Question about Canon Pixma iP2600 Photo InkJet Printer
Need to replace ink cartrige cannot get them to come back to the open area where they can be reached
I would like to replace ink holder belt in epson stylus r220 printer
It's very easy.
uncover the printer. Then look left and right site of the printer. There you find 2 lock in left and 1 lock in right side. In right side there is a spring tidely back side of the printer. then open all the parts from left side and right side. put of the plastic sensor that are sruck right to left in the back side of the printer. Then put off iron rod into the ink cartrige carrier. Then try to put off cartrige carrier from the printer ( where the carrier is parked). Then look the belt in the back of the cartrige carrier. Then replace it .
Thank you
Jun 27, 2011 | Office Equipment & Supplies
Brother MFC-620cn displays "Unable to Clean" error I have unplugged for hours and it will not clear. All ink cartriges are full and my status monitor indicates they are full. This came about after I did...
Your MFC has reached its limit of cleanings. The ink absorder box is full and needs to be replaced. Check the brother website for an authorized service center in your area.
Mar 29, 2010 | Brother MFC-620CN multifunction Color...
Replaced cartriges with remanafacuter. Front
Try removing all 4 ink cartridges and unplug the power.
Close the ink cover, leave the ink cartridges out and then plug the power back in.
Once the printer boots up completely, reinstall the cartridges
Mar 26, 2010 | Dell 968w Printer
My ink cartriges are stuck and I cannot get them out
Have you followed the proper procedure for removing/replacing the ink cartridges as outlined in your printer manual? (Opening the printer correctly will move the cartridges to a specific area where they can be removed/replaced).
If not, follow the instructions from HP support:
Replacing Ink Cartridges
Dec 20, 2009 | HP Officejet 5610 All-In-One InkJet...
Don't acept cartrige of ink. Allthe time the
this happens when you insert fake cartridges in HP. usually i think higher products of HP dont accept fake cartridges.
Go for vivera inks. they are genuine HP inks.
or look out for pin in the cartridge area. as it may not be settled properly
Dec 01, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Epson rx595 changed to cartriges everthing fine
Try cleaninig the ink before reinstalling it again,if problem pesist,clean the surface contact on the printer and put back the ink,if pops up again,replace the ink.
Jul 13, 2009 | Epson Stylus CX6000 All-In-One InkJet...
I haven't used the printer in a while (about 6 months) then last week I turned it on and tried to use it. Went to print a test page and it went through the process but nothing came out on the paper. I...
Take out the cartriges and hold one at a time between your forefinger and thumb tightly. Hit your wrists together and see if ink comes out the bottom of the cartrige. Be careful not to mess ink on your clothes or carpet etc. This sharp "shock" will bleed the cartrige and hopefully the cartrige will work. Clean all messed ink from any contacts and the jet area of the cartrige before inserting back into the plotter.
Dec 14, 2008 | HP DesignJet 750c plus InkJet Printer
How do I replace the ink in my HP Officejet G85?
Generally, you open the cover of the ink area, when the machine is on, and the cartrige tray will move to the center. The inks rotate out, look for instructions inside, usually downward. Remove any tapes or covers from the ink, don't touch the contact area. Snap the ink in, close the lid, see what the computer has to say.
Aug 09, 2008 | Office Equipment & Supplies
Hp Officejet 6310 All-in-one paper jam
Here's a video that shows how to clear a jam on this printer.
Apr 08, 2008 | HP Officejet 6310 All-In-One InkJet...
Canon Pixma iP2600 Photo InkJet Printer Logo
old marine
old marine
