun 03, 2007 | Evenflo Chase Comfort Touch
Infant Rear facing car seat
ON THE BACK OF THE CAR SEAT ARE TWO LATCHES SIMPLY REMOVE ONE BY PUTING THE STRAP THROUGH THE LATCH AND ADJUSTING IT TO YOUR CHILD FIT DO THE SAME TO THE OTHER. LET ME KNOW IF I WAS ANY HELP...
Jun 01, 2007 | Evenflo Embrace
Graco ComfortSport 8639 - Grey Logo
698 people viewed this question
Top Graco Baby Gear Experts
Greg Cann
Greg Cann
Colin Stickland
Colin Stickland
john milligan
Are you a Graco Baby Gear Expert? Answer questions, earn points and help others
