Question about Mitsubishi WS-65905 65" Rear Projection Television
Mitsubishi Projection TV dis-assembly
I inherited a 65" tv from the prior owner of my house. I need to get it out of the basement, but am leery of pulling the top section off, without knowing what type of connectors are inside the cabinet. Considering the size, I know for sure that this thing came in 2 pieces. I'm just not sure how tough it is to take apart. Any technical bulletins or literature would help.
Thanks
When I took mine apart, I had to unscrew all the screws on the pegboard, then there are some screws along the midsection on both sides. Other than that, there weren't any cables or anything to be leary of. It was really pretty easy. Hope that helps.
Posted on Jan 07, 2008
Why won't TV won't stay powered on?
probably not worth it. How many times does the LED flash? That will indicate your failure cause. Problem is this is an old tv and parts are not available or cost effective. Unless its bad capacitors or bad solder you could be looking at rediculous amounts to fix it. Mitsubishi WS 65413 Manuals Support and Troubleshooting TVs
here is a link to the manual. please provide the amount of LED blinks. itll blink a few times and pause.
Feb 04, 2015 | Mitsubishi WS-65413 65" Rear Projection...
Mitsubishi wd-65638 65 in hd tv dlp tv usb i dont no how to work it
I think you need to download the manual for you to easy follow how it works...
try this link:
http://safemanuals.com/user-guide-instructions-owner-manual/MITSUBISHI/WD-65638-_E
try to click the right box and click the boy to the left side...rate and comment then download..
Dec 11, 2011 | Mitsubishi WD-65638 65" DLP HDTV
When you turn the TV on it stops at the blue Mitsubishi screen and the power button just blinks. You have to then unplug the TV to power down. Pushing the power button on the TV or remote will not power...
There is a software update that is available for some Mitsubishi dlp models. The wd-65c9 is one of them. When I experienced your problem, I went to the website, downloaded the update, and installed it on my tv and boom, its fixed. It's super easy, free, and takes a few minutes.
Jan 31, 2011 | Mitsubishi WD-65C9 65" DLP HDTV
Need to dis assemble a ws-65807 tv to move
go here and sign up for a 7 day use ($5) and download the service manual (and schematics and pcb layouts) for your tv
http://www.free-service-manuals.com/members/
Jan 19, 2011 | Mitsubishi WS-65807 65" Rear Projection...
I want to move my 65 inch mitsubishi from the ground floor to the second floor of my house where will i get the instruction on how to disassemble it.
Don't disassemble this tv,it have very sensitive CRTS Tubes assemblies.U take it aparts,it will not funsctions the same way again or not at all.Buy another tv smaller lighter take it up stair.
Jun 15, 2010 | Mitsubishi WS-65807 65" Rear Projection...
Mitsubishi WS-65713 Blinking green light. TV will not turn on!
These Mits TV's tend to have power supply problems that are well documented on the web, when the symptom is as you describe. And this assumes no other unusual noises were heard before the TV went into shutdown.
The repairs are fairly straight forward if you are comfortable with electro-mechanical dis-assembly, soldering repair, and re-assembly.
Just do a search on Mitsubishi (your model number) and capacitors.
Dec 21, 2009 | Mitsubishi WS-65713 65" Rear Projection...
HDTV CABLE NOT HOOKED UP/WORKING
COMP 1 and 2 are for 480i/p sources. Hook it to the 1080i capable on the back. Also make sure the HD DVR is outputting 1080i not 720p. The Mits can not disply 720p and will show a scrambled screen if you try to.
Jan 31, 2009 | Mitsubishi WS-65809 65" Rear Projection...
Yellow status light on mitsubishi wd-65733 tv
When tv goes out, press the menu and input buttons. The green light will flash with a 2 digit code.
Jul 26, 2008 | Mitsubishi WD-65733 65" HDTV
Mitsubishi 65831
sounds like the projector globe is gone. i think you will need to replace it. if you are lucky there should be a pannel on the side or rear of the tv that allows you to replace the globe. pricey though.
good luck
smeags
Dec 31, 2007 | Mitsubishi Diamond WD-65831 65" Projection...
Mitsubishi WS-65905 65" Rear Projection Television Logo
282 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
