Question about Motorola Mobility V557 Cellular Phone
Screen reads insert SIM and Sim is installed?
  • 77 Answers
Reinstall the sim card carefully to fit or your sim card is damage.
Posted on Sep 29, 2009
Testimonial: "Thanks"
  • 496 Answers
If you tried another sim in your phone, this could be the result. Nowadays, some phones "recognize" the original sim card and may reject another. You might have to get with your provider to clear this up.
Hope this helps... Good luck.
How to get phone to read sim card
Could be a bad sim card. Connect to your PC and see if you can read the sim card installed on your device, if so, attempt to go into it and check if accessible.
Sep 03, 2015 | Blu Win HD W510L 8GB Unlocked GSM Windows...
How do i install sim on a kyocera c653 phone
Did you mean the Hydro-life C6530N phone? There is no C653 listed on the Kyocera USA web site. The following is copied from page 9 of the manual for the C6530N:
Insert the SIM Card
1. Insert your thumbnail or fingernail into
the slit and lift the battery cover.
2. Grasp the white pull-tab extending from
the battery pack and pull the battery out
of its compartment.
3. Use your fingernail to carefully pull out
the SIM card tray.
4. Place the SIM card into the tray, with
the gold contacts facing down and the
cut off corner on the top left. Insert the
SIM tray back into the SIM card slot and
push until it clicks into place.
Note: Make sure not to insert the SIM
tray in the opposite direction.
5. Insert the battery, contacts end first, and
gently press into place.
If the tiny type is too hard to read, you can view the manual with a PDF reader at http://www.kyoceramobile.com/hydro-life/Hydro_LIFE_User_Guide_T-Mobile_en.pdf
There is a different manual for the MetroPCS version of the phone, but the SIM card installation is the same.
Jan 03, 2015 | Kyocera Cell Phones
Galaxy s3 not reading sim card, how to install it
check the symbol print on your phone near sim tray,there is a cut on one corner,as like on the sim, one side cut,insert sim as like
Feb 15, 2014 | Samsung Galaxy Cell Phones
My Sim Card won't read in my LG Gm310 phone
Perhaps the sim card was not initialized. Initialization allows you to communicate.
Feb 11, 2018 | LG Cell Phones
How i will initialize my SIM card?Should i enter my SIM PIN number?
Hi
Remove the battery from your phone. Slide off the back cover of your phone to get to the battery. Gently lift the battery from its compartment to remove.
Insert the SIM card into your phone. Once your battery is removed, insert the SIM card into your phone. Look at the image on the phone to see how to insert the SIM card correctly. Make sure it is pushed all the way into place.
Replace the battery and turn on the phone. Replace the battery back into its compartment and replace the back cover. Turn on your Nokia 2610 phone, and it should boot up. The name of your wireless provider will appear when your phone is turned on.
Allow time for your phone to read the SIM card. Once your phone is booted up, it will say initializing. This means that it is reading your SIM card information. Once your SIM card is read, your phone will go to the home screen. Your SIM card is now activated, and you should be able to access all of your information.
Please accept the solution if it's helpful. Do get back to us for any further query.
Sep 20, 2010 | HP iPAQ h6315/h6365 Pocket PC
My sim card when installed into my 5800 ,screen reads no sim inserted yet tried sim in 3 other phones sim fine message now reading phone is offline.
must be problem with the sim bracket of your phone if the sim is working in other phone. If so, then visit the nokia customer care centre
Sep 07, 2010 | Nokia 5800 XpressMusic Smartphone
My iphone isnt reading my sim card, it says "no sim card installed, insert a valid sim with no pin lock to activate iphone" when i try to slide to unlock it it takes me to emergency calls, please help
Try replacing you sim and if you still get the same error then it is a device issue. You will need to contact your service provider for replacement options!
Mar 13, 2010 | Apple iPhone 3G Black Smartphone
URGENT: INSERT SIM - UNABLE TO CHARGE
dear for not charging first check ur charger if ok then check and clean charging jeck. even not ok chen the status of solder of jeck if it is unsolder then sold it. even if not ok then check the charging fuse 0 ohams if meter shows continuty then ok other wise replace fuse. for inser sim card check connection from sill card ic(like combice resistor)
Mar 25, 2007 | Motorola Mobility RAZR V3
Motorola Mobility V557 Cellular Phone Logo
112 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
